Air Filter Talk
Discussion in 'Parallel World (790/890)' started by truckergemi, Dec 10, 2019.
  1. truckergemi
    truckergemi Been here awhile
    Nov 14, 2019
    131
    Texas
    Guys, I need air filter advice. I’ve put 400 miles on my new R and really should be switching to a better filter already. What does everyone here use?
  2. Radzz
    Radzz Been here awhile
    Jul 27, 2009
    132
    Denmark
    Guglatech... works perfectly . I´ve been using now for 10,000kms in plenty of dusty conditions. Catches everything and it´s easy to clean :-)
    guglemonster, chain and Vargubau like this.
  3. truckergemi
    Nov 14, 2019
    131
    Texas
  4. ShaftEd
    ShaftEd Long timer
    Nov 6, 2001
    4,002
    San Diego, CA USA
  5. Bluetonguejak
    Bluetonguejak Pretend racer
    Sep 16, 2009
    3,086
    Gippsland
    If going into dusty conditions with a Unifilter filter(Not the Aussie one),then liberally oil the (pre-oiled)element and grease the sealing faces as fine dust WILL get through otherwise:nod:deal
  6. chain
    chain Go Fly Supporter
    Aug 28, 2002
    4,829
    Central IL
    Thanks! I’ve been hunting for a serviceable air filter for this little monster. Ordered.
    Someone in the US needs to stock these
    guglemonster and Radzz like this.
  7. truckergemi
    Nov 14, 2019
    131
    Texas
    What kind of grease?
  8. ramirin
    ramirin Ready to push
    Mar 25, 2008
    1,059
    FIN
    Is there something proven wrong with Ktm 'offroad' filter (63506915000) or why you guys are looking for alternatives?
    #8
  9. AdvRonski
    AdvRonski They call me......Ronski
    Feb 4, 2007
    1,435
    Finally made it to Fruita!
    Apparently, the KTM PP filter has the filter foam encased behind screen on both sides, making it hard to service, where the Uni-Australia filter allows the foam to be removed for easier cleaning. The problem I've found with the Aus-Uni is that when it does get very dirty, it will allow dirt to pass around the edges of the foam elements, and right on into the engine intake valves. This is why I'm waiting for 4 new intake valves for my 790 right now, as they seem to be on backorder. I'm switching to the Guglatech air filter for now, but with the air intake snorkels in the dirtiest area of the bike, and the small filter size, I'm really hoping Triple Clamp Moto comes up with a better solution.
    #9
  10. truckergemi
    Nov 14, 2019
    131
    Texas
    I think I’m going to give the Uni Australia filter a try. Wish me luck!
    #10
  11. AdvRonski
    Feb 4, 2007
    1,435
    Well, OK, but you might want to reconsider.
    Here's where the dirt made it around the edge of the filter foam.
    The evidence of dirt infiltration is spread pretty evenly around the filter frame, making me wonder how much dirt makes it right through the middle of these relatively thin foam elements.
    #11
    lithodave, guglemonster and DRglidarn like this.
  12. Radzz
    Jul 27, 2009
    132
    Denmark
    #12
    guglemonster likes this.
  13. truckergemi
    Nov 14, 2019
    131
    Texas
    Well you just freaked me out enough to email about cancelling my order.
    #13
  14. truckergemi
    Nov 14, 2019
    131
    Texas
    Is there an American supplier for the guglatech?
    #14
  15. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,174
    SC
    What was wrong with the valves? Definitely looks like some oil was coming down the guides on a few.
    #15
  16. Bluetonguejak
    Sep 16, 2009
    3,086
    Gippsland
    Similar to @AdvRonski experience with the Oz Uni Filter, the PP Unifilter can allow dust (and fine grit) past the seal and through the element itself.
    The Oz Uni filter foam element is easily carried and replaced/cleaned on an off-road trip (daily when necessary in dry conditions).
    MUST be super cautious when oiling and installing the filters to get a good seal.
    The position of the intake draws-in copious amounts of dust/sand generated by the bike itself.
    #16
  17. AdvRonski
    Feb 4, 2007
    1,435
    The intake valves had zero clearance when I checked them, the faces were worn pretty badly. The exhaust valves are fine, and the seats are OK as well.
    #17
    guglemonster and Toddv like this.
  18. ShaftEd
    ShaftEd Long timer
    Nov 6, 2001
    4,002
    San Diego, CA USA
    I haven't had the issue with the Uni Oz filter that AdvRonski had, but I haven't subjected it to that heavy of an off road dusting. It's of course easy to pull and I check it regularly that no dirt is getting in the airbox past the filter that I can visually see. However, you can imagine that if the foam inserts got completely clogged, that the air will find someway pass the foam elements.
    #18
  19. Vargubau
    Vargubau Been here awhile
    Nov 11, 2014
    136
    Lyons, IL
    #19
    guglemonster and TrailTrauma like this.
  20. truckergemi
    Nov 14, 2019
    131
    Texas
    #20
