Africa Twin CRF1000L airflow management
Discussion in 'Japanese polycylindered adventure bikes' started by markbvt, Jul 12, 2016.
  1. xr650rRider
    xr650rRider Adventurer
    Jun 24, 2014
    52
    Cheap solution for buffeting effects, really works.
    #81
    jantomas, neepuk and slipknot like this.
  2. Benjah
    Benjah Been here awhile
    Jun 22, 2010
    349
    Christchurch, New Zealand
    I installed the MRA Vario today along with some other goodies. Took the bike for a spin and was very impressed with the reduction in wind noise and buffeting. I was really bothered by the noise with the stock screen, it absolutely did not work for me. I'm glad to report that I'm now a happy camper.
    The only problem I've found is that the screen interferes with the bars at full lock. I have the bars tilted forward from the stock position to aid with standing.
    #82
  3. mcmann
    mcmann Adventure Rider Junkie Supporter
    Nov 17, 2006
    4,552
    Jefferson, GA
    I found that adding spacers under the bottom of the tall Honda Touring screen (allowing a 2" gap at the bottom) helps reduce buffeting greatly. I ride with my face-shield open a couple inches . . . I now have a smooth airflow over my helmet. 5' 11", seat in the high position. It lowers the top of the windscreen for full view over the screen.
    #83
    oalvarez likes this.
  4. rally roo
    rally roo Total poser
    Apr 9, 2010
    865
    Smuggler's Notch, VT
    #84
  5. RED CAT
    RED CAT Bumpy Backroader
    Jun 2, 2005
    3,757
    Western Canada
    Think Madstad should build a unit for the AT soon. Tilt function far exceeds height for buffeting problems.
    #85
  6. rally roo
    Apr 9, 2010
    865
    #86
  7. jgunsett
    jgunsett Goin' Coastal
    Jul 16, 2007
    766
    Ohio NTZ - Ft. Myers, FL
    I love the Vstream on my S10, but man the Vstreams for the AT are butt ugly!
    #87
  8. jgunsett
    Jul 16, 2007
    766
    I really like this approach. What did you use for the spacers?
    #88
  9. mcmann
    Nov 17, 2006
    4,552
    Jefferson, GA
    I had extra elastomers from a PHDS (stacked 2 each side taped together). You could probably make spacers from a heavy rubber hose. I used neoprene rubber faucet spacers on the middle mount (stacked as needed).
    Progressive Handlebar Dampening System
    http://mx-tech.com/content/mounting_instructions_XTRIG_PHDS.pdf
    ktm phds elastomers
    http://www.ktmpartspro.com/oemparts/p/ktm/sxs05125203/elastomer-green-soft
    Sample PHDS: For illustration (not my bike)
    #89
    jgunsett likes this.
  10. Inniswhe
    Inniswhe Been here awhile
    Oct 16, 2005
    343
    PEI, Canada
    Anyone try the Madstad screen yet ?
    Trying to decide between mra vario , balzen brackets/stock screen , or the madstad offering.
    6'3" tall with a shoei multitec helmet. Will be installing the seat concepts rally seat before spring which will raise my noggin a little higher.
    Sent from my SM-G930W8 using Tapatalk
    #90
  11. markbvt
    markbvt Long timer
    Sep 26, 2007
    4,457
    Georgia, Vermont (that's one town, not two states)
    Update: I've now got almost 10,000 miles on my Africa Twin, including a 4000-mile trip through Labrador and Newfoundland, and thoughts of replacing the windscreen have disappeared. The cut-down one (see post #17) has worked out great for me.
    --mark
    #91
  12. Kray
    Kray Long timer
    Jul 13, 2013
    1,828
    Knoxville, TN
    Added hyperlink for post #17
    #92
  13. iammemares
    iammemares Been here awhile
    Apr 12, 2009
    327
    just picked up an AT. second ride and I determined the WS was creating some buffeting and lots of low frequency resonance. I too am the guy always riding with a short windscreen. Get me in clean quiet air and stop jacking around with all this. So it seems the 345mm tall Powerbronze sport is the shortest? I like it. But think something around 320 is best. any others?
    #93
  14. schizmoto
    schizmoto Adventurer
    Apr 3, 2014
    92
    Renton WA
    the fit and finish is quite nice. i do need my risers now though, my cycras and gps clamp bump it at full lock.
    #94
    Swen13 and mcridr like this.
  15. mcridr
    mcridr Adventurer
    Apr 16, 2007
    99
    Colorado
    Please keep us updated on your progress.
    Thanks in advance.
    #95
  16. jantomas
    jantomas Been here awhile
    Jun 8, 2016
    337
    Norway
    Even the low powerbronze leaves some noise. Running screenless is the most quiet. But it sort of defeats the purpose of an adventurebike. I recommend that you invest in the mra vario straight away. I tried a lot of different solutions myself but did not get happy in the longer run. If the vario turns out to be too hot on the warmest days I will probably ride screenless. I will try and just loosen the screws and push the screen down (or was it up?) to get it off without loosing or damaging the rubbernuts. Make sure to buy a pack of reserve nuts anyway.
    A tacky tip for reducing noise: Suck on your foamy earplugs to wet them before inserting. (But after shaping them a bit with your fingers.) Test for tighness by rubbing your fingertips fast against each other close to the ear. My finding is that whenever the plug works poorly it's because the tip was bent due to too much friction on insertation. Putting them in your mouth is tacky but nobody stops you from washing them as often as you want to. (They need some time to dry and will be very big and fluffy until the water is out.) Carrying several pairs is a good idea since unsuccessful insertation leaves a plug deformed for some time and it's better to just try a fresh one. I lost my own inhibitions after seeing a famous mc journalist suck on his.
    #96
  17. Drif10
    Drif10 Accredited Jackass
    Jun 12, 2003
    52,452
    Gates of Moscow
    Just received the Batzen screen mounts. Nicely made. Sprung for model with the gps mount, that's going to do nicely for one of my units, the other I'll mount to the bar.
    I'll follow up when tested.
    #97
  18. 1litre
    1litre In over my head
    Mar 15, 2016
    1,393
    Orangeville, Ontario, Canada
    And with pics of your mounts
    #98
  19. Inniswhe
    Oct 16, 2005
    343
    PEI, Canada
    Anyone try the madstad screen yet ?
    #99
  20. Moonchicken
    Moonchicken Wanderer
    Aug 17, 2016
    34
    Currently in T or C area of NM
    I have a madstad on now and I love it. Problem is solved. I tried the MRA Vario touring screen, the touratech screen, and every wind deflector I could find. None of them worked. I wear an adv helmet with a "beak" on it. I also tried sealing out air around the fork tubes and fairing. That did not work either.
