Advice on straightening a bent centre stand
Discussion in 'GS Boxers' started by notsoslow, Jun 27, 2020.
  1. notsoslow
    notsoslow Been here awhile
    Jun 20, 2006
    365
    Camperdown NSW
    My centre standis bent up on one side. I'm thinking if I take it off to straighten it I may have a problem relocating it if the pivot holes get moved slightly with the bending. Or if I leave it on the bike and use a bit of leverage, ie a long bar I may end up cracking off the frame lugs.
  2. lewisjr1
    lewisjr1 Long timer Supporter
    Sep 26, 2008
    5,679
    DC metro
    If it still works, I'd probably ignore it.
    But applying "leverage" to steel that's attached to an aluminum / magnesium engine lug seems a risky idea.
    Steel's cheap. Magnesium, not so much.
  3. Stoshu
    Stoshu Carnivorous Moronius Supporter
    Jul 11, 2004
    1,115
    Northeastern - PA
    If it isn't functional, or drives you nuts looking at it, you can always buy a used one on Ebay. Replace the bent one, then try straightening it for a spare.
  4. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    6,939
    Zer0-Zer0-Zer0-Zer0
    You may be better off to take the CS off and have it straightened, if it must be done, as opposed to dealing with it with CS on the bike. :deal
    You can have some sort of locating rod or pins through mounting holes to make sure they don't change during straightening process...
    If it still functions as it should and bike is stable when on it, I'd probably leave it as-is - ymmv... :thumb
    notsoslow likes this.
  5. notsoslow
    Jun 20, 2006
    365
    Camperdown NSW
    Thanks for the replies. There are a couple on ebay over here. That will probably be my solution. The bend makes the bike fall away from the rider as you put it on and off the stand which is why I'm after a straighter solution.
    Dale402 likes this.
  6. wellcraft
    wellcraft Been here awhile
    Aug 31, 2008
    884
    PA
    Best solution is to buy a new one or used one in good condition.
    notsoslow and Gezerbike like this.
