Airhead "Tips and Tricks"
Discussion in 'Airheads' started by elmoreman, Sep 26, 2006.
  1. radmeister
    radmeister Been here awhile Supporter
    Mar 23, 2010
    672
    The Creek - Stoney Creek, Ontario
    i like that tool. the red tools are the fastest.
  2. Bruincounselor
    Bruincounselor North Plains Drifter Supporter
    Apr 1, 2006
    2,275
    Northen Plain
    SmittyBlackstone and sprouty115 like this.
  3. sprouty115
    sprouty115 Long timer Supporter
    May 29, 2012
    8,708
    Providence, RI
    I might have just over-shared...
    globalt38 and SmittyBlackstone like this.
  4. Arktasian
    Arktasian Feelin the BMEP
    May 23, 2014
    2,278
    BC
    I changed my mind - it doesn't have the "pull open feature that keeps small screwdrivers in their drawers.
    SmittyBlackstone likes this.
  5. Disston
    Disston ShadeTreeExpert Supporter
    Aug 31, 2009
    19,086
    Silver Spring, Md
    Boy, I'm a real tool nerd and own more tools, old and new, than I'll ever need but I don't own one of those.
    Uke and SmittyBlackstone like this.
  6. Stagehand
    Stagehand Imperfectionist
    Oct 6, 2004
    33,411
    Turicum
    I did happen to have one Those tools lying around.
    edit: it was just a regular vice. thankfully it wasn't gapped too small, I don't know what I would have done. Send them back, I suppose
  7. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    9,173
    https://www.amazon.com/CTA-Tools-32...d=1&keywords=the+gapper&qid=1625524562&sr=8-2
    unlike this "original version" mine, also my CTA is American made. from the pics on amazon I can tell mine is higher quality. will not work with a plug that has 4 side electrodes. there were some wire types that would but they had square loops not round ones. looks like the press type gappers could be hard on your feeler gauges with a plug like the bosch platinum and they have no provision for opening the gap. the discs open just the tips of the side electrode without putting any pressure elsewhere on the plug, unlike a screwdriver which prys off the center electrode..
  8. gsd4me
    gsd4me 90% bluff
    Dec 11, 2005
    10,014
    Brisbane, Australia
    Here's a good trick to cheaply increase fuel range without the need to waste time with jerry cans. An Australian Nomad auxilliary tank, sold as 7.5 litres capacity, but will hold 8.3 litres to the brim. This one is mounted on a kitchen cutting board and is plumbed through a Y piece into the main fuel lines so it can be used first to remove excess weight from the rear of the subframe.
    The way it is mounted on the board means it can be situated at the front or rear of the subframe.
    thumbnail_20170608_120611.jpg thumbnail_20170608_120638.jpg thumbnail_20170608_120659.jpg
    The Bike.
    toecutta, WooPig, Uke and 3 others like this.
  9. Tripletreat
    Tripletreat Long timer
    Dec 20, 2008
    1,211
    Boise, Idaho
    Oz doesn't require fuel containers to be red? Where I live that's a law, although I have never seen anyone busted for it's violation.
  10. Tripletreat
    Dec 20, 2008
    1,211
    Boise, Idaho
    There is a distinct click when I rotate to and fro the rear wheel of my R100R. I assume the drive shaft U-joints are in failure mode. What are my options, apart from BMW OEM? I see the Ted Porter's shop and EuroMotoElectrics offers an after market replacement. Are there others? Years ago I think there was a shop in California that rebuilt the OEM drive shafts. I think it was Henderson, or something similar. Ideas? Suggestions? TIA
  11. Plaka
    Jun 19, 2010
    9,173
    who are you talking to?
  12. Plaka
    Jun 19, 2010
    9,173
    what thread are you posting in? Seriously, I would move your post and put it on top where everybody will see it.
  13. Tripletreat
    Dec 20, 2008
    1,211
    Boise, Idaho
    Post 2228 addresses aux. fuel containers on the rear rack of the bike.
  14. Tripletreat
    Dec 20, 2008
    1,211
    Boise, Idaho
    opps, my bad!
  15. Plaka
    Jun 19, 2010
    9,173
    That one would be my bad. I forget how many people around here I don't see.
    Bigger Al and Disston like this.
  16. Chalk
    Chalk Been here awhile
    Feb 14, 2016
    510
    England
    Out of interest, how many people re-torque the heads every time they do the tappets?
    As a long term Guzzi owner it seems overkill unless I’m missing something.
  17. Plaka
    Jun 19, 2010
    9,173
    nope. happen to know Matt Parkhouse quit doing it too. On the early heads the rocker end play needs set so 4 of the head bolts will need retorque to do that.
  18. Chalk
    Feb 14, 2016
    510
    England
    Interesting, I have the later 1000cc heads on my bike, think I’m just going to do the tappets and not bother with the re-torque. Save the issue with the studs pulling out of the cases as well.
  19. Disston
    Aug 31, 2009
    19,086
    Silver Spring, Md
    About ten or fifteen years ago this seemed to be common. Then it was suggested every other time may be better. Currently not very often at all unless you see loosening of the lateral movement or have some other reason.
    With a new head gasket after buttoning up the top end retorque after 50 miles or so and again at 500 miles.
    A retorque is not done like the original installation. Don't loosen all the nuts at once. Undo each in turn and tighten that one to final torque. No steps in torque setting. Loosen then apply final torque. Finish with one before moving on to the next.
    These directions are similar to others but they are mine and some may have a minor protest or two to my methods. We can't all be perfect.
  20. Plaka
    Jun 19, 2010
    9,173
    we can all be perfect except you tho' :D
    Disston likes this.
