Africa Twin CFR1000L armor, crash protection
Discussion in 'Japanese polycylindered adventure bikes' started by daninghram, May 16, 2016.
  1. dwelds
    dwelds Been here awhile
    Jan 2, 2015
    105
    here n there
    I've heard good things about the om being tough enough not to bend on a drop. Was just watching a video of the one guy saying he pulled altriders cause he was bending them constantly. How do the heeds do with this?
  2. Sailor Jack
    Sailor Jack Been here awhile
    Mar 4, 2005
    144
    New Mexico
    Ive got the BUMOT plate on my 2016 DCT, paired up with the HEED basics- excellent combo for protection, bit of a PITA for maintenence
    briarjumper12 likes this.
  3. Yooper_Bob
    Yooper_Bob Insert witty saying here....
    Aug 31, 2005
    5,009
    Da UP, eh! (Marquette, MI)
    I had dropped my bike several times.... and once off my lift!!! The Heed bars have not budged.
    I have not gone down at speed.... thankfully!
  4. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,840
    Upper Michigan
    I use the heed bunkers and bash plate. Can not count how mainly times this bike has slid out.Lost the tail at 30 mph and bike slid on its side about 20 feet down a logging road.The workmanship is A1 and they are tough.The make filter service a pita but they do a great job and would buy again. I have cased a few rocks 2 up and skid plate has small dents but doing its job well. 20200502_154442.jpg
    briarjumper12 and b76 like this.
  5. winmosser
    winmosser UGS
    Jul 6, 2011
    1
    45N, 75W
    Can you share the $$cdn for the B&B guard? I’m in Ontario so landed cost would be similar thx. Sweet pic
  6. NSFW
    NSFW basecamp4adv Super Supporter
    Feb 20, 2007
    25,657
    Burbank CA
    finally found the time to install the right footpeg armor; took me longer to install than i initially thought since i need to find the tool to cut a notch on the adjoining headshield. you'll see it on the picture.
    b76 and Junglejeff1 like this.
  7. Easterntide
    Easterntide Adventurer
    Mar 17, 2014
    27
    Dieppe, NB, Canada
    Bash plate in polished $586 AUD
    Bash plate in black is $ 604 AUD
    Shipping to Canada is $110 AUD
    Quotes from B&B
  8. Easterntide
    Mar 17, 2014
    27
    Dieppe, NB, Canada
    100% correct on the nose being the biggest PIA! :-)
  9. SkipD
    SkipD That looks stickey
    Aug 19, 2010
    473
    Gold Coast
    I have tested stock bars a number of times on both tar and gravel and other than a respray look like new and the good thing is they are only 2.5kg with all mounting hardware and you only need to undo two bolts on the crash bars to pull side plastics off to get to air filters remoave tank etc.
  10. Olde Phart
    Olde Phart Olde Phart
    Mar 3, 2018
    642
    Land of Oro y Plata
    This is hard for me to believe (as a BSME that understands forces and strength of materials). The OEM stuff is a "light bar" for the attachment of additional illumination devices. Given the mount points and the inherent strength of these lightweight components they are no more and no less and will offer only the minimum of protection on impact.
    I went with the AltRider bars, lower, upper and mid-connecting members as well. I made my purchase decision based upon both the gauge (thickness) and bends (geometry) of the bars themselves and have dropped the girl numerous times at a stop (bad footing, gravel, uneven surfaces, etc.). No deformation and the only thing tweaked are the rubber mounted bars that get all whopperjawed from picking it back up requiring realignment by yanking in the opposite direction at steering lock. I'd like to see more about the rider that "is bending them constantly" to see what his setup or issue is. I'm very skeptical ...
    One thing to keep in mind is propagation of forces. If you have bars that are so strong that they will not deflect or deform on impact, the forces generated are then passed along to the mounting points. Do you want to bend bars that may be replaced for several hundreds of dollars or pass along the forces to bend the frame that will required several thousands of dollars to replace? Do a bit of research on energy absorbing automotive frame safety designs and then give it even more thought.
    Good gettin' bent to ya!
  11. SkipD
    Aug 19, 2010
    473
    Gold Coast
    What is this plastic bit that you remove? On the 2016 you only need to take off the two outer panels to get to the airfilters, not sure if that changed for later years. So once the crash bars are out of the way(stock bars that undo two bolts and let it drop down), its the 3 push pins (per side panel) inside front duct by the radiators 1 at the very front vertically up into the side panel and the 3 screws that fix it. If you have lots of rubber grease on the locating pins and rubber grommets it is very quick to get panels on and off.
  12. b76
    b76 Need more adventures
    Sep 1, 2009
    159
    oregon
    Here is a picture of the B&B dakar with the Camel Adv footpeg brace.
    I took a lot of material off of the camel brace and just the radius from the skid plate
    RustySpokes and NSFW like this.
  13. Yooper_Bob
    Aug 31, 2005
    5,009
    The little plastic piece under the nose.....part #7 in the diagram below. I have not tried pulling the side panels without removing this piece first....
  14. NSFW
    Feb 20, 2007
    25,657
    Burbank CA
    nice job on trimming. i have a Black Dog skid plate have not installed it back on the bike. i wonder if i would have the same fitting issue.
  15. b76
    Sep 1, 2009
    159
    oregon
    I would assume the black dog skid plate will interfere with the peg brace.
    The Altrider did too. We ended up switching it out before adding the brace
  16. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    17,946
    Tucson, AZ
    That piece is a proper bitch to get back on when you have the Denali aux light mount installed.
  17. SkipD
    Aug 19, 2010
    473
    Gold Coast
    Leave that in place, if you remove push pin 23 you will see that goes through plastic #7 and locks the side panel on (when you have the panel off you will see its a long insert from the side panel that goes into #23). When you pull out the push pin and work the side panel off (having taken out the other pushpins and screws) starting at the upper rear of the panel and work your way forward with small movements. I cant over state how much easier it makes it to use rubber grease on all the grommets and alignment pins. You also have to make sure the side panel fits over the alignment catches on the side of the headlight and air duct plastics.
  18. Yooper_Bob
    Aug 31, 2005
    5,009
    I have already done the grease trick.
    Next time I will just pull the pins out of #7 and try leaving it in place.
  19. William Wolfen
    William Wolfen Long timer
    Dec 5, 2015
    3,335
    Cypress, TX
    I've never removed that part. I've taken off the side panels and the headlight mask (#5), but never that one (#7).
  20. cantbeserious
    cantbeserious n00b
    May 12, 2020
    4
    San Francisco, CA
    hey guys, looking for some help/insight on barkbusters on a 2018 ATAS, hopefully this is the right forum. I'm wondering if this level of separation is normal for the clamps?
    I ended up having to use different hardware (still grade 12.9) as I destroyed the heads on the ones that came with the kit but everything else is normal. Let me know what you guys think, thanks!
