1. ADVRIDER Print Magazine!
    We're doing two more print magazines this year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
Africa Twin CRF1000L suspension
Discussion in 'Japanese polycylindered adventure bikes' started by uk_mouse, Jun 22, 2016.
  1. Motociclo
    Motociclo Long timer
    May 18, 2017
    1,288
    The Hunter.
    PM me springs your using and i will sort a solution. I will offer setips for for kjs and shock.
  2. NorskieRider
    NorskieRider Ultracrepidarian
    Mar 19, 2011
    1,778
    Minnesota
    Thanks for taking the time to help.
    Unfortunately I get the error that I'm not allowed to start a conversation with you.
    You asked for the spring rate ... unfortunately I don't have that. The previous owner put that spring on and wasn't able to tell me what it was. But I suppose that's a
    If I were to re-spring, is there a rate you'd recommend?
  3. Motociclo
    May 18, 2017
    1,288
    The Hunter.
    Thats odd PM won't play.
    Happy to help.
    Check spring for markings. Usually something marked on them.
    My reco for springs,
    Forks, 0.72.
    Shock, 10.7
  4. NorskieRider
    Mar 19, 2011
    1,778
    Minnesota
    Thanks, and with the 10.7 spring, which shim stack?
  5. Motociclo
    May 18, 2017
    1,288
    The Hunter.
    Will piece together a stack and PM you.
  6. Tgoranson
    Tgoranson 2018 Africa Twin
    Jan 9, 2017
    34
    Whitehorse, YT
    Does any one have opinions on the Andreani kits for our bikes, seems like there's not a tonne of vocal people out there with them. I'm basically l'm looking at these compared to the AK-20's and mmaaaaaaybe the FKA's (if I can stretch my budget). I have a TFX shock on order and am trying to find a fork solution that would suit me.
  7. Motociclo
    May 18, 2017
    1,288
    The Hunter.
    All varied opinions. Some love the Andr, others, think they are too harsh.
    Ohlins cavitate.
    The AK20, they will be best option in my opinion.
    Any will be better than stock. Don't be fooled into thinking huge pistons are better in every case. They have there place, but 20mm cartridge in Af Twin is plenty adequate.
    Spend the time to set them up post install.
    Plenty just buy a setup, bolt and go. Can do it, but its not going to be as goid as spending and hour, if that, riding and tuning.
  8. Tgoranson
    Jan 9, 2017
    34
    Whitehorse, YT
    Thanks for the info, I sort of figured that the AK-20s would be a bit better, from the sounds of things they actually take the time to do a bit of valving to suit the rider. I have a feeling that the Andreani's might be a bit too road oriented.
    I think I'm just having a hard time walking away from the price...
    I'm definitely going to spend time trying to find settings to suit me though. I figure there's no point spending all this time researching the different components if I'm just going to slap something on out of the box and call it good.
  9. Tgoranson
    Jan 9, 2017
    34
    Whitehorse, YT
    Pulled the trigger on the AK-20's today. Even though they ended up being about $400 more than the Andreani I think they will suit me better. The reports on Andreani seem to be related to high speed compression. Living in the Yukon, the roads can be pretty rough at times, and the off-road sections are usually very rocky, I think the AK-20's will be better suited to dealing with this. Once both these and my TFX shock show up I will try to remember to put a report in this thread for them. But I will wait for both ends to show up before mounting them, I already have a test ride route planned.
    97707 likes this.
  10. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    19,009
    Tucson, AZ
    That's all well and good but, you need to start posting some pictures of you and your bike out and about that beautiful part of the world.
  11. swimmer
    Oct 9, 2007
    19,009
    Tucson, AZ
    97707 likes this.
  12. Tgoranson
    Jan 9, 2017
    34
    Whitehorse, YT
    No new pics from this year yet, I have a few from the last couple seaons but we had a record breaking year for snowfall and it's taking a while for the trails to clear up. I've only been out for a couple road rides so far this year.
  13. Snakeman99
    Snakeman99 Adventurer
    Mar 30, 2008
    91
    Tucson, Arizona
    Replacing my front fork springs today with Cogent units. After draining the old stock oil, should I add a bit of fresh oil and drain a second time to help flush out the old stuff before I add the final clean amount? The old oil did have a bit of "sheen" to it but not too bad ( after 7,000 miles).
  14. Big Willy
    Big Willy Gen. Italia
    Nov 28, 2008
    5,239
    Sunshine Coast
    Me personally...I would take them apart and give them a thorough clean. A new set of seals wouldn't hurt either
    PistolPetey likes this.
  15. mentolio
    mentolio King of the island of unwanted toys...
    Jul 14, 2016
    1,322
    if you have the fluid to spare, go for it. Understanding that most of your “junk” will likely be piled up in corners and the bottom, so your fluid won’t likely ever look “truly clean” until you break them down and clean them out. You oil doesn’t look terrible, if I were you and I wasn’t looking to pull them all the way apart, I’d probably just add clean fluid and roll with it.
  16. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    5,363
    Upper Michigan
    If not to nasty I flush with cheap atf.If nasty I pull down for a cleaning.Yours don't look to bad.
  17. Snakeman99
    Mar 30, 2008
    91
    Tucson, Arizona
    Thanks, I ended up adding another 30ml of new oil to help flush out additional residue. It came out pretty clean the second time.
    Junglejeff1 likes this.
  18. Snakeman99
    Mar 30, 2008
    91
    Tucson, Arizona
    uh-oh...
    When I assembled my forks I didn't check to make sure the height from the lock nut top surface to the end of the threaded damper rod measured 10.5mm. Is this a critical distance? I'm wondering if I should take them back off and double check. I seem to recall one of the nuts being spun down on the damper rod to a distance > 10.5mm
  19. Motociclo
    May 18, 2017
    1,288
    The Hunter.
    If you screwed fork cap all way on, you'll only get about 1.5 turns from rebound adjuster.
    I never bother with the 10.5mm, make sure rebound adjuster is full anti clock out, then turn in 3 to 3.5 turns, make sure nut on rod is all way screwed down, screw on fork cap until it just seats on the needle, then nip up lock nut to cap and test adjuster range is in the 3 to 3.5 region.
    I'll get back to you today about PM.
    Snakeman99 likes this.
  20. Snakeman99
    Mar 30, 2008
    91
    Tucson, Arizona
    I ended up taking them both off and adjusted the lock nut to the recommended 10.5mm. I was just about right on one, but the other was WAY off and only had about 1 turn of rebound adjustment.
