Adventurizing a KTM 500exc for RTW Riding
Discussion in 'Thumpers' started by rtwpaul, Mar 7, 2019.
  1. Kshaw
    Kshaw Been here awhile
    Apr 9, 2020
    324
    San Antonio
    Been messing with my reckless 80 for a couple days on my 2021 500 exc and I’m trying to decide if I should keep it or not. My plan is to only use the legs, and leave the top beaver tail empty most of the time. This would keep the weight low and forward while leaving the tail of the bike empty.
    I am worried about exhaust burns though since it seems to hover above the exhaust a few inches in the back. Any issues with this? I do not want to add a rack if I can help it.
    On mosko vendor thread they suggest burning new holes to angle the legs up more but I’m hesitant to try this in case I want to return it.
    Magile likes this.
  2. chilejack
    chilejack Viajero Viejo
    Nov 7, 2010
    807
    Albuquerque
    If the bike is stock height, you may have the wrong stand. Measure it and check with PMB.
    Buildzall and renogeorge like this.
  3. kubcat
    kubcat Riding is Eudaemonic Supporter
    Sep 22, 2016
    1,955
    Upstate NY
    I have been thinking about that. Seems like a good possibility, given the sh*tshow it was working with them. As we all know by now, COVID created a high demand and severe shortages of adventure bike gear. Fastway/ProMotoBillet was one of the hardest hit - good for their revenue, but terrible for business operations. After talking with them for a while, and getting a "good faith" estimate on the backorder time frame (3-5 weeks - seems reasonable), I ordered the stand on June 24th, knowing I didn't really need it until a few days before our planned trip on August 15th to run the NEBDR for a week. Well, the long and the short of it is that they had the mechanism back in stock in that time frame, but for some reason the machining run for the specific kickstand leg made for my 2014 350 EXC never got done until the week AFTER my trip in August. After all the confusion and seemingly inept management of their production resources, the most likely answer is that they shipped me the wrong stand. However, I see that the stand is currently on backorder now, so I can't see how they could make it right even if they did ship me the wrong part.
    They make great products, but I think the have to reconsider how they are managing the business operations - probably just some hacks that like bikes and got lucky. Now they are well over their heads, so I will have to factor that into all of my future buying decisions. I suggest others consider this as well if you are in the market for any of their products that are on backorder.
    tlrmark, JagLite and Bt10 like this.
  4. chilejack
    Nov 7, 2010
    807
    Albuquerque
    Have you compared the length to your OEM stand?
    Fast1 likes this.
  5. renogeorge
    renogeorge Let's ride!!
    Apr 7, 2007
    6,529
    Reno
    I have also been frustrated with delays from PMB and other suppliers during COVID times. But I think you are reading in a lot from your experience. I have found PMB to be very professional, certainly not a bunch of hacks. FWIW
    LJC, JagLite and Wattner like this.
  6. powderpig
    powderpig Been here awhile Supporter
    Nov 15, 2011
    208
    Bend, OR
    It would be a pretty simple repair for a welder to just shorten it. Might be easier than going through the hassle of an exchange.
    Burro driver likes this.
  7. chilejack
    Nov 7, 2010
    807
    Albuquerque
    It's made from billet aluminum and is pricey. I don't think I would chance cutting and welding it. If it's the wrong stand, PMB/Fastway should conjure up a replacement. Email or phone them to verify the length. If the length is right, there is an issue with the height of the bike itself.
    Wattner likes this.
  8. 2old2Bbold
    2old2Bbold was 2bold2getold
    Dec 10, 2011
    5,313
    Arlington, Texas
    When I shortened the rear of my 450xcw, I cut the bottom of the stand and made a new foot... easy. :D I realize it's not a stock stand but surely something can be fabbed.
    LM15, JagLite and jm19328 like this.
  9. renogeorge
    Apr 7, 2007
    6,529
    Reno
    I cut and re weld them all the time. Never a problem. But it should fit if right part and normal height bike
    JagLite likes this.
  10. powderpig
    Nov 15, 2011
    208
    Bend, OR
    Aluminum is no problem for a good welder. Easy, peasy.
  11. renogeorge
    Apr 7, 2007
    6,529
    Reno
    Since we’re on stand shortening....the oem stands are easily shortened without welding. Just use some heat and unscrew the plastic foot. Cut stand and reinstall foot. FWIW
  12. chilejack
    Nov 7, 2010
    807
    Albuquerque
    Ah, heat, that was the problem, thanks!
  13. Das alpha tier
    Das alpha tier n00b
    Nov 1, 2018
    1
    Namibia
    Hey guys,
    I am a Namibian who has been doing rides/tours on my 500 exc for the past 2 years. We did many tours around namibia, all unsupported. We did the first unsupported trip through south west angola where you cover around 650km without fuel or anything else. We came across active landmine fields and went through the famous Acre of Death.
    Have a look at some of our videos.
    https://www.youtube.com/channel/UCGCQDeeB2xVSheeJ-E2_5hw
    About our setup:
    We have 2018 ktm 500 ex's ( australian spec).
    We have the Acerbis 15.5lt tanks, Brake disc protectors, swing arm protectors and aftermarket plastic bash plates. Those are about the only mods we have.
    Tires we run mitas C02 in the rear with Michelin desert race mousses. Front we use whatever has good grip with Michellin desert mousses also. We get around 6000km out of a rear tire and the same out of the front. If you want more info just contact me.
  14. BDG
    BDG Long timer
    Jan 9, 2006
    1,193
    UK
    Great videos thanks. I’ve ridden in Namibia back in 2008, I loved the country, you’re lucky guys
  15. Kshaw
    Apr 9, 2020
    324
    San Antonio
    Anyone know if you can drop down a tooth in the front sprocket without serious wear and tear on the chain slider?
  16. Buildzall
    Buildzall Rooster Supporter
    Apr 22, 2013
    4,384
    Ga
    I run 14 with no problem s
  17. atomizer
    atomizer Be here now Supporter
    Jan 16, 2010
    675
    Dixon, New Mexico
    I ran a 13 with no problems...
  18. WR450Pilot
    WR450Pilot Adventurer
    Sep 22, 2014
    14
    Hi Paul.
    Thanks for sharing all this. It's opened my eyes and got me thinking.
    I've never ridden an "adventure bike". The closest I got was riding a friend's DR600 out of a snowy trail on terrible tires.:)
    I presently do a lot of single track/technical riding on a YZ250FX and YZ450FX. I totally get wanting a light, versatile bike for trail riding. But I also think I'd want something that is fairly comfy on the road and that would carry luggage well.
    What terrain would you ride on your world tour that would be more technical than what this guy did on his Tenere 700 ?
    How much does your prepped 500 weigh full of fuel but no luggage ? How much does it weigh fully loaded, without you ?
    How comfy would your 500 be on the road compared to the Tenere 700 ?
    What stopped you from getting the Husky 701 ? Weight ? Would the 701 be more comfy on the road ?
    Then there is this...
    And this. He claims to have ridding 100.000 km (62,000 miles) in the last 3 years.
    https://eatsleepride.com/c/332703/a_wobbly_review_of_the_2021_yamaha_tenere_700
  19. WR450Pilot
    Sep 22, 2014
    14
    Seems to keep up with regular dirt bikes pretty well. In good conditions, anyway.
    Around the world on a T700.
  20. skibum69
    skibum69 slave to gravity Super Supporter
    May 14, 2006
    13,938
    New Melbourne, Newfoundland
    Guessing the 700 would be a little more comfortable on the slab but a good saddle and good ergonomics make up for a lot.
