Airhead Exhaust Threads: Alternate Repair
Discussion in 'Old's Cool' started by Lornce, Jun 5, 2007.
  1. shawn
    shawn Adventurer
    Jul 20, 2007
    29
    England
    Mine came today! possibly the most damaged threads they have been used on yet???:D
    Only put it on to try it so its only finger tight! You can see it will do the job though:clap
    #21
  2. opposedcyljunkie
    opposedcyljunkie Heavyweight Boxer
    Feb 20, 2007
    4,897
    By the Lake
    looks promising! what will you use to seal the cracked areas?
    #22
  3. shawn
    shawn Adventurer
    Jul 20, 2007
    29
    England
    I may get them welded in yet, depends on my mate getting access to aluminium welding gear. I can weld aluminium but I'm in the same situation:D BUT when you consider how far the exhaust pipes go in I think I could get away just clamping it. Given:D that I'm fitting reverse cone megas I don't think the noise will be an issue:D
    #23
  4. opposedcyljunkie
    Feb 20, 2007
    4,897
    By the Lake
    i'd seal that off if i were you. you wouldn't want to have any air leaks there, resulting in backfiring and leaning-out of your mixtures (add to that the difficulty of tuning the carbs).
    #24
  5. Ekke
    Ekke RTW Adventurer
    Apr 17, 2004
    295
    Redwood Meadows, Alberta
    I put Walter's exhaust nuts on my '89 R100GS over the winter when one of my exhaust threads was damaged. They worked perfectly but I think the nicest thing is that I can use an allen key to remove the exhaust now. That's nice when on the road...
    By the way, Moneybookers worked just fine.
    #25
  6. Zebedee
    Zebedee Been here awhile
    Jan 3, 2004
    922
    ... I was born a ramblin' man
    ... a quick bump for Walter's exhaust nut adapters :thumb
    I didn't have any problem getting through to Walter by email, and he always replied to my questions promptly. Also, I didn't have a Moneybookers account and didn't fancy setting one up but Walter was happy to accept Paypal.
    The only minor issue I've had is that it took 3 days from posting for the adapters in the father-land to them arriving in Oz and then another 17 days to traverse the land down under ... go figure :huh
    Good communication, quality product ... delivery within Oz via Pony "express"
    Have a good 'un
    John
    #26
  7. wirewrkr
    wirewrkr the thread-killer
    May 23, 2008
    4,293
    HIGH desert
    How in the hell did that happen? Was anyone hurt?
    That will leak like crazy. and may cause further problems down the road/ keep in mind that the compression ring and seal ring are being drawn up to the face to seal exhaust. don't want to burn a valve.
    RV
    #27
  8. shawn
    shawn Adventurer
    Jul 20, 2007
    29
    England
    :D Got it welded as well in the end:D
    Inside and out!:D
    #28
  9. apt13
    apt13 Been here awhile
    Dec 5, 2010
    488
    Athens, GA
    sorry to dig up an old thread, but i just installed one of these doo-hickeys and it worked like a charm. had to cut off my old finned nuts and looked like a previous owner basically glued them on with some kind of adhesive as there were barely any threads there once i got them off. researched around about getting new threads cut in and stumbled across this easy fix. for around $120 i'm back up and running, although they do look a little "odd." maybe someday when i do a restoration i'll get them properly fixed and new threads cut.
    anyway, ordered them from the UK and they were at my door within a week. http://www.motorworks.co.uk
    and they also make a "finned" version now, but i didn't want to pay the extra money for them.
    just wanted to bump this back up from the depths and leave my positive thumbs up to the original creator of them:
    https://www.sternmutterersatz.de/index.php?page=exhaust-nut-repair
    #29
    Lornce, franko58 and Kokopelli like this.
