Airhead "Tips and Tricks"
Discussion in 'Airheads' started by elmoreman, Sep 26, 2006.
  1. WRC51
    WRC51 Long timer
    Sep 8, 2008
    1,365
    Santa Rosa, Calif.
    Big B are the Vech bars 22mm? I just bought a set of lower bars but I think they sent the wrong ones and really didn't notice it until they were on the bike. (too late to return). Even the new short cables for these bars are too long, especially the under tank MC cable. Oh well back to the drawing board:D
  2. Big Bamboo
    Big Bamboo Aircooled & Sunbaked Supporter
    Sep 29, 2010
    14,974
    Big Island of Hawaii
    I'm pretty sure they are, it is a BMW number, after all. You could call Vech and ask. Those particular bars on my R90/6 were bent while breaking a couple of my ribs, and got tossed...
  3. s09rwmb
    s09rwmb I put the 'OLD' in 'Oldschool'
    Dec 25, 2008
    14
    North Central TEXAS
    24EB337F-5062-4675-B681-A7F0A70F52B1.jpeg Your back will appreciate this work table. Not my original idea - some other genius. My sketch though. It’s what I do. Study the dimensions and modify it to your requirements.
  4. s09rwmb
    Dec 25, 2008
    14
    North Central TEXAS
    0C5C6AD5-F97D-4506-BFC9-463D60232DA9.jpeg RS fairing boot installation as I have learned requires clean oil free assembly points - what I call “rails” cast into the fairing that the rubber channels in the boots snap over. The “blind” and “upper center” fairing sections create an opening for the boots and must be fitted in such a way that the seam between them is as flat as can be.
    I warm the rubber just a bit with a heat gun during installation and begin by installing the small radius end of the boot first. Then, I work the sides into position on their respective locking rails until I get the opposite small end radius seated. At this point there is usually a bias - one side is stretched tighter fore and aft than the other that can be felt because the small ends aren’t fully seated - and that condition is what causes the boot to come loose as the fork tubes pull against the webbing.
    The trick is to work the bias out of the boot along the side rail attachments and get the small radius ends seated completely front and back.
    While working the sides one can feel that tension dissipate each time the small ends are pressed home. If tension is inadvertently added to one side, the small radius pops off the rail.
    Many times boots I’ve replaced for others were brittle and torn but the edges were still seated firmly with no glue. Occasionally one will pop out and I just work it back into place as described. Most folks resort to glue or install bellows which do protect the fork tubes. I prefer my fairing factory sealed. When trailering, the boots are easily removed to permit the installation of soft ties.
  5. MrBob
    MrBob Rabbitbrush Ranger Supporter
    Oct 27, 2005
    17,367
    Boulder county, Colorado
    Anybody know what this switched terminal is meant for? I’m thinking of wiring a USB port to it to charge my GPS and phone.
  6. Big Bamboo
    Sep 29, 2010
    14,974
    That looks like the wire that went to the emissions control solenoid under the starter cover. There should be a corresponding male connector in the same area. I've just plugged them together, but not sure if that's necessary or beneficial.
    SmittyBlackstone likes this.
  7. MrBob
    Oct 27, 2005
    17,367
    The emissions stuff was removed by a PO, so that could be it.
  8. garandman
    garandman Wandering Minstrel
    Feb 5, 2007
    7,572
    Dorchester, MA / Sunapee, NH
    This is a "DOH!" item but worth mentioning. Rode my R90/6 to a Yankee Beemers breakfast. Went out to take a trip to the American Heritage Museum. No start.
    Duncan of Duncan's Beemers was right there. Told him "It doesn't even crank." He made two observations:
    1. "Four out of five bikes that roll in the driveway have loose battery connections."
    2. "A screwdriver will not get them tight enough: use a 10mm wrench."
    Sure enough, battery leads were loose - and I'd used a screwdriver to tighten them initially.
  9. folmonty
    folmonty Older I get, the faster I was Supporter
    Jun 14, 2002
    368
    Danville, CA
    Was messing around with cable routing and had to disconnect the clutch cable several times. Found connecting several zip-ties together allowed for easy connection of the barrel fitting on the actuation arm. Not a lot of space to work when exhaust is all connected. 53A5BB3C-4FE3-4EAB-A6BE-7389F562B826.jpeg
  10. garandman
    Feb 5, 2007
    7,572
    While ordering a right side battery cover that flew away (now I know to add a zip tie!) also bought a muffler wrench. Loosened then retightened the nuts and they worked fine.
    Others have recommended removing thrm yearly and applying Nev’r Seize. What say ye?
  11. ORexpat
    ORexpat Oregon Expatriate
    Jan 7, 2007
    3,518
    West of Seattle . . .
    Yup. loosen regularly!
    R100PDave and SmittyBlackstone like this.
  12. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    6,398
    Longmont, CO
    remove, clean threads, apply fresh antisieze yearly.
  13. sprouty115
    sprouty115 Long timer Supporter
    May 29, 2012
    6,528
    Providence, RI
    Considering how easy it is to pull up a picture of someone cutting these off perfectly good engines, I'm not sure how anyone could recommend against yearly maintenance.
  14. Disston
    Disston ShadeTreeExpert
    Aug 31, 2009
    15,329
    Silver Spring, Md
    How tight do you make the exhaust nuts? Beings it is rather impossible to measure this torque it may be impossible to say but I think the manual has a pretty high figure. Don't have the manual here so I can't look it up. I make them tight enough to not leak but not much more than that.
  15. SmittyBlackstone
    SmittyBlackstone Been here awhile
    Mar 3, 2015
    582
    Westchster County, NY
    Copper antiseize. Only.
  16. Disston
    Aug 31, 2009
    15,329
    Silver Spring, Md
    I have been using the Permatex silver anti seize for 50 years. Works fine.
  17. Plaka
    Jun 19, 2010
    6,398
    Longmont, CO
    Really? In 40 years of doing it I have never used that. I don't even have any. I'll have to run right out and change it.
    What oil do you use--- only?
  18. SmittyBlackstone
    Mar 3, 2015
    582
    It is what I use.
    Don't be a d bag
  19. Plaka
    Jun 19, 2010
    6,398
    Longmont, CO
    I believe you but look in the mirror before calling names. Giving people bad information is not nice....or perhaps you just phrased it very poorly.
    It is a high temp. junction. Any high temp anti-sieze will work, and use plenty of it.
    dazz and SmittyBlackstone like this.
  20. MrBob
    Oct 27, 2005
    17,367
    Edit: Easy, peasy after getting a clear idea of how to make the adjustment using Youtube vids and some reading.
