Adventure Sportster Build AKA Piglet
Discussion in 'Some Assembly Required' started by Austin hayes, May 28, 2016.
  1. Austin hayes
    Austin hayes Been here awhile
    Sep 16, 2015
    244
    Richmond
    Got the hydraulic clutch installed and some new grips, took it for test ride. It doesn't drastically reduce clutch pull but it does give it a much more precise feel
  2. johnwesley
    johnwesley wanta be
    May 11, 2006
    3,335
    mena, Ar
    One thing, I had a skid plate that helped cover that, come to think of it I still have a skid plate:lol3
  3. AK650
    AK650 Long timer Supporter
    Jun 26, 2013
    1,824
    Alaska
    Not to be Captain Obvious, but you definitely want to be sure the bolts aren't too long(especially just barely too long), as you run the risk of bottoming out in the blind hole, and damaging the case.
  4. c1skout
    c1skout Long timer
    Sep 29, 2009
    1,691
    Western PA
    Wow! Looking great!
  5. johnwesley
    johnwesley wanta be
    May 11, 2006
    3,335
    mena, Ar
    That wire clip that was on the hydraulic line was attached to the motor mount bolt. It kept the line close to the bike.
  6. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Started working on the exhaust
    Made the collector from a 90° bend, exhaust is going to wrap behind the shock and I'm running a lossi reverse cone muffler
  7. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    13,989
    Orange County, CA
    Lossi (lossa I think) uses cone engineering megaphones/mufflers etc. check cone engineering out might save ya a few bucks.
    CopyCat and JagLite like this.
  8. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Finished building the collector and tacked everything up. I wasn't quite sure how to go about building a collector, but what I did worked out decent, could be a little smoother finish.
    I ended up hammering out a piece of straight pipe over a piece of Dom in the bench vise to flare the end. Still need to route the exhaust up and behind the shock to the muffler
    smdub, madrider5150, AK650 and 3 others like this.
  9. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Welded up the exhaust, just gotta finish grinding some welds and make a mount tab for it
    It tucks in nice and tight against the bike, and sounds killer. Stoked on how it turned out
  10. JimVonBaden
    Feb 11, 2005
    91,764
    Alexandria, VA
    Pipes look great!
    Those gas rear shocks?
    Not a fan of the rear bodywork, but the rest of the bike is kick ass!
  11. Bigeyedfish
    Bigeyedfish Adventurer
    Aug 19, 2018
    31
    Missouri
    Gotta admit, I don't know my way around a V-twin very well. Is the exhaust all one piece? Seems like it would be tough to remove with no connections between the cylinders and collector.
  12. Austin hayes
    Sep 16, 2015
    244
    Richmond
    All one piece, it slides right into the exhaust ports no problem
  13. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Made up a rear exhaust mount
    Finally figured out how I'm going to keep the chain tensioned
    Maintains equal chain tension during full suspension travel. The slider is a slide pad from a telescopic crane and and is moly impregnated plastic, it should last quite a while even with the pressure of chain during acceleration. I need to finsh the mount for it still, it's just tacked in place.
    Stripped it back to the bare frame and painted it
  14. ClutchDumpinDan
    ClutchDumpinDan Go do
    Nov 12, 2015
    1,614
    Virginia
    Interesting solution for the chain slider/tensioner. Curious how it’ll hold up over time. Can’t wait to see it all back together!
    AK650 likes this.
  15. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Put it all back together and started final assembly. Still waiting on a few parts to finish the swing arm and oil tank, frame paint looks like complete shit, solvent pop and flat spots everywhere but I don't have time to do it again right now. It will get powder coated next winter.
    All of the wiring sits inside of the headlight bucket and any exposed wire is cloth covered, loom is asphalt covered fabric
  16. Austin hayes
    Sep 16, 2015
    244
    Richmond
    She's done! Shakedown run went well, chain slider is wearing to quickly, ordered some stronger nylatron slider material and I'm going to try skateboard wheels for the roller. Other than that it ran great
  17. ClutchDumpinDan
    Nov 12, 2015
    1,614
    Virginia
    Wicked. Can’t wait to see it tearing up the Rockies!
  18. johnwesley
    johnwesley wanta be
    May 11, 2006
    3,335
    mena, Ar
    Looks fun
    I ended up with a skate board wheel on mine and it worked well. I tried different slider materials and mounted them flush with the swing arm. A little shaping and you can get them to bend slightly around the swing arm pivot. I believe I settled on delrin for the side. I still have a piec out in the shop. If ya want I can get the specs off of it.
  19. Dino de Laurentiis
    Dino de Laurentiis Working on it
    Mar 20, 2010
    519
    Ultima Thule
    I think you have a swingarm geometry issue rather than a slider material problem. Easier said than done, I know, but id say you won’t get around the problem unless you lower the swing arm pivot an inch or so, and mount the slider flush to the swing arm like johnw suggests above. Anti squat would be less extreme as well that way.
  20. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Yep I agree,already planning on that. I've got a spare frame sitting around to experiment with.
