    Dismiss Notice
Adventure Sportster Build AKA Piglet
Discussion in 'Some Assembly Required' started by Austin hayes, May 28, 2016.
  1. Austin hayes
    Austin hayes Been here awhile
    Sep 16, 2015
    244
    Richmond
    As of right now I have no intention of altering it from stock.
    I am curious what it will end up weighing, I really have no idea what it will be.
    Richy likes this.
  2. madrider5150
    madrider5150 Riding somewhere
    Oct 15, 2013
    1,328
    PNW
    Excellent, happy to see some updates on this beast! Pretty sure others have used hydraulic clutch with chainsikle rearsets but cant say for certain. Are you planning anything in terms of crash bars/engine protection?
  3. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Going to ditch that crappy aluminum skid plate I was running and make a new steel one, along with some sort of crash bar in the future, no definite plans and it's not really a high priority.
  4. madrider5150
    Oct 15, 2013
    1,328
    PNW
    The Chainsikle shifter is very vulnerable to being bent in by a tip over. I'd like to figure out a folding tip or something to protect it
    Sent from my Moto G (4) using Tapatalk
  5. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Progress!
    New boat tail seat and a tank that's not all fucked up
    Chain slider
    Coil and ignition toggle bracket
    madrider5150 and ClutchDumpinDan like this.
  6. CopyCat
    CopyCat I am NOT like the others Supporter
    May 16, 2015
    784
    behind the cheddar curtain
  7. Austin hayes
    Sep 16, 2015
    244
    Richmond
    A KTM 640 Duke? Not 100% sure
  8. ClutchDumpinDan
    ClutchDumpinDan Go do
    Nov 12, 2015
    1,631
    Virginia
  9. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Pulled it apart and put some primer on it
    Chopped off the tail section...
    Bought some 1" .120" wall DOM to make a new tail section
    Ordered some parts....
  10. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Mocked up the caliper
    Need to make a brake stay bracket
    Gotta make a tensioner for the chain
    Picked up a biltwell whiskey throttle, I got tired of the 1" throttle on the 7/8" bar being sloppy
    johnwesley and ClutchDumpinDan like this.
  11. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Tried out a few different ways to do the brake stay, this is the best thing I could come up with using a grinder, drill and file
    Somehow my speed holes ended up a little off but I wasn't about to make a new one over that
    ClutchDumpinDan likes this.
  12. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Decided to run a little bit different motor setup than I had been planning on, before I was planning on 12.5:1 compression and Andrew's n6 cams, new plan is 10.5:1 and Andrews n4 cams for a little bit milder street motor that will run reliably on pump gas
    New NHRS pistons
    Cams are in the mail and jugs are at the machine shop getting bored .060 over for the new pistons
  13. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Started working on some swing arm braces
  14. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Bend up the new tail section....
  15. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    14,359
    Orange County, CA
  16. Austin hayes
    Sep 16, 2015
    244
    Richmond
    1" .120" wall DOM
    villageidiot likes this.
  17. madrider5150
    Oct 15, 2013
    1,328
    PNW
    Interested to see what you come up with for the chain tensioner
  18. Austin hayes
    Sep 16, 2015
    244
    Richmond
    Made up a matching swing arm brace for the other side, just need to weld them on.
    A few more parts showed up in the mail, I sure do like billet but my bank account isn't a big fan of it.
    Turns out the EFI Buell heads I'm running need a special intake manifold to work with a carb, the mounting surfaces on a the EFI heads are milled down a 1/16 on each side, resulting in a poor intake seal if you try to use the stock carbed manifold
    ClutchDumpinDan and madrider5150 like this.
  19. villageidiot
    Apr 29, 2010
    14,359
    Orange County, CA
    Who’s sprocket cover is that?
    Speed merchant? TC BROS? it’s not tracker die, I have that one.
    I hope your chainsikle lowered rear sets are better than the garbage he sent me, which took a month to return.
    C196D36B-95BE-4B37-A275-5A88C0418811.jpeg 54E868D0-F91F-46DA-A3BD-6F9A28406AEE.jpeg 96F9691F-1A72-4B86-8A1A-CBA5C1C70B6C.jpeg 632BAE91-3338-4F1E-B84C-F7B9BF874419.jpeg
  20. madrider5150
    Oct 15, 2013
    1,328
    PNW
