Aerostich mini pump hot mess
Discussion in 'Equipment' started by brianbrannon, Jul 9, 2018.
  1. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    782
    Denver, CO
    It worked good for two years airing up a big KTM until in 90 degree weather the plastic piston in the compressor melted. I repaired it with a new o-ring and JB weld, not really counting on it lasting. It is smaller and lighter than the all metal ones, ymmv
  2. Tall Man
    Tall Man Priest, Temple of Syrinx
    Jul 14, 2007
    4,827
    The Occident
    Apt thread title.
    I have the same pump, and they do indeed get quite warm during prolonged running...which the instruction document does warn against.
  3. Graniteone
    Graniteone 3,2,1...Beer me!
    Jul 25, 2011
    589
    Golden, Colorado
    If this is the pump you are referring to, it has saved my bacon multiple times and keeps on chugging.http://www.aerostich.com/aerostich-mini-compressor.html The key is to not run it for super long without a break and keep it clean. For the record I keep two co2 canisters handy or a hand pump depending on the trip for the time when the mini compressor may fail.
  4. squish
    squish Out of the office.
    Dec 4, 2003
    8,341
    Where the Ghetto meets the sea.
    I've been using de box mini inflators for a long time.
    The tricks I heard early on
    Do not run them for a long time (there's virtually zero duty cycle for these things, before they overheat)
    Do not run them on the ground. I use a mini biner and a length of para cord and hang mine off the handle bar or rack
    Keep the air intake out of the dust.
    Maintain a long strain relief section of the electrical plugs
  5. lkraus
    lkraus Been here awhile
    Dec 15, 2012
    572
    Central Ohio
    My Slime pump instructions specifically say NOT to run the engine while pumping. Increased voltage = higher motor speeds = higher temperatures.
  6. squish
    Dec 4, 2003
    8,341
    I suspect that those instructions are for a car, and a larger car battery.
    On a motorcycle, with it's tiny battery and the typically marginal charging systems. you could run down your battery right quick filling up a tire while not running the engine.
  7. brianbrannon
    Dec 15, 2009
    782
    Denver, CO
    I wouldn't consider the time to air up a back tire "super long". The Aerostich pump with a metal piston would be ideal
  8. Exurban
    Exurban Been here awhile
    Sep 14, 2007
    722
    Wilmington, DE
    Battery size has nothing to do with it. Sounds like that pump motor does not like the higher voltages from an alternator- bike or car. Interesting that pump looks like the guts that others end up with when they strip down off the shelf compressors, only Aerostich charges a premium for it.
    For comparison, the Motopump can run for as long as you need without overheating and you can run it with or without the engine running. They point out, as a positive thing, if the engine is running, it will pump and fill your tires faster.
    #8
    davidji likes this.
  9. Manrider218
    Manrider218 Been here awhile
    Mar 26, 2018
    138
    USA
    +1
    #9
  10. brianbrannon
    Dec 15, 2009
    782
    Denver, CO
    And the Motopump is also the guts stripped out and a premium charged
    #10
  11. squish
    Dec 4, 2003
    8,341
    Yeah, battery size does have something to do with it.
    See a motorcycle battery like a YTX14BS, common larger batter for bigger bikes.
    It's a 12Amp Hour Battery.
    Where a car battery
    Say a group 24, fairly common battery
    They have about 50amps.
    A motorcycle battery has less then half the amp hour rating vs the automobile battery
    #11
  12. Exurban
    Sep 14, 2007
    722
    Wilmington, DE
    I’m well aware of battery capacity but, I reread your previous post where you suggested the instructions were intended for cars. You might be right depending which pump lkraus has. I have a small Slime pump for bikes and can’t find that language. However, he commented that
    I’m suggesting a “larger car battery” doesn’t enter into his rationale for not running the engine. I’d have to look at some specs but I don’t think alternator voltages vary all that much between bikes and cars. 13.8-14.2 more or less. So I don’t know why the instructions for his particular pump would warn against running the engine. It might be some lawyer thing and nothing to do with electrons.
    #12
  13. Johnny4x4
    Johnny4x4 Hope 2 B Cool Sumday
    Nov 15, 2010
    825
    West Valley City, Utah
    I would suggest switching to a Moto pumps Air shot.
    I put one on each bike, and have used it to top off my the tires in my excursion a few times. I have run it for about 20 minutes straight on the truck tires, never a problem.
    around the same price as the Aero stich, also comes in a bag, and I think a better connection on the valve stem.
    Just my $0.02.
    #13
  14. brianbrannon
    Dec 15, 2009
    782
    Denver, CO
    Anything with a case is too big to fit under my seat
    #14
  15. Wonger20
    Wonger20 Adventurer
    Mar 12, 2018
    97
    GA
    So scrap the bag or use it for something else? I don't understand why that is relevant if the pump fits and zero pumps with a case fit.
    #15
  16. brianbrannon
    Dec 15, 2009
    782
    Denver, CO
    It is relevant because he recommended the Motopump Air Shot and that pump has a case that makes it too big. What is not relevant is your suggestion to "scrap the bag"
    #16
