Africa Twins Only - CRF1000 Engineered Enhancements
Discussion in 'Vendors' started by spartanman, Sep 3, 2016.
  1. Nikoutdoor
    Nikoutdoor Been here awhile
    Apr 20, 2013
    176
    NW Arkansas
    Here are a couple with the grab rails installed I also have the ALTrider rack extension plate on. Let me know if you'd like any more pics.
    Barron, Dave77459, mslow and 2 others like this.
  2. Kastenfrosch
    Kastenfrosch Adventurer
    Nov 16, 2016
    74
    Germany
    Thanks a bunch, Nik.
    Nikoutdoor likes this.
  3. tremor38
    tremor38 Long timer
    May 30, 2006
    2,163
    Japan
    Looking good!
    Sent from my SC-02H using Tapatalk
  4. tremor38
    tremor38 Long timer
    May 30, 2006
    2,163
    Japan
    How well are the rotopax mounting holes lining up?
  5. Nikoutdoor
    Apr 20, 2013
    176
    NW Arkansas
    They do not you'd have to drill them through the ATO rack if you wanted to use it with the Altrider plate. The ones on the ATO rack are aft of the ones on the Altrider plate. The back hole on the Altrider plate is where the letters ATO is laser cut. 14970488920051688757338.jpg 14970490498071392462510.jpg
  6. Nikoutdoor
    Apr 20, 2013
    176
    NW Arkansas
    I also had the mill out clearance for a strap to fit under the plate on the forward strap hole on the Altrider plate so I could use the center strap on my Mosko Motors R 80. Sorry for the grainy pix I did not have good lighting!
  7. tremor38
    tremor38 Long timer
    May 30, 2006
    2,163
    Japan
    Very good info. I was wondering about that as well. Thanks.
    I suppose another option to the loop slot access would be to add spacers between the racks?
  8. Nikoutdoor
    Apr 20, 2013
    176
    NW Arkansas
    Yeah you could add spacers but then you're not distributed in the weight as evenly on the ATO rack. I'm sure it'd be strong enough just not as strong as if it's mounted flush. But if you don't have the means to mill it out spacers would be a lot easier.
  9. chrshale01
    chrshale01 Adventurer
    Jun 1, 2017
    97
    Maybe future racks should accommodate this?
    Sent from my HTC 10 using Tapatalk
  10. tremor38
    tremor38 Long timer
    May 30, 2006
    2,163
    Japan
    For sure. Probably my reluctance to mod a brand-new, shiny SS rack, but once the newness wears off practicaliy will no doubt take over.
  11. Nikoutdoor
    Apr 20, 2013
    176
    NW Arkansas
    I think it'll be hard for them to accommodate all the different aftermarket extension plates and their features. They did make sure that they would be able to mount any of the aftermarket extension plates using the OEM hole spacing.
    Barron likes this.
  12. Nikoutdoor
    Apr 20, 2013
    176
    NW Arkansas
    I did not mod the ATO rack I modded the Altrider plate the aluminum is a lot easier to mill than stainless steel it's also a lot thicker and cheaper if you miss it up.
  13. chrshale01
    Jun 1, 2017
    97
    As I understand it, the impetus for the racks was to accommodate mosko moto reckless 80's?
  14. chrshale01
    Jun 1, 2017
    97
    OK. Sorry for my misunderstanding.
  15. chrshale01
    Jun 1, 2017
    97
    And yes. I'd rather mill aluminum than steel too.
  16. Nikoutdoor
    Apr 20, 2013
    176
    NW Arkansas
    Yes it accommodates the R 80 great without an extension plate required. And you are right that was the whole idea behind this design.
    chrshale01 likes this.
  17. Nikoutdoor
    Apr 20, 2013
    176
    NW Arkansas
    Yeah it was enough of a pain just to oversized the holes that didn't line up on the front of the rack.
  18. tremor38
    tremor38 Long timer
    May 30, 2006
    2,163
    Japan
    Doh, my reading comprehension gets an F today. Agreed.
  19. Nikoutdoor
    Apr 20, 2013
    176
    NW Arkansas
    As far as the rotopax goes you'd have a choice if you wanted to do drill the Altrider plate or the ATO rack to match the other one if you drilled the plate you would have extra set of hold on top that we're not all the way through. I guess the same is true on drilling the ATO rack but you wouldn't see the holes because they be on the bottom.
  20. spartanman
    spartanman regret minimizer
    Oct 17, 2009
    2,484
    Land of High Hopes & Low Taxes
    Thanks, mslow, we truly appreciate the feedback! Glad it worked well for you. ^^^My new screensaver!^^^
