Ajp pr7
Discussion in 'Thumpers' started by Tiago, Sep 30, 2014.
  1. Crash217
    Crash217 The short guy with a beard
    Jun 28, 2005
    1,290
    Tulsa, Oklahoma
    No need to replace wheels, simply get the Nuetec Tubliss system. $125-ish per wheel, available at most dealers/distributors.
    http://tubliss.com/
    I had good luck with them. Just keep a tiny bicycle suspension air pump with you to run the inner bladder psi up to 100-125psi when you’re away from a high powered air compressor and need to.
  2. Anders-
    Anders- 690R
    Aug 23, 2013
    4,634
    Швеция
    Tubliss is not tubeless :deal
    A tubeless tire means a lot less to mess around with.
  3. Crash217
    Jun 28, 2005
    1,290
    Tulsa, Oklahoma
    But if you’re just wanting to avoid a pinch flatted tube, then it’s an option.
  4. Tbucket
    Tbucket Adventurer Supporter
    Oct 11, 2014
    31
    Since we are on the oil screen topic this is what I found on mine. Waiting on the new one. That is all I found. I have flushed the cases and clean the oil pump. The oil pump was clean. I hope that I get the updated version. Does any body have the new part number
  5. Tbucket
    Oct 11, 2014
    31
    Also found little pieces on the other side screens. Otherwise is super clean
    jredford likes this.
  6. hockeyrick
    hockeyrick Hockeyrick
    May 31, 2015
    239
    Huatulco, Oaxaca, Mexico
    Just a question to mess with, what if you run with no screen, doesn't the oil filter do this job?
  7. Anders-
    Anders- 690R
    Aug 23, 2013
    4,634
    Швеция
    Check the oil circuit section in your workshop manual?
    My wild guess is that the screen protects an oil pump.
  8. Tbucket
    Oct 11, 2014
    31
    That is correct it protects t the oil pump.
  9. Tbucket
    Oct 11, 2014
    31
    I guess it can. Because what I had there and nothing was the same, and who knows for how long was like that.
  10. hockeyrick
    May 31, 2015
    239
    OKThen, that means other bikes have no protection for their oil pump, yet they still work fine? Just trying to wrap my head around the Xtra screens!
  11. LoRZo
    LoRZo Adventurer
    Apr 30, 2019
    53
    France
    Hello,
    Last year I rode 34000 across Europe, it's now time to do a big servicing on the bike. And adding some extra.
    Watch out the 1st episode.
  12. ghostridergary
    ghostridergary Trying is the first step on the road to failure.. Supporter
    Nov 23, 2010
    114
    Lundun, UK
    Can someone confirm if that slot head screw on the top of the forks is the pressure release as per WP forks?
  13. zodillyicous
    zodillyicous Been here awhile
    Jan 30, 2014
    218
    Seattle
    Yes image-2021-04-20-11:56:15-638.jpg
  14. LoRZo
    LoRZo Adventurer
    Apr 30, 2019
    53
    France
    Second episode of my PR7 servicing
  15. XR250EFFNR
    XR250EFFNR n00b
    Nov 15, 2019
    5
    San Diego
    PR7 owners: how is the visibility with the tablet up front? Do find yourself standing up more than you would like?
    Can anyone speak to how smooth this bike is on longer road sections compared to a SWM650 Superdual X (same engine) and the crf450l?
  16. jredford
    jredford Ninja Racer
    Feb 29, 2008
    1,610
    H town...
    Has anyone had an issue with the neutral light not turning off? Mine just stays on no matter what gear I am in.
  17. ghostridergary
    Nov 23, 2010
    114
    Lundun, UK
    Amateur hour at Gaz's Fabrications again.... rather than spend £70 on a Thork bracket for my Montana, just used an old Ram mount and a couple of 1mm ally spacers to utilise my existing AMPS bracket...... and its probably more adjustable!
  18. DLS01
    DLS01 Adventurer
    Jun 26, 2017
    21
    LWD
    Sun is a pain for the tablet. Standing is comfortable and if I stand I face the tablet less. If I can’t read it I stop. Is safer.
    Can’t compare with the other bikes. On road the PR7 is good for an off road. 100km/h for a longer period is fine, depending on wind. Wind protection is minimal of course. Bike feels smooth and there is not that much vibration.
    To get off road I have quite some on road kms to go. I experience that as fun and comfortable too. Although it is capable to it is not a highway bike. At least not for me for a long distance.
    XR250EFFNR likes this.
  19. DLS01
    DLS01 Adventurer
    Jun 26, 2017
    21
    LWD
    No. I think a visit to the dealer is at place.
    kelvyn likes this.
  20. kelvyn
    kelvyn KTM AdventureR
    Apr 16, 2010
    47
    Durham, England
    Yes
    Myself and a colleague
    I've dielectric greased the middle connector but its the unit behind the sprocket which is sensitive to moisture on mine
