Adventurizing a KTM 500exc for RTW Riding
Discussion in 'Thumpers' started by rtwpaul, Mar 7, 2019.
  1. Buildzall
    Buildzall Rooster Supporter
    Apr 22, 2013
    4,377
    Ga
    Fihunnid
    (Tips hat to @rtwpaul)
    CHEERS :beer
  2. rtwpaul
    rtwpaul out riding... Supporter
    Feb 7, 2011
    5,339
    arizona
    Minor upgrade but a good one, if you are setting up the exc for adventure riding then a cush drive rear wheel is a good idea, but also an expensive upgrade. Another addition you might not have considered or heard of is Rekluse clutch rubbers instead of the stock ones?
    They just have a little more structure than stock especially on the leading side, I just got some from my buddy Mike at tacomoto for $30, put them in yesterday, Rekluse on the left
    LM15, Magile, Ginger Beard and 10 others like this.
  3. Takataka
    Takataka Been here awhile
    Sep 26, 2014
    617
    NZ
    What are the noticeable symptoms of worn clutch rubbers?
  4. Buildzall
    Apr 22, 2013
    4,377
    Ga
    (Insert inappropriates here)
    wilso122 and HiJincs like this.
  5. skibum69
    skibum69 slave to gravity Super Supporter
    May 14, 2006
    13,920
    New Melbourne, Newfoundland
    Those are the rubbers from your Cush drive hub? What do you notice as a difference?
  6. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    15,608
    Out in the NM Dez somewhere
    They're from the clutch
  7. chilejack
    chilejack Viajero Viejo
    Nov 7, 2010
    806
    Albuquerque
    I'm trying to find a way to cushion the drive train on my plated '18 FX350 Husky. My parts diagram research on RMATV indicates that, at least since 2005, no white or orange KTM below 600 cc has come with a cush drive rear hub. Prior to 2012 the enduro bikes under 600cc used a rubber ring cushion in the clutch hub. After 2012 the enduro bikes use individual rubber cush pieces as in Rtwpaul's pic above. The motocrossers and cross country derivatives like my FX350 have no rubber cush clutch pieces. The cush equipped clutches don't appear to be a drop-in alternative for the race bikes, so apparently, I need to go with a cush drive hub from the over 600cc singles. Maybe a Recuse auto clutch is the solution?
    Using cush rubbers in the clutch rather than the rear wheel reduces overall and, particularly, unsprung weight. KTM obviously feels that the clutch rubbers provide adequate drivetrain protection on pavement. There may be a small performance loss, which would account for not using them in the race bikes.
  8. dirtyoffroad
    dirtyoffroad Been here awhile Super Supporter
    Jan 26, 2008
    674
    merrimack,N.H.
    you can have a rear wheel built with a cush hub.
  9. Buildzall
    Apr 22, 2013
    4,377
    Ga
    Warp9 makes great wheels and sells a cush hub. I have 4 sets of warp9 and two are cushhub.
    I'm 5years on mine.
    I have no complaints.
    Fihunnid
    LM15, Thumperama, JagLite and 6 others like this.
  10. bobfab
    bobfab Long timer Supporter
    May 11, 2009
    2,357
    Limerick, PA
    Chain looks too tight!
    Haha I had to be *that* guy
  11. skibum69
    May 14, 2006
    13,920
    Right...clutch.
  12. Scutty
    Scutty Talent-limited bike builder and rider
    Jul 19, 2011
    744
    Sunny Surrey, UK
    If you're running any kind of knobbly tire then surely that is a way more effective cush? I understand them on road bikes with very grippy road rubber but for off road or dual sport tires?
    Fast1, chilejack and jm19328 like this.
  13. kubcat
    kubcat Riding is Eudaemonic Supporter
    Sep 22, 2016
    1,952
    Upstate NY
    I recently bought a pro moto billet kickstand for my 2014 350 EXCF, but it seems to be too long or too steep. The bike is very upright now and even on a flat surface can be tipped over if I bump into it. Has anyone else experienced this problem? What did you do to solve it?
  14. renogeorge
    renogeorge Let's ride!!
    Apr 7, 2007
    6,524
    Reno
    I have installed many over the years. I have found their stands to be the correct length for all bikes except those that have been lowered either with link, shock shortening or backing shock preload off. For these I just shorten the stand. FWIW
    RideFreak and Buildzall like this.
  15. Buildzall
    Apr 22, 2013
    4,377
    Ga
    Agreed, if your rear suspension is low (for us short legged sob's) the stand is long.
  16. Buildzall
    Apr 22, 2013
    4,377
    Ga
    Agreed, more applicable for road senario.
    I mounted this tire on cush hub wheel for a ride where I needed a sand/mud tire for the day and this rim with dead street tire was available for the ride.
    Had a great time!
    Now I can do some nasty redline clutch dumping burnout wheelies in the road -shred it - (whooot) -
    then get the new street-ish Tusk Adventure tire mounted on there.
    As for the benefit or suitable applications, consider long term ownership and Accumulated high miles on street, dualsport, hard pack and mixed use Adventure miles with hard rubber Adventure tires.
    It's a nickles worth of additional preventative medicine.
    It might be modern day snake oil.
    Might be old school snake oil with cocain in it : )
    Maybe It's not helping you or doin you any good but...
    ... you'll feel better and like it too : )
    Remember.....
    Don't do drugs.
    Wheelie for Safety.
    JagLite likes this.
  17. yokesman
    yokesman Long timer
    Sep 12, 2008
    2,802
    SW. Idaho
  18. Buildzall
    Apr 22, 2013
    4,377
    Ga
    If your out roosting its nooo problem.
    Stay safe.
    Roost on : )
  19. kubcat
    Sep 22, 2016
    1,952
    Upstate NY
    The bike is stock height. I will double check preload, but I'm pretty sure that its is higher, rather than lower, than typical because I set it for ADV riding with a loaded MM R40 pack. Any other thoughts?
  20. renogeorge
    Apr 7, 2007
    6,524
    Reno
    Monster mudder tires?
