Africa Twin Farkle Fest with Pictures
Discussion in 'Japanese polycylindered adventure bikes' started by NoVa Rider, May 26, 2016.
  1. Aces 6
    Aces 6 Whiskey Tango Foxtrot, Over
    Mar 10, 2009
    4,816
    CONUS
    Getnout, misterk, mike54 and 5 others like this.
  2. BlackDogCycleWorks
    BlackDogCycleWorks Been here awhile Super Supporter
    Oct 28, 2014
    900
    Sandpoint, ID & Mulege, Baja
    Getnout and Aces 6 like this.
  3. soren_dk
    soren_dk Long timer
    Jul 17, 2008
    1,895
    Denmark
    If you were in doubt that the AT is Japanese -- try adjusting the rear preload .... I've had to ride by the local hospitals neonatal department to ask whether they had new-born dwarfs that could give me a hand
    motocopter, Honda-50 and pepebayeta like this.
  4. PistolPetey
    PistolPetey Been here awhile Supporter
    Dec 17, 2009
    289
    Wild West BC
    I've got the SW Motech skid plate, and I used to run the SW Motech crashbars, but like you, I sustained case damage on rock/gravel nap. I removed the SWM crashbars and put on the full Altrider crash bar set, and modified the SW Motech skid plate to fit (angle grinder).
    After several drops, the Altrider bars are doing their job very well. No further damage, and the bars haven't deformed thus far.
    The SW Motech bars are just fine for dropping your bike on tarmac, but as soon as there's uneven ground and protruding rocks, the engine is vulnerable.
    gve.mcmlxxiv likes this.
  5. soren_dk
    soren_dk Long timer
    Jul 17, 2008
    1,895
    Denmark
    What is your sag?
    I'm scratching my head here setting the read preload. Following this advice: advpulse
    Even with max preload (full clockwise), I'm getting ~8cm (~3.1 in) loaded sag when I sit on the bike -- i.e the difference from extended sag on the center stand to loaded sag (measured from the read axle nut to a point on my pannier frame).
    I.e I cannot get the recommended sag of 1/3 the total spring travel of 6.6cm (~2.6in).
    The weight of the bike alone (balanced upright, off the side stand) it sags about 5cm (~2in).
    I'm not an Italian sized boy, but I'm not that chubby (105kg = ~230lb) ... am I?
    Does that sound right to you? Does your AT sag 2 inches from its own weight alone, with max preload?
  6. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,648
    Upper Michigan
    Found the same on my bike.Springs are pretty much a joke on this bike.put a a 10.4 or 10.6 kg on back and .72 or .82 in fork.Springs in fork also progressive but they are way to soft in beginning of travel.
    Getnout and soren_dk like this.
  7. advdoctor
    advdoctor Been here awhile
    Sep 18, 2009
    236
    Interior Alaska
    Exact same thing.
  8. Black99S
    Black99S Been here awhile
    Dec 30, 2012
    387
    Vancouver, Canada
    Sounds right. I'm 165lb geared up and need ~25 of the 32 clicks to get proper sag.
    You need a stiffer spring on the shock - but be careful because the stock shock has pretty weak rebound control.
    I had a local shop re-value my shock and it made a good improvement.
    Had 0.75 fork springs installed and the forks re-valved too. Another good improvement.
  9. soren_dk
    soren_dk Long timer
    Jul 17, 2008
    1,895
    Denmark
    Might be worth the effort - I'll look around for shop to do it, but I'm not hopeful I'll find one here in little Denmark...
    (btw - I know it's 'rear' and not 'read' in my original post)
  10. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,421
    日本
    How'd you do that? There's a remote knob for adjusting the preload. :scratch
    The stock shock is undersprung for your weight. Maybe try a Hyperpro spring if you don't want to replace the stock unit.
  11. soren_dk
    soren_dk Long timer
    Jul 17, 2008
    1,895
    Denmark
    My hand hardly fits in the small triangle in the frame to access the remote knob. -- I ended up removing the knob and using a ratchet directly on the metal
    (not my actual hand in the picture ... just me being a drama queen)
    OneAUout likes this.
  12. gve.mcmlxxiv
    gve.mcmlxxiv 2016 Africa Twin DCT No.272
    Sep 5, 2017
    410
    Arkansas
    I love the tall narrowing effect this does visually.
    bobbyimp likes this.
  13. Merlin44
    Merlin44 XR400R & Africa Twin Supporter
    Jun 17, 2016
    191
    Spring, Texas
    Not really a farkle, but added braces to the luggage rack. Holan, I think, makes some, but only fits their racks.
    IMG_20190901_224403.jpg Made from 3/4" tubing, flattened the ends, drilled holes, painted black. Lower ends bolt to pannier bracket, and upper ends bolt to aluminum plate on luggage rack.
    Didn't have to bend them, straight pipe cleared the turn signals.
  14. 97707
    97707 Vulture capitalist
    Aug 19, 2014
    13,662
    Oregon, USA
    Has anyone tried to fit a Touratech rallyform bash plate and Alt rider lower crash bars?
    Any problem putting that together?
    Nihon Newbie likes this.
  15. motocopter
    motocopter Long timer
    Oct 5, 2012
    3,331
    North mid-TN & mid North AL
  16. Benjah
    Benjah Been here awhile
    Jun 22, 2010
    348
    Christchurch, New Zealand
    ... all depends on how tall you are.
  17. soren_dk
    soren_dk Long timer
    Jul 17, 2008
    1,895
    Denmark
    182cm
  18. Nihon Newbie
    Nihon Newbie Weirdo
    Dec 13, 2012
    478
    SLO Cal
    I have been looking for the picture for hours, but somewhere on the internets I saw a photo of an AT with that combo. I called both companies and they don't know either.
    97707 likes this.
  19. 97707
    Aug 19, 2014
    13,662
    Oregon, USA
    Thanks for the reply. I like that bash plate best, but the TT lower bars that go with it don't have the best rep. The Altrider bar sticks out more, but it seems to be stouter.
    I wonder how much trimming you'd need to do to the plate -- if any -- to get it to fit with the bars. Or maybe there's a reason they just won't go together.
    I'd get the Outback Motortek mid bars for more protection and not worry about the wraparound top bars. Maybe that complicates the package, because the lower and mid bars mount to the same points.
  20. Nihon Newbie
    Nihon Newbie Weirdo
    Dec 13, 2012
    478
    SLO Cal
    I had that skidplate on my last AT and loved it. I have the AltRider bars on my current AT and I'm like 95% sure they would be fine together, but I'm selling my AT so not spending $ to find out, lol. Even if you had to trim the plate, that's easy.
    97707 likes this.
