air box mod.
Discussion in 'Dakar champion (950/990)' started by vgstef, May 26, 2004.
  1. vgstef
    vgstef Been here awhile
    Aug 28, 2003
    197
    Canada
    I just did the ait box mod (sommer) and raise the needle on the carburator and after this mod i am having surging problem at 3000-4000 RPM. Anyone experiance this ? should I put the needle back to the original positon ?
  2. mchaskell
    mchaskell Adventurer
    Apr 21, 2004
    70
    Fresno, CA
    Did you turn out your air screws? Part throttle operation is a matter of float height and the pilot jet. I would turn out the pilot air screws 2.5 - 3 turns and see how she runs.
  3. vgstef
    Aug 28, 2003
    197
    Canada
    Yes when I lift the needle (1 clip) I also ste the idle screw to 2.5 turn out front and rear. The original setting was 1.3/4 front and 2.1/4 rear.I thing I will put the Idle screw back to the original position.
  4. Renegade6
    Renegade6 Been here awhile
    Feb 23, 2004
    854
    New Boston, TX
    Make sure your carb vent tubes (goes from each carb to the bottom of the airbox) aren't kinked.
  5. KTMax
    KTMax Ninth of the Nazgul
    Oct 28, 2003
    1,099
    Amsterdam, The Netherlands
    Yep AND if they are the uprated version of the hoses (depending on the production date of your bike)...
  6. vgstef
    Aug 28, 2003
    197
    Canada
    The vent tube for the carb are venting to the outside of the airbox. Both carb venting hose still connect with the Y connection and then the hose exit the airbox and at the end of the hose I installed a crankcase filter. Should I disconnect the Y connection and exit both hose to the outside of the airbox ?
  7. Flanny
    Flanny Flanny-it-up!
    Feb 18, 2003
    2,739
    Ottawa, Ontario, Canada, the World, the Universe
    You should be fine with the "Y". Just make sure there are no kinks.
    BTW - with the air-box more open, it is impossible that your bike should be at the stock idle jet adjustment. There is more air, and therefore, there needs to be more fuel.
  8. Renegade6
    Feb 23, 2004
    854
    New Boston, TX
    Try running it without the crankcase filter.
    #8
  9. Flanny
    Feb 18, 2003
    2,739
    #9
  10. vgstef
    Aug 28, 2003
    197
    Canada
    I remouve the carb and set the idles screw to 1 7/8 for the front and 2 3/8 for the rear. The original position was 1 3/4 front and 2 1/4 rear. This set up work good the flat spot is gone. I also try 2 1/2 for each carb and the bike did not like it.
    #10
