Airhead "Tips and Tricks"
Discussion in 'Airheads' started by elmoreman, Sep 26, 2006.
  1. MrBob
    MrBob In the Pines. Supporter
    Oct 27, 2005
    19,445
    Boulder CO and Tallahassee, FL
    Anybody know what this switched terminal is meant for? I’m thinking of wiring a USB port to it to charge my GPS and phone.
  2. Big Bamboo
    Big Bamboo Aircooled & Sunbaked Supporter
    Sep 29, 2010
    15,765
    Big Island of Hawaii
    That looks like the wire that went to the emissions control solenoid under the starter cover. There should be a corresponding male connector in the same area. I've just plugged them together, but not sure if that's necessary or beneficial.
    SmittyBlackstone likes this.
  3. MrBob
    Oct 27, 2005
    19,445
    The emissions stuff was removed by a PO, so that could be it.
  4. garandman
    garandman Wandering Minstrel
    Feb 5, 2007
    7,721
    Dorchester, MA / Sunapee, NH
    This is a "DOH!" item but worth mentioning. Rode my R90/6 to a Yankee Beemers breakfast. Went out to take a trip to the American Heritage Museum. No start.
    Duncan of Duncan's Beemers was right there. Told him "It doesn't even crank." He made two observations:
    1. "Four out of five bikes that roll in the driveway have loose battery connections."
    2. "A screwdriver will not get them tight enough: use a 10mm wrench."
    Sure enough, battery leads were loose - and I'd used a screwdriver to tighten them initially.
  5. folmonty
    folmonty twins make perfect moto music Supporter
    Jun 14, 2002
    399
    Out West
    Was messing around with cable routing and had to disconnect the clutch cable several times. Found connecting several zip-ties together allowed for easy connection of the barrel fitting on the actuation arm. Not a lot of space to work when exhaust is all connected. 53A5BB3C-4FE3-4EAB-A6BE-7389F562B826.jpeg
  6. garandman
    Feb 5, 2007
    7,721
    While ordering a right side battery cover that flew away (now I know to add a zip tie!) also bought a muffler wrench. Loosened then retightened the nuts and they worked fine.
    Others have recommended removing thrm yearly and applying Nev’r Seize. What say ye?
  7. ORexpat
    ORexpat Oregon Expatriate
    Jan 7, 2007
    3,609
    West of Seattle . . .
    Yup. loosen regularly!
    R100PDave and SmittyBlackstone like this.
  8. sprouty115
    sprouty115 Long timer Supporter
    May 29, 2012
    7,043
    Providence, RI
    Considering how easy it is to pull up a picture of someone cutting these off perfectly good engines, I'm not sure how anyone could recommend against yearly maintenance.
  9. Disston
    Disston ShadeTreeExpert
    Aug 31, 2009
    15,767
    Silver Spring, Md
    How tight do you make the exhaust nuts? Beings it is rather impossible to measure this torque it may be impossible to say but I think the manual has a pretty high figure. Don't have the manual here so I can't look it up. I make them tight enough to not leak but not much more than that.
  10. SmittyBlackstone
    SmittyBlackstone Been here awhile
    Mar 3, 2015
    722
    Westchster County, NY
    Copper antiseize. Only.
  11. Disston
    Aug 31, 2009
    15,767
    Silver Spring, Md
    I have been using the Permatex silver anti seize for 50 years. Works fine.
  12. SmittyBlackstone
    Mar 3, 2015
    722
    It is what I use.
    Don't be a d bag
  13. MrBob
    Oct 27, 2005
    19,445
    Edit: Easy, peasy after getting a clear idea of how to make the adjustment using Youtube vids and some reading.
  14. SmittyBlackstone
    Mar 3, 2015
    722
    It was not bad information.
    But I do agree you can use any hi temp antiseize.
    In my experience, the aluminum nut would sometimes still stick to the head.
    I learned that copper antiseize, being of a different metal, would not seize.
    I still loosen them once a year when servicing all of them.
    globalt38 likes this.
  15. Disston
    Aug 31, 2009
    15,767
    Silver Spring, Md
    My neighbor, Milo, has been building cafes and such for a few years. He doesn't only pick on Airheads but has lately begun on them too. So I'm his resident "expert" and lend him tools sometimes. I can't find my rotor removal bolt. So what is the length of a hardened rod, maybe a drill shank, that can be used with the stock rotor holding bolt to remove the rotor? If I was to guess I'd say 30 mm. But maybe 40 mm would be better? See guessing doesn't work for me too well. Anybody know?
  16. beemeruss
    beemeruss Russ Supporter
    Jan 17, 2010
    86
    Edmonton AB Canada
    I read somewhere that one of the studs from a valve cover will work in a pinch for a field repair but have not tried it myself. My special removal bolt has not wandered away yet.
    Cheers, Russ
  17. MrBob
    Oct 27, 2005
    19,445
    Today we pulled the back wheel and I cleaned out the ton of dust in the brake drum and deglazed the shoes. Pulled both front calipers and added new pads.
    The result is a dramatic increase in braking power.
  18. guywithchickens
    guywithchickens Been here awhile Supporter
    Nov 29, 2016
    878
    Central CT
  19. MrBob
    Oct 27, 2005
    19,445
    Inspection of the rear brake shoes showed areas where they weren't full contacting the braking surface of the drum. Oh, for the days when you took drum and shoes to the machine shop to have the shoes properly arced.
  20. Big Bamboo
    Sep 29, 2010
    15,765
    Vintage Brake still offers this service. https://www.vintagebrake.com/info.htm
    Uke and SmittyBlackstone like this.
