Ajp pr7
Discussion in 'Thumpers' started by Tiago, Sep 30, 2014.
  1. ebrew
    ebrew Motorcycle A.D.D.
    Nov 4, 2005
    2,333
    Denver colo
    More progress:) image.jpg
  2. High_Country
    High_Country Been here awhile
    Jun 19, 2017
    100
    For those not aware, the bike has a rear subframe hidden beneath the rear tail belly pan. There are two threaded inserts in the subframe extensions on each side. This will make adding luggage tie down points very easy.
    (The OEM rack and many others mount here, but the distributor was out when I got my bike so I had to locate and uncover the holes and drill out the plastic pan myself.)
    Just an fyi and another convenient thought out feature. Getting ready for my Wolfman E-Base.
  3. High_Country
    Jun 19, 2017
    100
    Also, was looking at a bunch of different gearing options. Even whipped up a spreadsheet to play around with ratios (ebrew loves spreadsheets ).
    Guessing there's no room to step up to a 16 tooth front - looking at how close the case saver is to the chain on the stock 15. Anyone know?
    Have purchased a 48 tooth rear to really tighten things up in the woods with the 15 up front. Stock mine came with 42. Also have a 14 tooth front I could use. So, was thinking with one new rear (48) and a couple new fronts (14, 16 plus OEM 15) I could have a bunch of different available ratios.
    42/15 (OEM) = 2.8
    42/14 = 3.0
    48/16 = 3.0
    48/15 = 3.2
    48/14 = 3.43
    Just curious if a 16 will fit.
    (By the way, the front sprocket that will fit is a JTF707. ) IMG_20200824_191425.jpg IMG_20200824_191420.jpg
  4. ebrew
    Nov 4, 2005
    2,333
    Denver colo
    Still a little wiring to do but fits great 2B8B2D0F-38E9-4E15-BD20-B3418148FCDB.jpeg
  5. ebrew
    Nov 4, 2005
    2,333
    Denver colo
    Man I don’t think a 16 will fit
    It’s a tight squeeze
  6. mrsdnf
    mrsdnf Long timer
    Feb 8, 2019
    1,221
    Lost between the Dandenongs and Yarra Valley
    High_Country likes this.
  7. VTwins4me
    VTwins4me Been here awhile
    Jun 24, 2007
    198
    Beverley, England
    THAT is tall!:-)
  8. VTwins4me
    Jun 24, 2007
    198
    Beverley, England
    For those needing lower gearing options - AFAM sprockets :
    13 T Pt No 37400-13
    14T Pt No 37400-14 (OEM for Aprilia RXV & MXV I believe)
    rvsparky likes this.
  9. Rotax655
    Rotax655 Aprilia World Meeting
    Dec 10, 2009
    680
    If I can around the world
    This is a AJP
    Bonnie & Clyde and sanvara like this.
  10. VTwins4me
    Jun 24, 2007
    198
    Beverley, England
    Graphix options for the PR7 are needed but not these - so boring.
  11. hockeyrick
    hockeyrick Hockeyrick
    May 31, 2015
    247
    Huatulco, Oaxaca, Mexico
    Hey Ebrew, cool lights, are those prices correct? Saw the web site.
  12. Rotax655
    Dec 10, 2009
    680
    To simulate relationships you can try this
    https://www.gearingcommander.com/
    With a 48 at the rear he will have much shorter ratios
  13. ebrew
    Nov 4, 2005
    2,333
    Denver colo
    Yes that’s with VAT as well
    So a bit cheaper but still a few $$$
  14. Brett737cap
    Brett737cap Life is short... leave with no regrets. Super Supporter
    Aug 11, 2002
    1,013
    Bergton, VA
    I had a graphic artist make these up for me using the factory template. The pics on the bike are photoshopped ideas. Final design is the template pic.
    4AC5135D-4379-4190-90D9-98EE3574C41B.jpeg BD6315B6-6D01-459D-B1AC-07DDB5AA9EA8.jpeg 8C872AA7-95DE-41A6-9A55-52FA91B3FDDE.jpeg AD4E6079-EB6A-4CE7-8DD6-6DDB50396F8C.jpeg
    2 SPOT likes this.
  15. webmonstro
    webmonstro A Aventura Continua....
    Jul 21, 2008
    1,244
    Portugal
    António Pinto himself doing the Portuguese section of the TET on a. PR7 obviously Screenshot_2020-08-27-22-31-07.jpg
  16. sanvara
    sanvara Been here awhile
    Jul 26, 2012
    214
    hi does anyone know the oem air filter ref. part number? thx
  17. Tbucket
    Tbucket Adventurer Supporter
    Oct 11, 2014
    32
    Air filter #00MTS01A0193
    $75.00
    Or you can order the twin air Filter and cage that is the same price
    sanvara likes this.
  18. Rotax655
    Dec 10, 2009
    680
    00MTS01A0225 Screenshot_2020-08-29-18-21-44-662_cn.wps.xiaomi.abroad.lite.jpg
    sanvara likes this.
  19. sanvara
    Jul 26, 2012
    214
    thx
    Tbucet and Rotax 655 for your quick response; I have the Oem now with 10 k km I use prefilter and clean it very often; owners manual says to change it every 10k km; What is your suggestion, to buy the original one or change to twin air? ( btw the one original one looks like new)
  20. Rotax655
    Dec 10, 2009
    680
    is the original AJP filter made of paper? I can tell you that twin air makes great products. my TE630 is factory fitted with a Twin Air. it cleans easily and lasts a long time. it might be a good choice
