aftermarket speedo wiring
Discussion in 'Airheads' started by arbalest, Jul 8, 2021.
  1. arbalest
    arbalest Long timer
    Mar 19, 2009
    1,410
    Windham, Maine
    Does anyone have an airhead (/6) wiring diagram for Acewell or Trail Tech (Vapor) speedo?
  2. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    8,889
    if the bike has an electronic tach the signal wire is black coming of the coil. the other black wire is coil trigger. but I would go to the aftermarket tach diagram and work backwards, if that is any help. if you do not have an electronic tach you will need a sender.
    Edit: for some reason I thought you were talking tachs. if I am correct, there were no electronic speedos. so the only wiring is the light.
  3. Kiwiabbo
    Kiwiabbo Long timer
    Apr 16, 2014
    1,494
    Taihape New Zealand
    74C1E69A-20D4-4EDA-9A20-CDD00B1C4068.jpeg I put an ace well on mine, just followed the wiring diagram as supplied and checked against the stock one. Can’t say I had any issues at all. That was on an acewell....
  4. Arktasian
    Arktasian "I know nothing!"
    May 23, 2014
    2,185
    BC
    ^ I’ve had good service with MTX L
