ADV bike lower than a Vstrom?
Discussion in 'Japanese polycylindered adventure bikes' started by Woodsparrow, Nov 18, 2019.
  1. Woodsparrow
    Woodsparrow Been here awhile
    Aug 5, 2019
    186
    Texas
    I like my 650, but the height is really driving me nuts. Even with a small lowering link and adjusting the suspension, it's too tall for me, and I'm not sure I want to invest in it further. 30" inseam. Plus the previous owner seems to have bought every accessory ever made for it and then removed half of them, kind of. I recently had to take it to a dealership because I couldn't figure out the blasted lighting problems - they traced the headlight failure to an LED tail light replacement that hadn't been grounded, and there were 3 different headlight harnesses run through it, plus like 4 things wired into the battery.
    Anyway. I don't think I want to mess around with the bike - it's great but maybe just not for me. So I'm debating swapping to something I can flat foot, and I'd like to keep the ADV style ride if I can, if anyone has a suggestion. I do need to either run 30+ miles on the highway one way to work, or 5 miles to the train station on city streets, so I kind of need a good at everything ride, especially one that won't require me to fill up halfway to work.
    I won't offroad it at all, I just like upright rides (can't do cruiser or sport seating because of back).
  2. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    8,473
    Versys X?
    I'm not sold on seat height as a gauge; for example my X-Country with 32.5" seat feels the same height as SWM Superdual which is 35". BMW uses "inner leg curve, unladen weight" formula which takes into account bike width and surprisingly some taller bikes are easier to flatfoot than lower ones.. GS is one of them
  3. mentolio
    mentolio King of the island of unwanted toys...
    Jul 14, 2016
    924
    Honda CB500X or NC700/750X? Dunno for certain the seat height, but Honda makes a soft suspension with a lot of sag?
    EZMoney likes this.
  4. Davidprej
    Davidprej Davidprej Supporter
    Dec 27, 2012
    950
    Lafayette, LA
    This site might help you evaluate the different bikes. https://cycle-ergo.com/
    You click through to find the bike, then add your personal height, inseam, then you can add other bikes.
  5. Woodsparrow
    Aug 5, 2019
    186
    Texas
    I usually use Cycle-ergo to determine fit, so the formulas shouldn't matter? I should be able to flat foot the GS. I don't think I can afford any of the fancier or more expensive GS models. I'm about pegged at a few thousand after trade, and I'd like to just get a new bike and avoid the dang gremlins I always seem to find.
  6. Woodsparrow
    Aug 5, 2019
    186
    Texas
    I've had a couple NC700s (don't ask) and they're pretty close to the same height as the Vstrom. A little lower, but still not 'flat foot'.
    CB500X was probably one of my favorite bikes, but I did feel it was a little under-tuned for the highway.
  7. Woodsparrow
    Aug 5, 2019
    186
    Texas
    I use the pants off that website!
  8. ScorpionT16
    ScorpionT16 Been here awhile
    Jul 3, 2018
    339
    Mississauga, ON
    https://www.rideapart.com/articles/...venture-vs-2013-honda-cb500x-comparison-test/
    CB500X would be my suggestion, pre-2019 before they added the 19" wheel and raised it a few mm. I have one now, and am switching for the opposite reasons, it's too low for me, at 34" inseam I can flat foot, stand straight, and still have a couple of inches under to spare. I had a SV650, same engine as the V-strom, didn't miss the power after a few days
    #8
  9. Woodsparrow
    Aug 5, 2019
    186
    Texas
    I'll take another look. I had one a few years ago. Even if they are clearancing the 2019 models it'll probably work. Especially if I drop a suspension kit in, those normally lower it a bit.
    #9
  10. cyclopathic
    Dec 23, 2007
    8,473
    The cycle-ergo provide useful information but not tell the whole story; you have to check bikes in person.
    What year is your Wee? They redesigned plastics and seat/tank for Gen3 and it made it slightly better for vertically challenged guys like you and me. IIRC the inner leg curve, unladen weight for regular GS listed at 1900mm, same as for G310GS.
    #10
  11. Woodsparrow
    Aug 5, 2019
    186
    Texas
    2013, so it should be one of the shorter ones already.
    Edit: I think 1900mm might be wrong - that's 74 inches?
    #11
  12. yokesman
    yokesman Long timer
    Sep 12, 2008
    2,771
    SW. Idaho
    the vstrom seat is abit wide, so some bread knife to the side foam n you will gain some stand up room.
    #12
  13. Shep
    Shep Vagabond Supporter
    Oct 3, 2003
    1,768
    Louisville, KY
    With a 29” inseam just about every bike I have ever owned is “tall” for me. I have a 2017 650 that I put a lowering link on. I guess I’ve just gotten used to dealing with tall bikes, but I also have a 2017 Triumph Street Scrambler that I can easily flatfoot...different style but a lot of fun to ride. I also had a Tiger 800 XCX Low suspension model that I could nearly flatfoot.
    #13
    danketchpel likes this.
  14. eakins
    eakins Butler Maps
    May 29, 2002
    36,985
    Fort Collins, Colorado
    F/G 650 GS
    https://www.advpulse.com/adv-bikes/top-10-adventure-motorcycles-for-short-riders/11/
    I have AX41 tires on mine and have alot more fun in the dirt than on my 650 Strom.
    I have a Seat Concepts tall/Dakar seat to vs the standard lower Seat Concepts seat.
    28" inseam here and no issues with flat footing my GS. My Strom also with Seat Concepts is taller on my feet for sure.
    Both bikes are 19/17" and so so ground clearance. GS is lighter and feels just as fast up till about 70. Both bikes need suspension work!
    #14
    rauchman and cyclopathic like this.
  15. eakins
    eakins Butler Maps
    May 29, 2002
    36,985
    Have you sat on and tried the Himalayan?
    Low seat and COG. Might be the torquey motor you need.
    #15
  16. Cal
    Cal Long timer
    Mar 11, 2008
    3,951
    Calgary
    I think my inseam is 29" but I may be shrinking to 28" I have the 2012 strom with a 7'8" lowering link and I had 1/1/2 inchs cut out of the seat, it is perfect balls of the feet. I use a sheep skin for long highway runs and that adds more comfort but raises me about 1/2"
    #16
    cyclopathic likes this.
  17. danketchpel
    danketchpel Long timer
    Jun 1, 2010
    4,281
    Camarillo, CA
    That's what I was going to suggest but I don't know how it falls into the budget. My Bonneville T-120 is the only bike in my garage I can truly flat foot (29" inseam). I've ridden tall dirt bikes for so long I've gotten used to never being able to flat foot.
    Other bikes that come to mind are the Tiger 800 roadie low, I could flat foot that bike, RE Himalaya but wheezy on the freeway, that BMW F650GS, maybe the already mentioned CB500X. Otherwise you're in cruiserville the home of low seat heights.
    #17
  18. cyclopathic
    Dec 23, 2007
    8,473
    The measurement is x2 leg inseam running one leg from the bottom up and down second. R1200GS is also listed as 1860mm with seat in low position.. comparing to G310GS 1900mm. They also have factory lowered version IIRC.
    The Wee-strom was redesigned for 2017 and should feel lower than Gen2 you have. I have owned 2015 for 2 years same as yours put happy 73k miles on it. That bike is wide I ran lowering links and modified seat.
    Edit:
    R 1200 GS BMW bike Seat Height Reference:
    800/820mm - Low Suspension Kit (Option) 820/840mm - Low Front Seat (Option/Accessory)
    825/845mm - Low Comfort Seat
    #18
  19. Woodsparrow
    Aug 5, 2019
    186
    Texas
    I'm really looking at a GS 750. I'm going to to sit one tomorrow. I don't think I can afford one, the cheapest new is still 11k, and I'm not seeing any used nearby.
    #19
  20. Woodsparrow
    Aug 5, 2019
    186
    Texas
    I'm going to try it - same place has like 6 different bikes I want to check out tomorrow. Worried that it won't have the top speed I'd like.
    #20
    eakins likes this.
