    Dismiss Notice
Adventure Sportster Build AKA Piglet
Discussion in 'Some Assembly Required' started by Austin hayes, May 28, 2016.
  1. Austin hayes
    Austin hayes Been here awhile
    Sep 16, 2015
    244
    Richmond
    That would definitely save me quite a bit of guess work, thanks !
  2. johnwesley
    johnwesley wanta be
    May 11, 2006
    3,359
    mena, Ar
    What shock r u using and what stroke?
  3. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Currently a junk 15'' shock , I'll be upgrading but I haven't decided on the exact one I want .
  4. johnwesley
    johnwesley wanta be
    May 11, 2006
    3,359
    mena, Ar
    Reason I ask is progressive makes a 15" and it only comes with 2 spring options. I used a 17" shock and would recommend not going that long. It will cause unnecessary chain rub issues.
    You will end up with a shock stroke ratio of around 2:1 so you can just double the shock stroke to get close to your travel. So if you find a 4" stroke then you can count on 8" travel. The spring I had was 21-30 N/mm rate, but I had a secondary spring which made the total spring rate softer for the first half of the travel. I'll see if I can find the secondary spring and figure out the total rate for you. If you look through my first build thread the info is probably in there somewhere
  5. boatpuller
    boatpuller Long timer
    Jan 4, 2012
    1,692
    Central fly-over land.
    Well you can have the head gasket R
    Having a hard time understanding that, as the shock mounts closet to the rear axle, how does the travel double the stroke?
  6. johnwesley
    johnwesley wanta be
    May 11, 2006
    3,359
    mena, Ar
    It doesn't when he stretches the arm 4 inches but leaves the mount the stock distance from the swingarm pivot
  7. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Burned in the extension today and got it sitting on its own weight. 20161210_180819_HDR.jpg
    Measured my shocks and they are 15.75 eye to eye , I could definitely go with a longer shock that had some sag , these things have maby 1/2'' sag with me on it .
    Clearance from top of tire to bottom of seat hoop is a issue, I built the hoop running a 16'' wheel, with more shock up travel I'll have major issues that will need addressed .
    ClutchDumpinDan likes this.
  8. johnwesley
    johnwesley wanta be
    May 11, 2006
    3,359
    mena, Ar
    i ended up with A rack from a gs grafted on to the front half of a stock rear fender. that kept the rear tire from hitting a fender and gave a nice place to mount luggage
  9. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Stripped her down for the winter tune up. Getting gaskets, and some paint. Possibly heads if I can find a set, front head exhaust studs all junked up, preferably Buell heads
  10. Hvymax
    Hvymax Been here awhile
    Sep 22, 2016
    453
    La Plata MD
    That is so what I was planning before I got a KLR. I will probably do it someday when I have the time. Stretching the swingarm would be first on my list.
  11. Austin hayes
    Sep 16, 2015
    244
    Richmond
    KLRs suck, get a sportster
    madrider5150 likes this.
  12. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,166
    Your imagination.
  13. madrider5150
    madrider5150 Riding somewhere
    Oct 15, 2013
    1,328
    PNW
    Are your forks the stock length or shortened? Its got a nice stance with the extended swingarm. Looks like a good time to powdercoat the frame..
  14. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Stock for the wp 50mm, they are compressed a bit in that pic since it's strapped to the table.
  15. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Been awhile since a update, frames bare, motors torn down waiting on a set of buell xb heads I scored, working on trimming as much excess from the bike as possible.
    Need to order pistons, shocks and cams.
    JagLite likes this.
  16. madrider5150
    Oct 15, 2013
    1,328
    PNW
    Are you still working on your own rear sets? Did you finish your swing arm extension?
  17. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Extension is done, no progress on rear sets, not sure what I'll do for them. Build direction has changed as life is always changing. She will be getting some better funding and more time, it's no longer my primary bike. Planning on more of a race bike, and it will probably end up at a few shows. Attention to detail has become more of the primary focus.
  18. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Scored a set of 17.5'' fox float 2 air shocks today, planning on setting them at 16'' with me on the bike. Will net 8ish in'' of travel.
    Xb12 heads need milled for carb/breather and I am looking for a set of xb9 pistons that net about 12-1 compression which is high but I'll be running hot cams with more overlap so real compression ratio will be lower.
    Plan on keeping the hsr42 carb and building a hi 2-1 pipe with a cone engineering muffler. Scored a screaming eagle ignition module I may run, heard really good things about them. Not super pleased with my dynatek dualfire system.
  19. ClutchDumpinDan
    ClutchDumpinDan Go do
    Nov 12, 2015
    1,628
    Virginia
    That sounds like fun, you know where to find me.
    What size pipe? I've got a bunch of bends.
  20. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Pretty stoked on how it sits. Will sag some with the engine in it, which will be about right
    kraven and ClutchDumpinDan like this.
