Africa Twins Only - CRF1000 Engineered Enhancements
Discussion in 'Vendors' started by spartanman, Sep 3, 2016.
  1. MrKiwi
    MrKiwi old enough that I should know better Super Supporter
    Oct 16, 2009
    16,180
    New Zealand
    Yeah, I need the room. But the ATO rack is good.
  2. MrKiwi
    Oct 16, 2009
    16,180
    New Zealand
    OK more pictures, not very good but hopefully you will see why the Givi under top plate support brackets will not fit.
    ATO rear rack fitted
    Givi support bracket
    The problem
    But as I have noted, I'm not worried. The ATO construction is so much stronger in this area than the OEM rack.
  3. ripping r
    ripping r Lost
    Feb 28, 2016
    447
    Earth
    well got my ato rack today! got lucky got off work early. well I was trying. and it showed just after getting home. looks great not sure if I want to keep the bare or power coat it. being ss I know it wont rust. but blue or red might look better. rack.jpg
    LastOutlaw, MrKiwi and chrshale01 like this.
  4. Bike Guy
    Bike Guy Long timer
    May 20, 2005
    1,044
    sierra foothills, hwy 49
    Not necessarily. S/S will rust and also magnetic. Depends on what ya buying for the job. I ordered specifically for the job.
  5. C.J.
    C.J. Sierra Nevada Rider
    Jan 4, 2005
    245
    Shingle Springs
    Added SW Motech rack on it today. I ground the spacers down to sit flat instead of drilling out the ATO rack. Drilling SS is no fun. Now I can hold my cold Sierra Nevada. That is a Mosko Back Country 30 in the front, I carry tools and tire stuff in it and can expand it greatly. [​IMG][​IMG][​IMG][​IMG]
    Sent from my SM-N910V using Tapatalk
    spartanman and MrKiwi like this.
  6. ripping r
    ripping r Lost
    Feb 28, 2016
    447
    Earth
    I got it just to make the bike look better. I hate the looks of the stock rack.
  7. tremor38
    tremor38 Long timer
    May 30, 2006
    2,163
    Japan
    Never understood when people feel compelled to inform that ''SS will rust.'' Eeeyaaa, but the difference is night and day between that and say mild steel. Much less attention needed. Equipment I maintain is in a marine environment and SS makes corrosion control SO much easier. We're talking about the difference between very light surface rust vs exfoliation, but yeah, bettter not even bother because ''stainless will rust.'' What a completely pointless position to take.
    Sent from my SC-02H using Tapatalk
    ripping r likes this.
  8. spartanman
    spartanman regret minimizer
    Oct 17, 2009
    2,444
    Land of High Hopes & Low Taxes
    304 stainless steel is highly corrosion resistant -- it won't rust itself but can if ferrous materials become embedded in it during machining or grinding. 304 is non-magnetic.
    MrKiwi, ripping r and chrshale01 like this.
  9. ripping r
    ripping r Lost
    Feb 28, 2016
    447
    Earth
    great to hear. ill go with my first idea. and run it as is. tell I pick a color.
    and being in very hot and dry az not like I have much to worry about.
  10. Mr. Fisherman
    Mr. Fisherman Back in Black!
    Oct 8, 2006
    12,877
    Trying to tame the Snake!
    Anyone have the link to the install video?
    I looked but couldn't find it again.
    Maybe it could be added to the first page?
  11. spartanman
    Oct 17, 2009
    2,444
  12. Mr. Fisherman
    Oct 8, 2006
    12,877
    Just came back here to post that. Thank you.
  13. chrshale01
    chrshale01 Adventurer
    Jun 1, 2017
    97
    It's on on p. 19 of this thread.
    Sent from my HTC 10 using Tapatalk
  14. Mr. Fisherman
    Oct 8, 2006
    12,877
    Has anyone mounted one of these on a 2017?
    I am going to look closer in the morning but right now mine doesn't look like it lines up. The front two bolts are much wider and the rear two are studs with nuts, not bolts.
  15. spartanman
    Oct 17, 2009
    2,444
    The ATO rack has been installed on several 2017 ATs. The OEM rack and attachment hardware are the same for 2016-2017.
    2017: http://www.cheapcycleparts.com/oemparts/a/hon/58988d8387a8660f30f4c806/side-cover-rear-carrier
    2016: http://www.cheapcycleparts.com/oemparts/a/hon/5702d20c87a8660f4c83bdad/side-cover-rear-carrier
    chrshale01 likes this.
  16. Mr. Fisherman
    Oct 8, 2006
    12,877
    Email sent with pics to Larry. Please respond ASAP.
    Sent from my SM-G930P using Tapatalk
  17. Mr. Fisherman
    Oct 8, 2006
    12,877
    19 and 20 in the 2017 diagram are incorrect.
    Not the first time this models documentation was not accurate.
    See this...
    Those are studs, not top down bolts.
  18. C.J.
    Jan 4, 2005
    245
    Shingle Springs
    Its a tight fit up front on them two. Take your time, use anti seize on all the bolts. If needed you might drill them out a bit but it is stainless, never fun to drill.
  19. C.J.
    Jan 4, 2005
    245
    Shingle Springs
    Looks like studs from hoop supports are pushing rack forward. Get under fender and beat that thing straight. :D
  20. Mr. Fisherman
    Oct 8, 2006
    12,877
    Got it figured out. I had to spread the bottom tabs for the 10mm bolts. It was hitting one side.
    Danielkoh81 and arrcrussell like this.
