Advice on fuel tanks for the 525 EXC
Discussion in 'Thumpers' started by GSDude, Dec 27, 2006.
  1. GSDude
    GSDude Banned
    May 16, 2005
    23,607
    High Desert
    The 2.11 gal tank is absurd for enduro riding/racing. Any recommendations? I'd like a 4 gal.
    Thanks!!
  2. jimeconomou
    jimeconomou Guest
    The MXC tank is 3.4-5g but adds about 2-3 inches at the rads, the 6.6 KTM/Acerbis is what I have on my EXC but it is a street/adv bike, forget serious off road as it splays your legs way out unless you are on the rear fender. I'd go IMS for thin and higher capacity for off road use. If you are going to sell the stocker let me know, my brother needs one for MX. Thanks and good luck, Jim.
    Pthurman likes this.
  3. Ignore Amos
    Ignore Amos bruised, dazed & confused
    Aug 4, 2004
    984
    Tucson, Arizona
    which isn't much...I have the IMS 3.1 which advantage is that it carrys the fuel a little lower than the Clark 3.1 but the IMS does not (without a heatgun modification) allow the use of an electric fan which the Clark does...I think the Clark is a little less money too ($180 vs $199)
    I'm getting about 120 miles to the tank at trail riding speed and 85-95 at race pace (like I know what that really is...so I should say MY race pace) with the 3.1 You may not need the bigger tank if that's enough range.
  4. GSDude
    GSDude Banned
    May 16, 2005
    23,607
    High Desert
    I ordered the IMS 3.1 today..thanx!
  5. Arch
    Arch Incurable Gearhead
    Dec 30, 2001
    11,706
    Katy, TX
    Make sure the IMS clears the fan. Can't remember if those or the Clarkes fouled the fan, or even if it's applicable with either anymore, but worth asking about or looking into beforehand as it does seem to ring a bell. I run KTM's MXC (current XC) 13 liter, 3.4 gal. tank/seat for dual-sport. Clears the fan, no concerns at all with the small amount of extra width at the rads, and it better protects them. Wish it was available in natural/clear, though.
  6. rickf
    rickf oldfatguyMAN
    Jun 21, 2006
    1,695
    Temecula, CA
    I bought the IMS and, while the fit and finish is great, I am very disappointed at the amount of airflow it restricts and that it will not clear the accessory fan. I would not buy again.
  7. GSDude
    GSDude Banned
    May 16, 2005
    23,607
    High Desert
    Ooops...may have to return the IMS.
  8. Beemer Pat
    Beemer Pat ...
    Feb 15, 2004
    2,722
    rockiesriders.com
    #8
  9. GSDude
    GSDude Banned
    May 16, 2005
    23,607
    High Desert
    Thanx for the heads up..will return the IMS and get the Clark!!!
    #9
  10. jimeconomou
    jimeconomou Guest
    Sorry I recommended the IMS, I was not aware of the fan issues. I had 2 tanks on past KTMs and was impressed with the quality of fit & finish but didn't have a fan on either bike. Good luck, Jim.
    #10
  11. derekm
    derekm nOOb
    Dec 12, 2004
    45
    Seattle, Wa
    The Cyclebuy.com guys are a good bunch. They're experienced at DS and motard conversions, and close to me :thumb
    #11
  12. Ignore Amos
    Aug 4, 2004
    984
    Tucson, Arizona
    You see...you didn't read my post now did ya:nono
    I'm going to wait till summer to see how the bike runs then, but I'm in the Desert and ride on Hot days and more than likely need the fan so I'll probably have to go to the Clark as well.
    #12
  13. jimeconomou
    jimeconomou Guest
    I have the fan on my 520 with the 6.6g tank, if the IMS carries the fuel lower I would be inclined to add a different fan, I recall old computer cooling fans can be fitted easily and are cheap and smaller/lighter than the factory kit. Guys use a switch or the thermo unit from the KTM kit to trigger them. Around $12 new at electronics supply, radio shack or similar, hobby stores also, IIRC, free if you find an old computer in the trash, just a thought. Better weight distribution is a pretty strong factor, my 07 sxf250 with fuel stored underseat flicks around much easier than my older front tank SX ever did. Jim.
    #13
  14. Doug Matson
    Doug Matson Long timer Supporter
    Aug 25, 2003
    3,213
    Torrance, Ca.
    I have the IMS 3.1 but when I filled it after mounting it on the bike it took 2.85 gals. I called IMS and they said that the moulding process makes each tank a little different. You can also add the Baja Designs rear tank that holds 1.5 gals it mounts in place of the side cover. You can also do the hot water compressed air trick to expand you capacity of the tank.
    #14
  15. GSDude
    GSDude Banned
    May 16, 2005
    23,607
    High Desert
    3 GAL should be enough for 125+ miles..most of the enduros I run are 100 and have a fuel stop about halfway which is fine.
    #15
  16. rmaudsley
    rmaudsley Been here awhile
    Aug 3, 2004
    143
    Tucson, AZ
    #16
  17. alfaris
    alfaris MOTERO TORERO
    Dec 14, 2003
    1,155
    Madrid, Spain
    got the KTM OEM 13lts MXC tank. only mounted when going to Morocco.
    yesterday i installed this graphics
    #17
  18. LILBIT
    LILBIT Ride you must.
    Oct 17, 2007
    1,675
    Lake Placid, FL
    PM me about a used small tank.
    #18
  19. JKL
    JKL Rider
    Feb 5, 2005
    742
    Vancouver Island
    I have the KTM XC tank on my 525EXC - 3.5 gal or close to it.
    It also requires a different seat.
    The fit is perfect and the gas is low.
    It is not noticably wider then the stock and it looks better then the IMS or Clarke IMO.
    The fan fits, too!:lol3
    #19
  20. alfaris
    Dec 14, 2003
    1,155
    Madrid, Spain
    yes, i have mounted also specific seat that covers the gap that shrouds leave when removed to place 13 lts tank.
    #20
