Adventure Sportster Build AKA Piglet
Discussion in 'Some Assembly Required' started by Austin hayes, May 28, 2016.
  1. johnwesley
    johnwesley wanta be
    May 11, 2006
    3,377
    mena, Ar
    Not sure if you still need an answer on this but mine fit with out issue. I still have my hydro set up hanging on the wall in the shop from when I parted the sportster out.
    I’m anxious To hear how those shocks work for you. I use to run them on an old rock crawler I had. They were popular for those of us who didn’t want to drop thousands on coil over set ups. We ended up running limit straps to keep them from unloading. I run one strap in the middle so as to keep full travel articulation but limit full axle droop.
  2. Austin hayes
    Austin hayes Been here awhile
    Sep 16, 2015
    244
    Richmond
    She lives! Should be taking it around the block soon, still need to build the exhaust and chain tensioner and order a few small parts. And obviously it's going to need some paint
  3. madrider5150
    madrider5150 Riding somewhere
    Oct 15, 2013
    1,348
    PNW
    So did you find out a way to run the chainsikle lowsets with that speed merchant sprocket cover?
    villageidiot likes this.
  4. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Haven't sorted that out yet, I don't think it's going to be a big deal at all though. Just needs some spacers
    madrider5150 likes this.
  5. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Took it around the block this morning, still a long way to go but it was motivating as fuck to ride
  6. Austin hayes
    Sep 16, 2015
    244
    Richmond
  7. ClutchDumpinDan
    ClutchDumpinDan Go do
    Nov 12, 2015
    1,641
    Virginia
  8. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Just a bit over 12"
    ClutchDumpinDan likes this.
  9. ClutchDumpinDan
    Nov 12, 2015
    1,641
    Virginia
    Sweet. Gotta find bigger logs to get stuck on now.
  10. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Made up a new kick stand out of some 3/4" .120 wall DOM, with a coffin shaped foot. Wish it tucked in a little tighter, but it works well and that's what counts. Needs a stronger spring.
    Chopped my shitty old exhaust so I could mount up the rear brake setup, chain sickle bolted up to the speed merchant cover with a few simple aluminum spacers, not a big deal at all
    Rode it about 15 miles today, runs like a raped ape. Pulls power wheelies with ease
  11. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Got my new hydro clutch set up from @johnwesley , looks great! Thanks man!
    smolt, AK650, ClutchDumpinDan and 2 others like this.
  12. johnwesley
    johnwesley wanta be
    May 11, 2006
    3,377
    mena, Ar
    Couldn’t have went for a better project. Can’t wait for you to give it a run
    smolt, AK650 and villageidiot like this.
  13. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    14,708
    Orange County, CA
    did ya put tips on the spacers to key into the counterbores on the speed merchant sprocket cover?
  14. CopyCat
    CopyCat I am NOT like the others Supporter
    May 16, 2015
    804
    behind the cheddar curtain
    Austin, will you please educate me about where you got your rear brake line? And did you use the stock brake light pressure switch?
  15. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Nope, I'm considering welding the spacers to the cover though.
  16. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Just ordered it through summit racing, they stock almost every length and type of hose you could want. Had to get a special hose fitting for the wilwood caliper
  17. villageidiot
    Apr 29, 2010
    14,708
    Orange County, CA
    any good hydraulics shop can make a custom brake hose.
    i had 4 brake hoses made today for a car at work.
  18. AK650
    AK650 Long timer Supporter
    Jun 26, 2013
    1,959
    Alaska
    Look forward to hearing how the hydro clutch works out....very interesting!:thumb
  19. madrider5150
    Oct 15, 2013
    1,348
    PNW
    How did you measure what length bolts you needed with the different spacing on that sprocket cover? I had a hell of a time trying to measure things and find the correct length bolts to get the right amount of threads into the engine case or same as stock set up anyway. Maybe speed merchant is more similar to stock but Ive run into the same problems with tracker die and licks now. Shane at chainsikle should just make his own steel or billet sprocket cover that works with his lowsets.
  20. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Depth Guage on a caliper
    AK650 and madrider5150 like this.
