Air Filter Talk
Discussion in 'Parallel World (790/890)' started by truckergemi, Dec 10, 2019.
  1. NHktmRider
    NHktmRider Adventurer
    Oct 26, 2016
    42
    Haven’t decided which way I’m going to run it. All depends on where it hits the Canadian border in Maine, but I’m guessing it’s going to be by Ft Kent. Assuming that’s the case I’ll run N to S as well.
    #41
  2. Bluetonguejak
    Bluetonguejak Pretend racer
    Sep 16, 2009
    2,653
    Gippsland
    Got rid of this POS
    Replaced it with this..
    We need 'somebody to design a pre-filter assembly to replace the lid that eliminates the snorkles without restricting flow...:hmmmmm
    #42
    1coolbanana and braaap! like this.
  3. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,503
    Here and There
    B Bolton has suggested that the 2 drain grommets in the bottom of the airbox should be replaced with blanking grommets if riding in very dusty conditions... They've seen some dust sucked back thru.
    Maybe the blokes at Triple Clamp Moto are already looking at the prefilter idea?
    #43
  4. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,103
    NW Sydney, Australia
    The POS is the stocker?
    Sorry, havent picked mine up yet so stocking up on essential parts :-)
    #44
  5. braaap!
    Mar 16, 2005
    4,503
    Here and There
    Yeah the oem has the filter trapped in a cage, near impossible to clean properly.
    https://www.uniflow.com.au/contents/en-us/d369_KTMADV.html scroll down a bit to get to the new filter assembly, spare foams and now, snorkel prefilters.
    I was under the impression that all AU bikes either had the oem filter swapped out at delivery or unfilters shipped out following for early deliveries (like mine - and no charge)...
    #45
  6. 1coolbanana
    Aug 25, 2009
    6,103
    Bugger, already ordered filter and pre filters, never mind, if it comes with one Ill have a spare :-)
    #46
  7. Bluetonguejak
    Sep 16, 2009
    2,653
    Gippsland
    Paper filter removed on pre-delivery and replaced with foam Uni filter (Not-Oz version).
    Lots of dust got through filter and past seal (1000km service done day before ride) - KTM Aus had Air box and throttle bodies removed and cleaned, and supplied/fitted Oz Uni filter.
    Gunna keep an eye on the valve clearances and oil consumption KTM Aus will look after any associated issues.
    The Oz Uni filter is a much better fit around the Air box groove than the other Unifilter.
    I pulled the new filter and greased fuck out of the seal (although it had been greased) for piece of mind.
    #47
    braaap! likes this.
  8. Night Crawler
    Night Crawler Been here awhile
    Mar 14, 2012
    276
    Portland, OR
    Uni-not Oz? This is confusing. Anyone got a link for the good one?
    #48
  9. 1coolbanana
    Aug 25, 2009
    6,103
    The good one
    #49
  10. Night Crawler
    Mar 14, 2012
    276
    Portland, OR
    Thank you
    #50
  11. Buckeye1887
    Buckeye1887 Adventurer
    Nov 23, 2019
    34
    San Francisco
    New to this world - is this only am issue for off road riding? If I'm exclusively on road are the disposable filters fine, or should I still be looking into oiled and greased?
    #51
  12. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    9,190
    The Delta Ghetto, GA (aka PTC)
    Paper filters better than foam for onroad, no question about it.
    #52
    Buckeye1887 likes this.
  13. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,046
    SC
    I run equipment as a side hustle and it's DUSTY so here's my take on filter media. These machines are pricey and have pretty sophisticated filtration systems to keep the engines alive. But in the end it's a dual paper filter setup inner/outer primary/secondary. They filter well, probably better than anything but are slightly restrictive. I'm a fan of paper filters with outerwears material to pre-filter.
    If I go on a trip, what good is an oil bath filter that will be more or less un-cleanable on the trail without bringing a lot of crap along with to service it and spend time every day to do so? With a paper filter it can be bonded to the gasket creating a leak free joint and when they get full of crap you can simply beat the crap out of them pretty easily. It won't be clean and flow like a new filter again but it will flow just find for off road use.Who needs 95HP, 89 should do fine?
    For reference, I beat the crap out of my primary filters probably 4 or 5 times before replacement and they hold a lot of crap, at 80 bucks a pop I get what I feel comfortable with out of them. Probably a full measuring cup or more of dust/dirt comes out each time if I run it till it tells me it's clogged. the secondary filter shows no signs of material getting through either, they have always been clean when I replace them.
    It's hard to beat the convenience and reliability of a paper filter IMO and I'm not concerned with the possible 2 or 3 HP a better flowing filter may provide if it ends up being harmful to the engine.
    #53
    Venturer and Beshar like this.
  14. PowerCell
    PowerCell Manufacture Super Supporter Supporter
    Sep 28, 2005
    2,606
    Southern Kalifornia
    Our Quick Release KTM 790 Performance Rally Style Airbox is just finishing production...
    #54
    Vicresendez, kzeb, Bike Guy and 6 others like this.
  15. ramirin
    ramirin Ready to push
    Mar 25, 2008
    640
    FIN
    2D drawings? come on - tease us with some 3D instead :thumb
    #55
    kzeb and PowerCell like this.
  16. PowerCell
    Sep 28, 2005
    2,606
    Southern Kalifornia
    Now what fun would there be in that? :D
    #56
    ramirin likes this.
  17. Lill-Erik
    Lill-Erik Adventurer
    Jul 22, 2019
    26
    Sweden
    Ooh so now we have three companies making airbox solutions :thumbup Having more choices is never bad.
    #57
  18. ramirin
    Mar 25, 2008
    640
    FIN
    Who is no. 3? Anything in europe?
    #58
  19. Lill-Erik
    Jul 22, 2019
    26
    Sweden
    Rottweiler, Powercell and Trippleclampmoto from the UK :-)
    #59
    ramirin likes this.
  20. ramirin
    Mar 25, 2008
    640
    FIN
    :dukegirl I'm ready, bring it on
    #60
    kzeb, AdvRonski and PowerCell like this.
