Airheads Flea Market Thread
Discussion in 'Airheads' started by Ben Carufel, May 3, 2012.
  1. Tiggum
    Tiggum Retired
    Mar 2, 2015
    380
    Nashvegas
    That would be ".....colourful Canadian money."
  2. mslim
    mslim If it's worth doing... it's worth overdoing
    Jan 11, 2015
    1,197
    Austin of the Ozarks
    I am advised by ATE Classic that their part # is Ate 03-3556-0052-2-34.
    I was unable to source a USA retailer though. If you didn't care about the fluid level sender, I ordered a non-sender cap from Autohausaz under part # 477611361. I replaced mine last night.
    I did futz around with my intermittent OE cap on the bench trying to repair it. I very carefully removed the small blue cap with a razor blade to gain access to the float terminals inside. I shot DeOxit on them and tried to burnish with a pencil eraser. I also cleaned the .250 male wire terminals. It continuity tested OK but I haven't put it back on the bike to see if it's really fixed.
    SmittyBlackstone and Square1 like this.
  3. MrBob
    MrBob Rabbitbrush Ranger Supporter
    Oct 27, 2005
    17,368
    Boulder county, Colorado
    Of course, I’ve been away too long.
  4. DonniBoi
    DonniBoi Out of my element Supporter
    Jun 26, 2010
    385
    Santa Rosa, Ca
    WANTED: R100GS-PD windscreen. Stock or Aftermarket that is NOT a parabellum sceen.
    Located in SF Bay area. Also have a parabellum I'd trade
  5. georgej
    georgej Been here awhile
    Nov 9, 2008
    294
    Upstate,N.Y.
    I wonder if a really need the fluid level sensor. It's not that big of a deal to remove the tank and check it every so often. I wonder if I can't repair the spade connector with a sodering iron.
    SmittyBlackstone likes this.
  6. Lornce
    Lornce Lost In Place
    Aug 17, 2003
    22,721
    Way Out There.
    Have a look around an auto wrecking yard. I seem to remember the same cap on the brake and clutch slave cylinder reservoirs of my early '80's 320i.
  7. arbalest
    arbalest Been here awhile
    Mar 19, 2009
    315
    J-Boy, I may have a cap. Is $50 too much? For that I could send the whole MC. I'll check at the shop and get back to you.
  8. arbalest
    Mar 19, 2009
    315
    I do have a complete MC with cap. $50 plus shipping.
  9. mslim
    Jan 11, 2015
    1,197
    I looked into this when I was researching my problem. They are similar but float height spec for the R90 undertank motorcycle sender is 33mm. Most automobile reservoirs are deeper than that. If you find one that works please post it.
  10. hotwheels22
    hotwheels22 motorradRP + Airheads International
    May 29, 2015
    4,981
    austin
    pimp your ride:
    MOCAL/BAT BMW r80/R100 oil cooler line (stainless steel line and 45/90 banjo bolts).
    pimp your ride.
    $155 plus shipping retail.
    $80 CONUS
  11. hotwheels22
    May 29, 2015
    4,981
    austin
    why risk your life with a bulging rubber brake line?:
    r80/r100 custom made 44" stainless brake line (with 45/30 degree banjo bolts). $90 new.
    $50 CONUS
  12. hotwheels22
    May 29, 2015
    4,981
    austin
    Dynatek Coil (DC6-1; 12V/3.0-Ohm)
    $40 shipped
    jjwithers likes this.
  13. realgone
    realgone Adventurer
    Oct 15, 2013
    83
    Edmonton, Alberta
    Edit: found one, thanks guys.
    WTB: Left side mirror and mirror mount to fit 1986 r80rt fairing. Does not need to be perfect, just has to do the job.
  14. srob3
    srob3 Grasshopper
    Oct 13, 2008
    51
    East Tn
    https://advrider.com/f/threads/bmw-r75-7-knoxville-tn.1388267/In General flea market. Thanks
  15. Primal Haj
    Primal Haj Looking for Mecca
    Sep 1, 2009
    157
    Southwest Montana
    EC4C2015-F68E-4ECF-BC02-5B922F545A86.jpeg 0A0B37C8-5E15-4D6A-AB2F-95E71E11FA5C.jpeg 2D68690A-5BB6-4860-A8EE-292C6BE9FBF6.jpeg B6B91A7D-3277-4694-8168-2DD5037D74D3.jpeg
    R65/5 LWB seat $150 plus shipping
    Rear fender, some fiberglass damage $50 plus shipping
    Crash bars $50 plus shipping
  16. OHScot
    OHScot Been here awhile
    Sep 28, 2010
    118
    Southwest Ohio
    Hi,
    Recently went to a bar mounted master cylinder. So have a master cylinder that needs a re-seal, line, reservoir, cap, brake switch the whole deal. PM with offer.
    Cap, reservoir and line were replaced about 6-8 years ago. Bought new from Capital Cycle.
    Got tired of the leaks under the tank. Looked at the bore in the cylinder and I believe it is just the seal gone weak, still had brakes just weeped fluid when it sat in the cold garage. Rebuilt the cylinder in the early 90's with new seal kit and piston, so it was due...
  17. aftrn
    aftrn Enabler Supporter
    Oct 6, 2008
    10
    Washington, UT
    Need a set of:
    Square Style-Valve Covers
    Non Painted-Aluminum
    Original Style for 81 G/S
    Mine are shaved down and bashed from several "events" over the years! I need a set that are not damaged but they don't have to be clean/restored. I'll do the cleaning/vapor blasting. New is available but they want first born prices.
  18. highspire
    highspire n00b
    May 25, 2011
    5
  19. Tiggum
    Tiggum Retired
    Mar 2, 2015
    380
    Nashvegas
    Anyone got any good SHORT rear suspension units (maybe Works or Progressive) to fit on a R65LS. Please let me know what you've got and how much $ you want.
  20. aftrn
    Oct 6, 2008
    10
    Washington, UT
    WTB An uncrashed left-side crash bar for an R80 G/S to R100 GS (1981 - 1995)...same part number!
