1. ADVRIDER Print Magazine!
    We're doing two more print magazines this year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
Africa Twin CRF1000L suspension
Discussion in 'Japanese polycylindered adventure bikes' started by uk_mouse, Jun 22, 2016.
  1. Nomadic_adv
    Nomadic_adv Been here awhile
    Oct 31, 2019
    207
    N GA
    Forgot to add that but updated the post anyway. Thanks for all your info, very informative.
    Motociclo likes this.
  2. Motociclo
    Motociclo Long timer
    May 18, 2017
    1,288
    The Hunter.
    Serviced forks. 10k km.
    To recap, i use the ATAS uppers and lowers with reg AT internals with my own valving specs and springs.
    Didn't need to run shim behind bush, clearance is much better on these fork bits.
    No visible blemishes or wear on upper tube.
    Oil colour quite good.
    Wasn't expecting to see any thing, has been many ATAS forks serviced with no noticable wear at 20k km +.
  3. William Wolfen
    William Wolfen Long timer
    Dec 5, 2015
    3,894
    Cypress, TX
    Excellent news. I hope to hear more like it.
    bbanker and Junglejeff1 like this.
  4. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    5,363
    Upper Michigan
    Excellent to know that.If mine wear out will do the same as you.Would most likely put new aftermarket internals in at same time.
  5. Motociclo
    May 18, 2017
    1,288
    The Hunter.
    Ohlins NIX30 inserts a nice option. Nitron, Touratech and couple of others offer cartridge options too.
    It is possible to convert the oem fork internals to a single function oper leg. The only downside, is for one cartridge, it is not reversible.
  6. Junglejeff1
    Oct 20, 2016
    5,363
    Upper Michigan
    Not thinking a single sided set up is a great idea in such small forks.Seem like you would be giving up a lot of flow on a set of forks that are already wanting flow wise.
  7. Motociclo
    May 18, 2017
    1,288
    The Hunter.
    No issues with flow.
    Oem valves flow plenty well enough.
    Junglejeff1 likes this.
  8. Junglejeff1
    Oct 20, 2016
    5,363
    Upper Michigan
    But if you switched to one side just rebound and one side just compression I would think that would cut your flow in half.I am guessing the one kit you mentioned does that but not sure.
  9. Motociclo
    May 18, 2017
    1,288
    The Hunter.
    All those kits do that. Don't lose anything in damping. Makes it better. Proper midvalves.
    Good base valve a must. Biggest issue is cavitation. Not being pressurised like a twin chamber fork for example.
    But can be made to work very well.
    Touratech kit is pressurised, don't think others are.
  10. NavigatorCA
    NavigatorCA Been here awhile
    Jan 15, 2015
    598
    Calgary
    The outer tubes on 2020 AT and ATAS are finally the same (surprise-surprise), just different color. In person, they look very similar to 2019 ATAS, but I didn’t compare them side by side.
    2019 ATAS
    2020 AT and ATAS
    2017 AT
    NSFW, Squily, William Wolfen and 4 others like this.
  11. gve.mcmlxxiv
    gve.mcmlxxiv 2016 Africa Twin DCT No.272
    Sep 5, 2017
    463
    Arkansas
    We solved it for them.
    MillennialFalcon likes this.
  12. Squily
    Squily Squily Supporter
    Sep 18, 2006
    2,986
    Esperance WA (Down Under)
    no no no
    you can't solve anything that's not broken and Mr Honda says it's not
  13. bbanker
    bbanker Been here awhile Supporter
    Feb 24, 2011
    574
    Beautiful NC
    It'll be interesting to see if the part is superseded by the new tube...
  14. Sailor Jack
    Sailor Jack Been here awhile
    Mar 4, 2005
    144
    New Mexico
  15. H3llbent
    H3llbent Adventurer
    Sep 7, 2019
    13
    Montreal
    Slowly moving forward with my SSS swap, next step getting the fork sprung valved and limited. Need to find an ATAS shock as well.
  16. Camel ADV
    Camel ADV Long timer Supporter
    Mar 4, 2009
    2,453
    Calgary
    It looks great John!
  17. gve.mcmlxxiv
    Sep 5, 2017
    463
    Arkansas
    Lots of 1100 footage showing the bike bouncing out of hits. Now that I k ow what I know about suspension. I would still get it but order springs and shims the same day
  18. Greg the pole
    Greg the pole There are no stupid questions, only stupid people
    Mar 1, 2011
    2,583
    Calgary, AB
    what problem?? :flush
    But to give them some credit, they are addressing the issue, and putting in better tubes..only time will tell.
    remember...ignorance is bliss.
    here's a refresher for a good laugh from the blog..
    Here’s a hilarious read from one of the Revzilla guys, when they asked Honda USA about the issue, linky here: https://www.revzilla.com/common-tread/you-needed-to-know-honda-africa-twin-dct-crf1000l
    @bbanker
    @NavigatorCA
    @Motociclo
    2017
    https://www.cheapcycleparts.com/oemparts/a/hon/58988d8887a8660f30f4c857/front-fork
    TUBE (OUTER) 51410-MJP-G51
    2019 ATAS
    https://www.cheapcycleparts.com/oemparts/a/hon/5c2fcb9987a8660b98794692/front-fork
    TUBE (OUTER) (SHOWA) 51410-MKK-D21
    2020 AT1100
    https://www.cheapcycleparts.com/oemparts/a/hon/5e3d9d8687a8660b08a1de16/front-fork-1
    TUBE (OUTER) 51410-MKS-E01
    2020 ATAS 1100
    https://www.cheapcycleparts.com/oemparts/a/hon/5e3d9d7987a8660b08a1ddbf/front-fork-2
    TUBE (OUTER) 51410-MKS-EN1
    So, parts wise, 2020 both outers almost identical.
    Guts are different from base to ATAS electronic.
    so it's def. a different part number even to the 2019 ATAS...
    bbanker likes this.
  19. Quercus petraea
    Quercus petraea Been here awhile
    Jan 11, 2019
    233
    Spain
    I'm curious about what's the 2020 outer tube diameter in its narrowest point. Or may be they just made some minnor change in the inside?
    Did you noticed that 2018 ATAS outer tubes are more expensive than 2020's?
  20. Greg the pole
    Mar 1, 2011
    2,583
    Calgary, AB
    it will taper from the bell end, and get thicker just before the lower triple. it's not contant.
    Talking to @Motociclo, if manufacturers kept the same thickness as the bottom of the tube (bell end) all the way up to the triple, flex would be reduced by x10 plus.
    Every tube manufacturer does it, to save on material.
    I didn't catch the price. I'm all spent out on tubes.. :D
