Airhead "Tips and Tricks"
Discussion in 'Airheads' started by elmoreman, Sep 26, 2006.
  1. SmittyBlackstone
    SmittyBlackstone Been here awhile
    Mar 3, 2015
    580
    Westchster County, NY
    It was not bad information.
    But I do agree you can use any hi temp antiseize.
    In my experience, the aluminum nut would sometimes still stick to the head.
    I learned that copper antiseize, being of a different metal, would not seize.
    I still loosen them once a year when servicing all of them.
    globalt38 likes this.
  2. Disston
    Disston ShadeTreeExpert
    Aug 31, 2009
    15,314
    Silver Spring, Md
    My neighbor, Milo, has been building cafes and such for a few years. He doesn't only pick on Airheads but has lately begun on them too. So I'm his resident "expert" and lend him tools sometimes. I can't find my rotor removal bolt. So what is the length of a hardened rod, maybe a drill shank, that can be used with the stock rotor holding bolt to remove the rotor? If I was to guess I'd say 30 mm. But maybe 40 mm would be better? See guessing doesn't work for me too well. Anybody know?
  3. beemeruss
    beemeruss Russ Supporter
    Jan 17, 2010
    70
    Edmonton AB Canada
    I read somewhere that one of the studs from a valve cover will work in a pinch for a field repair but have not tried it myself. My special removal bolt has not wandered away yet.
    Cheers, Russ
    SmittyBlackstone likes this.
  4. MrBob
    MrBob Rabbitbrush Ranger Supporter
    Oct 27, 2005
    17,365
    Boulder county, Colorado
    Today we pulled the back wheel and I cleaned out the ton of dust in the brake drum and deglazed the shoes. Pulled both front calipers and added new pads.
    The result is a dramatic increase in braking power.
  5. guywithchickens
    guywithchickens Been here awhile
    Nov 29, 2016
    709
    Central CT
    BMWGSA, SmittyBlackstone, Uke and 3 others like this.
  6. MrBob
    Oct 27, 2005
    17,365
    Inspection of the rear brake shoes showed areas where they weren't full contacting the braking surface of the drum. Oh, for the days when you took drum and shoes to the machine shop to have the shoes properly arced.
  7. Big Bamboo
    Big Bamboo Aircooled & Sunbaked Supporter
    Sep 29, 2010
    14,938
    Big Island of Hawaii
    Vintage Brake still offers this service. https://www.vintagebrake.com/info.htm
    Uke and SmittyBlackstone like this.
  8. Disston
    Aug 31, 2009
    15,314
    Silver Spring, Md
    If you mail it in. But there used to be an old guy did it on 14th street while you waited.
    Thanks guys for the info on making a rotor removal tool. I'll pass along the numbers and Milo can make his own.
  9. MrBob
    Oct 27, 2005
    17,365
  10. Big Bamboo
    Sep 29, 2010
    14,938
    Sonora, California
  11. MrBob
    Oct 27, 2005
    17,365
    Someone told me this practice fell out of favor because of liability issues.
  12. DonniBoi
    DonniBoi Out of my element Supporter
    Jun 26, 2010
    382
    Santa Rosa, Ca
    I'm new to airheads but I found using two wrenches for valve adjustments is not needed. I was able to hold the adjuster with my fingers and use one wrench to snug up the lock nut. I was having problems going too loose or too tight. Just my two cents
    WRC51 and Disston like this.
  13. Disston
    Aug 31, 2009
    15,314
    Silver Spring, Md
    I'll have to try that one. Who woulda thought?
    SmittyBlackstone and DonniBoi like this.
  14. mark1305
    mark1305 Old Enough To Know Better Supporter
    Feb 7, 2005
    6,690
    Merritt Island, FL
    I think I posted this related tip way back - if the finned nuts are stuck (whether or not anti seize was used), try firing up the engine for about 60 seconds or so. It's just enough heat to expand and loosen mine every time. And I do use anti seize.
  15. ME 109
    ME 109 Long timer Supporter
    Jun 25, 2009
    8,048
    Albury Australia
    Just bought my '81RS hi/lo head light switch back to brand new function with a spritz of food grade silicone spray.
    The switch was very lazy to return from the flash position, but the spray has worked very well and now it flicks back easily.
    I don't expect any electrical issues with the spray.
    I had my switch apart to re solder a connection so before replacing the switch lever I gave a quick spritz to either side of the pivoting mechanism.
    Difficult to do without removing the switch lever, but the lever pulls/prys off easily.
    There's another $500 saved from the auto electrician by being able to fix the thing myself.
    That's what I told my wife anyway, pay for the next three tyres sort of thing.
    I've got away with it for 26 years.
    BMWGSA, Cogswell, StmbtDave and 7 others like this.
  16. Runaway Train
    Runaway Train The Left-Right Tourer
    Aug 9, 2013
    292
    Ontario, Canada
    I’ve been meaning to make this special tool for some time now. I usually only think about checking the oil in the morning before I ride to work, and since I work in an office now, I’d rather not go with grease on my hands.
    This “BMW Special tool” allows me to check the oil without getting my hands dirty.
    I’m going to stain it with 20w50 :)
  17. TwoShoes
    TwoShoes How Many Shoes?
    Aug 18, 2003
    417
    Fredericton, New Brunswick, Canada
    Love your idea :-). but check your seat, now you're going to show up at work with 20w50 on yer ass !
  18. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    6,373
    Longmont, CO
    why is there oil on the outside of your dipstick and what do you wipe the stick with to get an accurate reading?
  19. Runaway Train
    Aug 9, 2013
    292
    Ontario, Canada
    That’s not actually oil on the seat. I rode home in the rain, that’s leftover liquid sunshine.
    Plaka. I use a clean shop cloth to wipe the dipstick.
  20. Disston
    Aug 31, 2009
    15,314
    Silver Spring, Md
    I have a rag in one of the pockets of my fairing. Another reason to have a fairing.
