Air compressor suggestions
Discussion in 'The Garage' started by Stroked 550, Feb 8, 2021.
  1. Stroked 550
    Stroked 550 Dirt Nut
    Nov 24, 2009
    2,267
    Outhere
    hey guys
    Im looking for an air compressor I can hookup to my batteries to fill up my 35s on the jeep and other large tires on my trucks
    What do you guys recommend?
  2. andynj
    andynj Been here awhile
    Jul 9, 2013
    516
    Stroked 550 and monkeydad like this.
  3. MrPulldown
    MrPulldown Long timer
    Aug 18, 2009
    8,793
    Truckee
  4. Stroked 550
    Nov 24, 2009
    2,267
    Outhere
  5. Stroked 550
    Nov 24, 2009
    2,267
    Outhere
  6. jb882
    jb882 13HP of fury.
    Aug 5, 2014
    1,314
    Peoples republic of Taxachusetts
    A friend of mine has the biggest viair unit for his 5th wheel rv. Has no issue inflating those tires to 110psi and it does it fast. The big thing with the one he has is the 40 min run time before you need to let it cool.
    https://www.viaircorp.com/portables/450p-rv-auto
  7. roger123
    roger123 Long timer Supporter
    Jun 23, 2007
    2,467
    VA Beach, VA
    Viair user here, just get the one sized for your needs, plenty of options.
  8. Nailhead
    Nailhead Inclusion Rider
    Apr 6, 2003
    11,088
    Longmont, CO
    Got a Viair 450 years back, and have zero complaints, especially with its 100% duty cycle. It fills truck tires (285-17) fast, and car tires so fast I really have to keep an eye on my gauge.
    #8
  9. jasonmt
    jasonmt Long timer
    Sep 20, 2011
    1,241
    Alberta, Canada
    I will be a contrarian and say I would (and have) went this way, similar price to a Viair 450P-RV:
    #9
  10. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    7,566
    i don't buy cordless anything anymore. the batteries go bad in a few years then you need to buy another one. if the vehicle has a battery (and alternator) that will be better.
    #10
    AtlantaViking likes this.
  11. spurcap
    spurcap Adventurer
    Feb 7, 2020
    41
    NJ, USA
    Best possible option for on vehicle air is using a belt driven compressor (aka AC compressor). this fills fast and bonus you can use air tools. assuming you don't want to sacrifice AC this involves getting a 2nd compressor, building a custom bracket and getting a larger v-belt.
    After this the decent electric compressors work ok. I can't remember the specific one I used but if I aired down 35s to single digit psi it would take about 5 mins a corner to get back up to highway psi. maybe there was a more powerful one I could have got though.
    #11
  12. ydarg
    ydarg Miscreant
    Nov 11, 2015
    2,369
    Above the Equator
    You have to find an internally lubricated compressor such as an old York for that. Any modern (as in anything built in the past 30 years) vehicle will use a compressor which circulates the oil with the refrigerant that is not suitable for air compressor duty.
    #12
  13. spurcap
    spurcap Adventurer
    Feb 7, 2020
    41
    NJ, USA
    You jogged my memory and are indeed correct. I was looking at an Old York when considering this approach for on-board air.
    #13
    ydarg likes this.
  14. jb882
    jb882 13HP of fury.
    Aug 5, 2014
    1,314
    But its giant compared to the Vair and not really something you would want bouncing around in the back of a jeep when you are off roading.... Then the is the batteries, unless you have a way to charge them away from the house you only have so much time you can use it. Those batteries are not cheap so having extras will be costly.
    #14
  15. Astronaut Jones
    Astronaut Jones Been here awhile
    Apr 17, 2010
    141
    NV, MN
    #15
  16. foxtrapper
    foxtrapper Long timer
    Sep 6, 2011
    4,886
    Presume you want to air up out in the wild or such?
    No specific recommendations, but you can find many interesting comparison tests/reviews of portable 12 volt compressors online and on YouTube. None are going to be as fast as a big tank of air from the shop compressor. But there are some surprising differences between the little 12 volt compressors. Orders of magnitude differences in fact.
    #16
    Stroked 550 likes this.
  17. spurcap
    spurcap Adventurer
    Feb 7, 2020
    41
    NJ, USA
    If speed is of the essence and storage space is not, another option is to get a sufficiently big air tank such as https://www.harborfreight.com/air-t...r-tanks/5-gallon-portable-air-tank-65594.html. (Never tried this tank so not saying this is big enough for your application but could work out the math based on PSI of tank/volume of tank/volume of tires needing to be filled).
    You can fill to high PSI with you shop compressor before you go and allows for speedy refilling after you air down the tires. Combined with a 12V compressor could also allow you to compress air when time permits (i.e. while sitting at camp) rather than when you are sitting at the side of a highway waiting to air up to drive home. If doing this though need to be aware of the output of your compressor/size of tank/duty cycle as a massive air tank to fill combined with a low cfm 12v compressor with a weak duty cycle will end up with a bad result.
    EDIT: Running the math, I expect this would work for filling a little but is unlikely to get you anywhere close to filling 4x 35" tires from say 10 psi to 30.
    #17
  18. jb882
    jb882 13HP of fury.
    Aug 5, 2014
    1,314
    I am not sure that having a pressurized vessel potentially bouncing around in the back of a jeep is a good idea. I know 150PSI or so does not seem like much but when a compressor tank with 120-150psi in them ruptures it can be incredibly destructive and can take off like a short term rocket if you knocked a fitting off.
    #18
  19. Stroked 550
    Nov 24, 2009
    2,267
    Outhere
    yeah im looking to air up out on the trails thanks thats a good idea I will check out youtube
    #19
  20. motoman12
    motoman12 Adventurer
    Oct 1, 2018
    60
    texas
    Instead of one supersized, have you considered 2 regular duty pumps assuming you have more than one plug in? I understand about the heat cycle (you have to add about 2-5 lbs more on each tire after the first since the air is so hot and will cool down a few psi. This could be a way to save time and money.
    #20
