Always a good habit to use the kill switch to shut off the bike... this builds muscle memory for emergency situations.
I installed some SW Motech side racks and mounted up some Giant Loop Moto Trekk panniers on my AT. Pretty happy with the result. These racks come off in a just a few seconds and they don't interfere with the hardware that mounts the factory hard cases so I can change the bike from soft panniers to hard cases to no luggage at all in just a few seconds. In case anyone wonders the Racks weighed in at 9 lbs, the Moto Trekks are 5 lbs, so combined soft panniers + Racks = 14lbs. Factory hard cases were 21lbs and they mount to the bike with no racks. Some pics:
Agreed .. I only do it. With The twin due to potential acc drain etc . I'm a big fan of dirtbike submarining / water crossings , tech creek riding , Practicing Ones finger hovering over kill switch to avoid hydraulicking in event of dumping it , is a good habit ! As much as I encourage my fellow Aqua nutters , I still partake in many recoverys . !!
And yet on a couple of off road riding courses I’ve done they advise you to NOT use the kill switch on a regular basis ? Thinking being it is not designed for such regular action and the switch longevity will be compromised.
I have used the kill switch exclusively to shut off my motos for 40+ years now. Many different brands of bikes. I have experienced 0 problems with switch longevity.
Agree as the grass is green and sky is blue and the kill switch on a bike is to be used Not the same issue but thanks Yep good idea will think about doing this next time Smart move if under warranty alwayys always use the kill switch as above ... maybe just a honda thing that is safe to ignore
Standard rider training is to always use the kill switch to develop muscle memory as mentioned above.
Cusp of dementia ... Std solo riding procedure when in boondocks on a ( no kicker moto ) is shutdown with effing key . So offending , heated grips , acc lights , Nav compensator , latte machine , hair dryer ,don't suck battery dry if you go wandering off looking for yowies.
Just wondering what tubes people are running in the back? MX Store has a couple of new Bridgys but I'm a bit confused by what I see and will wait til tomorrow to question them Bridgestone 425-150/80-18 TR4 Rear Tube at MXstore Bridgestone 150/70R18 TR4 Rear Tube at MXstore Anyone using a thicker 140 tube? Mitas 140/80-18 Heavy Duty Tube at MXstore Cheers
Been running Michelin Ultra Duty 4mm tubes front & rear since new. 140/80-18 in the rear. Usually put a new tube in every second or third tyre change . I use talcum powder to reduce the friction between the tyre & tube otherwise they seem to ball up pretty badly.
Thanks mate. I think I've still got the original tube as it's a Dunlop. Was trying different methods of fitting and pinched the bastard! Probably time for a change anyway as it's 4 years old. Was trying to put the tube in the tyre and fit both together. Will go back to my old method of putting the tube in once one side of the tyre is on the rim
I run heavy duty Michelin tubes and don't have any dramas with excessive flats, but I'm a pretty steady rider … I get them from MX Store and change them every second tire change whether they need it or not. I did run ultras once , but they don't accept patches too well and are too bulky to carry as spares .
More than 20 yrs old yam XT 600 non stainless still like new. I have at 2019 so I'll see how it would go. Did 2k19 model got stainless ones ?
Reports of the AT engine to be used in a couple of new Honda models, one being a CB1100X touring model. Looks like a possible replacement for the VFR1200 Crosstourer. Also in the new Honda Rebel 1100 along with the DCT or manual gearbox. https://motorbikewriter.com/a-honda-cb1000x-could-be-in-the-works/
