Africa twin "clunk" over small bumps. Bumot or center stand?
Discussion in 'Land of the Rising Sun: ADV Bikes from Japan' started by nixter, Jul 14, 2017.
  1. seancampbell
    seancampbell Been here awhile
    May 28, 2006
    778
    Gosford, NSW. Australia
    Yes, that's it.
    #21
  2. BygDaddee
    BygDaddee Where do I get a pie
    Oct 26, 2012
    6,583
    Brisbane Northside, OZ
    Are you sure the clunk isnt from inside fork ?
    #22
  3. neppi
    neppi Been here awhile
    Mar 9, 2017
    370
    Tauranga, New Zealand
    My Transalp had a similar kinda issue. Couldn't figure out what it was, until I was mocking around with the rear brakes. The brake pad sliding pin and the eyelets in the pads were all sooooo worn that they were rattling and clunking randomly. Cheap fix was to put some heatshrink tube over the pin. I was going to rebuild the brakes anyway in a little while.
    #23
  4. Copracer288
    Copracer288 How hard can it be?
    Aug 27, 2015
    65
    Bethlehem, PA
    My noise is definitely coming from "underneath me", not up front, that's why I say it's not steering head bearings or a fork issue.
    #24
    nixter likes this.
  5. King of Beers
    King of Beers Adventurer
    Mar 24, 2017
    67
    I would bet you are probably hearing the same slap noise most CRF1000L owners are hearing. I have not pinpointed the location myself, i just accept the general consensus that it is caused by the chain slapping... something...
    #25
    nixter likes this.
  6. nixter
    nixter Adventurer
    Apr 27, 2017
    90
    The slap could be my issue. Doubtful it's fork or rear spring related.
    Sent from my Pixel XL using Tapatalk
    #26
  7. atctim
    atctim Big Red Pig Farmer
    Apr 25, 2011
    45
    Pennsylvania
    The more I look and think about it, the more I think it is chain slap. The length of chain on the long swingarm is a lot of contact to contact. The chain is slapping the chain slider on top of the swingarm. I am going to have someone ride beside me and video it sometime soon. Should confirm what I am hearing.
    #27
  8. b76
    b76 Need more adventures
    Sep 1, 2009
    73
    oregon
    You are correct.
    I have the same noise. I was thinking something was wrong so I started watching it while riding (probably not safe). The noise happens when the chain slaps.
    #28
  9. bobbyimp
    bobbyimp Adventurer
    Nov 17, 2010
    81
    San Francisco
    I can live with this.........:clap
    #29
  10. nixter
    nixter Adventurer
    Apr 27, 2017
    90
    So turns out it's the Bumot bash plate. I think I forgot to use loctite on a couple spots. The noise has progressed and I can actually kick the bash plate now to replicate the noise. When I fix it I also want to see if I can modify the mounting with some rubber grommets or something.
    #30
