Advice: Pre Trip checks
Discussion in 'The Garage' started by JT.witt, Oct 23, 2019.
  1. JT.witt
    JT.witt Adventurer
    Jun 11, 2013
    18
    What’s the list of things to check before a trip and/or maintenance items to do?
    Obv tire pressure
    Oil
    Battery
    I have a 2013 KLR 650
  2. Schmokel
    Schmokel I got band for a fat joke.
    Jun 29, 2015
    17,700
    Up. And to the right.
    Fill the oil check the gas.
    :D
    After my accident, I check my luggage before I head out. Make sure there's no loose straps or anything hanging near the wheel.
  3. Emmett
    Emmett Been here awhile Supporter
    Mar 9, 2017
    414
    New Orleans
    Clean, lube, and check chain tension in addition to what you mentioned if you're going on a long trip.
    I start a packing list a few weeks before a trip, and I start organizing items early. Trips to different terrain, and at different times of yr require different camping and riding gear and perhaps different tools as well. I then use the list to "check" to make certain I've got everything I need.
    SmittyBlackstone and JT.witt like this.
  4. JensEskildsen
    JensEskildsen Long timer
    Mar 24, 2009
    2,244
    Denmark
    Depends on the trip i guess.
    I do my maintenance when I get home from a trip/riding, so the bike is ready to ride at any time.
    I know what remaining life I can expect out of my tires, chain/sprockets, brakes ect. Thats goes a long way. I always start with a fresh airfilter, and usually pack spares.
  5. VX Rider
    VX Rider Long timer
    Dec 11, 2015
    5,978
    Phoenix
    Cash
    And bank cards
    Insurance/tow plan
  6. MotoChris521
    MotoChris521 motominded
    Aug 30, 2007
    3,182
    south west
    milk crate fasteners!
    flei and dtysdalx2 like this.
  7. dtysdalx2
    dtysdalx2 Only a matter of time.
    Aug 1, 2004
    25,289
    Moneyapolis, MN
    Check for nails and screws in the tires that haven't started leaking yet. :D
    Electrical connectors that are ready to fail (loose) and nuts, bolts ready to fall out.
    How far is the trip? Nothing if under 50 miles.
    Everything if it's over 1000 miles.
  8. shu
    shu ...
    Feb 23, 2010
    1,820
    Colorado
    Check for loose fasteners:
    Start with the smallest bolt size that you see on your bike and get out the socket and wrench that will fit. Put the tool on every bolt that size you can see on the left side, then do the right side of the bike. Look up under the rear fender and on the front wheel, same way.
    Do the same for next size up fastener until you have checked every visible fastener on the bike. Then take the seat off and do the same. Be sure to check the battery connections (clean the posts and put some dielectric grease on the posts and nuts.)
    You're not trying to make everything tighter, just making sure it's not loose. Doing the whole bike will probably take less than an hour.
    If you find anything coming loose, consider using a light/medium threadlocker on it.
    While you're at it, spray a little chain lube into anything that pivots: pegs, stands & cable ball ends.
    ...............shu
    #8
    Desce and concours like this.
  9. PunkinHead
    PunkinHead Moobless Adventurer Supporter
    Dec 10, 2005
    10,265
    Land of Walmart Shoppers
    I make sure it's 106 miles to Chicago, we have a full tank of gas, a half a pack of cigarettes, it's dark and we're wearing sunglasses.
    #9
    BluByU, Yinzer Moto and JR356 like this.
  10. RJT
    RJT Adventurer
    Oct 30, 2018
    31
    Indianapolis, IN
    Don’t forget they have SCMODS.
    #10
  11. JR356
    JR356 Long timer
    May 4, 2005
    6,973
    Way Northwest
    JR356
    #11
  12. Schmokel
    Jun 29, 2015
    17,700
    ...two bags of grass, seventy-five pellets of mescaline, five sheets of high powered blotter acid, a salt shaker half full of cocaine, and a whole galaxy of multi-colored uppers, downers, screamers, laughers... and also a quart of tequila, a quart of rum, a case of Budweiser, a pint of raw ether and two dozen amyls....
    #12
    CopyCat likes this.
  13. BluByU
    BluByU Long timer Supporter
    Feb 24, 2007
    1,055
    Lost in America
    Nothing worse than a dope fiend on an ether binge
    OH Ya watch out for the bats
    #13
    CopyCat likes this.
  14. Houstrom46
    Houstrom46 Been here awhile
    Dec 3, 2017
    143
    Houston
    Before we go on trips (in the cage, by plane, on the bike or whatever), Wifey brings all kinds of crap from a check list; most of that is never needed and easily obtained if the need ever arises. OP didn't mention the destination, distance or how long the trip would last. I say, don't over think it. Chain maintenance, fluids, filters, tires, all that stuff is something that should be up to date regardless if on a trip or just puttering around on weekends. If going remote in the sticks 30, 50, 100 miles from civilization for a long period of time, then yes there are some things to account for. If the tires were previously aired down for off road, then I would ensure they were pressured to my needs for the trip. Aside from that, gas & go. Good luck, and have fun..
    #14
  15. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    8,320
    below the sea
    The only maintenance foible on the guzzi is one of the rear lamps vibrates itself to death every few thousand miles. The only bulb that ever failed. Now we have LED's , that's fixed too. Never had a bolt come loose but the steering head races tend to loosen slightly, less than a 12th turn.
    Like several have said, my maintenance is always done. I know roughly how much fuel is in the tank, despite not having a gauge, and how many miles the tires in their current state will do. The bike tends to breathe a bit of oil. I might add 1/2 a quart in 5000miles. It's a crankcase vent thing.
    Since I got the bike in 1980, now speedo says 180,000miles although there was a time I didn't have a cable.
    I have had one alternator rotor go - shit Bosch crap, a well known failure at the time - on the very first ride abroad, I only got 80 miles. A detour to a dealer sorted that and we caught the ferry.
    Second was my fault, a shitty solder on a new throttle cable. A French agricultural engineer fixed that, wouldn't accept a drink for his time.
    A scant handful of punctures - so check your ability to deal with them. Patches and levers or worms, mushrooms and a way to inflate.
    Ditto with chains if you have them.
    A few turns of duct tape, a few feet of welding wire, some electrical wire, fuses and zip ties. I can hold in my hand all the tools to completely dismantle the bike, although I have never had to, a friend blew his head gasket. Fixed it on a campsite in Germany. Caught the bus to the guzzi shop.
    The shitty handle bar switches got swapped for Honda ones, but at home in the comfort of my front room. I find the surroundings more convivial for messing with the bike. All those tools and parts you may need, just a hand stretch away. Or at least you will know where to get them fastest.
    Road side repairwork is overrated.
    #15
  16. squish
    squish Out of the office.
    Dec 4, 2003
    9,160
    Where the Ghetto meets the sea.
    Tires (air pressure and condition)
    Oil
    Fuel
    Nuts and bolts for stuff that if it falls off the ride is done
    So that's mostly but by no means a complete list:
    Shifter
    Clutch and brake lever
    Calipers
    Wheels
    Triple clamps
    lever perches
    Windscreens
    Rotor carriers
    Sprocket carriers
    Side stand mounting bolts (my wife's Ducati is terrible about this one, they go loose all the time)
    I mark a lot of these with a small dab from a paint pen, that way I just look at them to see if they have come loose or not.
    I also check the condition of the throttle cables and clutch cables.
    Lube and check the chain, looking for tight links or if I can pull links off the rear sprocket.
    I check oil, tires, fuel and chain just about every other ride.
    I check the rest of the list at least once a month or so.
    It gets tailored to each bike as I learn about a new to me bike and what areas give me problems, and which areas are fine.
    #16
