Africa Twin - Another broken rear rack
Discussion in 'Japanese polycylindered adventure bikes' started by stou, May 14, 2017.
  1. stou
    stou Been here awhile
    Jun 16, 2006
    432
    Quebec, Canada
    Yesterday I went to an off-road ride in public dirt road. Nothing extreme only public dirt road. As usual, I bring a minimum of equipment in case of flat or any other of emergency.
    Plus a heated vest for a total of 17lbs.
    On my way back, I hit a big hole. When I saw it, I put my weight at the back, pull the handlebar an passed it, no problem. But the tank bag on the rack hit my but. I tought it was simply loose on the rack. So I stoped to check. But the rack was broken.
    I never went down or crashed that bike, there's no scratches on it. I always carried that kind of stuffs when I go off road. On my previous adventure bikes, I carried a lot more stuffs like camping gear in more heavy conditions and never had any problem. On my GS1200, I did the White rim in Moab whit all the camping gear on the rack and I did heavy off road riding with my KTM 990R with more stuffs on the back and never had any problem.
    I'll go to the dealer tomorrow to see what they think about that and see if I can have it covered by the guarantee. This is an adventure bike, not a scooter. We need to cary some stuffs when we go in remote area.
  2. dduelin
    dduelin Prone To Wander, Lord, I Feel It
    Oct 17, 2006
    2,822
    Shaft City
    At least the fork stanchions did not come apart.
  3. Benjah
    Benjah Been here awhile
    Jun 22, 2010
    335
    Christchurch, New Zealand
    Yikes, that shouldn't happen...
    Manual states max rear load is 10kg on the rear rack, so you were not outside the design parameters. The bike should certainly be built to handle the odd big pot hole while carrying gear. Perhaps there was a flaw in the plastic or maybe the basic design is lacking.
    Personally, the rear rack doesn't look that strong to me and there is quite a bit of flex when you push on it. This is why I strap my tail bag to the edge of the seat when I go off road.
    Good luck with the warrantee claim.
    9Realms, neanderthal and ya(x2) like this.
  4. jsb223
    jsb223 ADV Rookie
    May 18, 2006
    1,752
    Waco, Texas USA
    that's uncool...
    you would think with all the rear rack extension plates available for adding
    area to tie down stuff that if it was a design flaw that more people would
    be seeing the same failure.
    So I hope your dealer can warranty claim it for you.
    add on's like this would make the problem much worse.
    https://touratech-usa.com/Store/Zega-Pro-Topcase-Rack-Honda-Africa-Twin-CRF1000L
    taking another look was the edge of your add on plate touching the area that is just above the taillight?
  5. tremor38
    tremor38 Long timer
    May 30, 2006
    2,163
    Japan
    S10s had problems with the earlier racks, so Yamaha added steel reenforcement. AT rack looks like it could use that for insurance.
    **Please bring to your dealer. I'd hate for any home remedy to slow down the changes Honda needs to make**
    Sent from my SC-02H using Tapatalk
  6. Bhart89
    Bhart89 Long timer Supporter
    Nov 12, 2013
    1,294
    Indianapolis, IN
  7. ya(x2)
    ya(x2) Long timer
    Mar 6, 2016
    1,958
    Occitanie - France.
    I've deleted the pictures with the additional curved brackets mounted (yellow strokes on the pics) ; But I believe the Holan frame's setup in its early version (with 2 crossbars + curved brackets) really helps in supporting the topbox load a bit more at least.
    My topbox is always loaded with :
    - A long U-LOCK and a rotor lock (quite heavy).
    - One of my two toolboxes which is relatively heavy (more than stou's one as per the picture).
    - Tyre repair spray and many other things for a total weight over stou's package configuration.
    From the beginning, I've been very suspicious about this ABS rack and the very flexible side stand also btw. But so far so good and I have ridden (as a normal rider) on really destroyed tracks in Greece and in France including repeated bumps both wheels well off the ground...
    @jsb223 : Already said that in the AT owner's tread. 2 ATs travelling the world have already ridden from Europe across the stans and Mongolia with Touratech topboxes well loaded, no issue. And if you look at threesomewithtwins, you'll see they are not reckless but not careful neither, normal riders who like to have fun so they are not afraid to use their bikes for what they've been build for. They've broken rear wheel bearings several times, GPS crossbar's weldings also several time but no issue at all with the rack.
    It really depends on the context and how hard ones rides or how unlucky he is not to avoid a big pothole or bump but it seems stop rode under normal conditions within the load specs... We've also seen on this forum oem wheels bent over potholes so sh... happens unfortunately.
    Anyhow @stou, good luck with the warranty claim. Could be a rack defeat and I hope Honda will support you.
    davyjones, 9Realms and MrKiwi like this.
  8. tremor38
    tremor38 Long timer
    May 30, 2006
    2,163
    Japan
    A stainless steel replacement (aftermarket) is available. It looks way stronger then the plastic OEM rack, so at least there is a good option. Link below:
    http://advrider.com/index.php?threads/1171785/
    #8
    davyjones and stou like this.
  9. Mrob
    Mrob Been here awhile
    Jan 23, 2016
    597
    N. VA
    I have a Outback Mototek rear rack but still put my tail bag on the pillion seat as well when riding off-road. 2 gallons of gas in a Rotopax (13 lbs.) is about all I'm willing to put on that rear rack.
    #9
  10. stou
    Jun 16, 2006
    432
    Quebec, Canada
    #10
  11. stou
    Jun 16, 2006
    432
    Quebec, Canada
    Maybe! See those pictures of the broken parts. Both side are broke in the very same way.
    By the way, the small plate I did on the rack, is for a Givi mounting plate. I use a small 33 liter Givi top case to go to work down town. I ride off road with the Givi box, it's too shaky
    #11
    ya(x2) likes this.
  12. G-van drone
    G-van drone Been here awhile
    Apr 9, 2007
    181
    Fenton, MI; Shanghai PRC; Seoul ROK
    Unfortunately (or not) you do not fall under the jurisdiction of the US National Highway Traffic and Safety Administration (NHTSA) - I don't know if there is a similar government organization in Canada. If this was in the US, if the NHTSA gets enough of these reports (the issue is putting the passenger at risk because the expected use of the handles is that they maintain sufficient integrity / load-bearing capability to give the passenger a means to maintain balance, seating position, etc.), it will trigger an investigation, and in the best case (for us, not Honda) it will result in a product recall where Honda is then on the hook to provide a redesigned part or reinforcement for all bikes sold, to be sold, and possibly reimburse owners who have purchased replacement parts. Transport Canada, perhaps?
    #12
    davyjones and SmittyBlackstone like this.
  13. cjmadura
    cjmadura Been here awhile
    Mar 4, 2008
    539
    Western Oregon
    A plastic rack on an Adventure Bike is simply a cheap way out for the manufacturer. Hell, even my old bare-bones KLR had a cast metal rack with a plastic center.
    These bikes should be built with a stainless steel rack, period. I hope Honda at least replaces it for you, though I wouldn't hold my breath. Good luck.
    #13
    9Realms likes this.
  14. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,255
    日本
    But while it looks like a nice rack and a good way to get rid of the grab handles, they don't claim it's any stronger. See the post below.
    That said, I would expect it is stronger and wouldn't break suddenly without warning.
    I've only heard of two OEM racks breaking though.
    #14
  15. michaeln
    michaeln What're YOU lookin' at? Supporter
    Jul 30, 2007
    3,830
    Avery, State of Jefferson
    I'd like it if it just got rid of those stupid grab handles.
    #15
  16. tremor38
    tremor38 Long timer
    May 30, 2006
    2,163
    Japan
    Too bad Kawi didn't give the KLR a better MAIN frame. I've seen them snap like a twig.
    #16
    Sno cat likes this.
  17. cjmadura
    Mar 4, 2008
    539
    Western Oregon
    Yeah, I really don't miss the KLR :D
    #17
  18. tremor38
    tremor38 Long timer
    May 30, 2006
    2,163
    Japan
    Seeing as how they mention overloaded top boxes, I can see why they won't go down that road. ''You said it's stronger, so I went past the OEM rating and it broke'' There are always those in the crowd who will regard it as super rack and will find out 'how much stronger' when they reach the breaking point.
    #18
    SmittyBlackstone and Aces 6 like this.
  19. MrKiwi
    MrKiwi backwards & upsidedown Super Supporter
    Oct 16, 2009
    14,421
    New Zealand
    It broke where I thought this bracket might. It is unusual, but one of the reasons why I am swapping out the rear bracket for a stainless steel one. Not withstanding the caveat by the makers of the stainless steel one, once I have received it I will make further modifications to it to strengthen it. I am to travel two up and place more than 10 kgs of weight on the top bracket.
    #19
  20. twinrider
    Aug 20, 2002
    17,255
    日本
    Yeah, I understand the CYA aspect of it. Just mentioning that they don't claim greater strength.
    #20
