Ajp pr7
Discussion in 'Thumpers' started by Tiago, Sep 30, 2014.
  1. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    2,171
    Герма́ния
    Less gears means less shifting :D
    Having just 5 gears instead of 6 means that the available space in the engine is bigger so the gears can be wider resulting in spreading the load on them better which should make them stronger and longer lasting. (in theory at least)
    BMW for instance have had 5 gears on their single cilinder Rotax engines and they are pretty much bomb proof.
    #81
  2. VxZeroKnots
    VxZeroKnots Long timer
    Jun 5, 2008
    4,604
    It should would be nice to have a modern equivalent of the 640ADV, but maybe without the vibes ;)
    I ended up building my own out of a 690 and HDB rally lite kit, but the 6-speed is so narrow I'd almost prefer the 640's 5-speed.
    I think gap between gears it is less of an issue on torque monster big bores that can easily pull hard across the range than it is on the smaller bikes. I don't really care one way or another but I've owned four bikes with semi-close or close range 6-speeds. On small trail bikes it makes sense, right gear for every situation and all. On the big bikes that can put down major power at low RPM it makes less sense.
    #82
    savetosave likes this.
  3. timeOday
    timeOday Long timer
    Jun 20, 2008
    4,116
    New Mexico
    Yeah, you know, if I were either CCM or AJP, I would be very worried by the fact that if I start to succeed and make any money, KTM will just say, "ok, fine, fine, here's your 690 Adventure, you whiners," which KTM could develop in their sleep if they feel like it.
    #83
  4. 2 SPOT
    2 SPOT bring the rape whistle
    Dec 14, 2005
    7,120
    Payson AZ
    develope? they already have it ready,, they even have turn signal holes in the fairing and everything, they just refuse to sell it.
    #84
  5. crunchiespg
    crunchiespg Long timer
    Sep 26, 2009
    1,253
    AB Canada
    Pics? You talking about the rally bike?
    #85
  6. 2 SPOT
    Dec 14, 2005
    7,120
    Payson AZ
    no not the RR bike,,,, way back in the early pages of the 690 ('06-'07?) when it was first coming out, there are pics of testing what we all thought at the time was going to be the 640a replacement, i'll see if i can find it.
    #86
  7. todd900ss
    todd900ss Been here awhile
    Apr 29, 2004
    796
    Marietta, Georgia
    Damn right and the Japanese will be right behind KTM.
    I'm pulling for CCM and AJP, hope they both sell all they can build.
    #87
  8. 2 SPOT
    Dec 14, 2005
    7,120
    Payson AZ
    me too, like i did with ATK, canondale and US Highland.
    #88
  9. Adventure boy
    Adventure boy Been here awhile
    Aug 21, 2003
    660
    London England
    I love the look of this bike and will buy one but am with Tim all the way in what he said, some very valid points, ive had all the adventure type bikes, numerous XT660s in all guises, CCM644s, XR650, 800GS, 800 Tiger, DRZs, KTM 640, KTM990 Adv R
    KTM 1190 Adventure R current bike along with a XT660R
    They have all had there good and bad points
    #89
  10. polishadam82
    polishadam82 black sheep
    Feb 19, 2011
    455
    Gilroy, CALI
    660 was also used in MZ with did pass cali emissions bullshit so they might be up to something there now the question is what's the price/
    #90
  11. todd900ss
    Apr 29, 2004
    796
    Marietta, Georgia
    The 660 motor in the MZ line used the 5 valve head, I'm not sure if the bottom end is the same. The XT660 uses the 4 valve head IRC.
    #91
  12. polishadam82
    Feb 19, 2011
    455
    Gilroy, CALI
    damn I was close only off by one valve haha :1drink either way it's a good motor I hope that's what they will use
    #92
  13. Samtech79
    Samtech79 Two wheeled lunatic
    Feb 27, 2014
    1,402
    NorCal
    I thought the motor was the same one in the Aprilia enduro. A yamaha design that was licensed to minarelli to produce. Five valves, 660cc.
    #93
  14. todd900ss
    Apr 29, 2004
    796
    Marietta, Georgia
    I had to double check.
    Here are the specs from Yamaha-motor.eu
    Engine
    Engine typeSingle cylinder, 4-stroke, liquid-cooled, SOHC, 4-valves
    Displacement660cc
    Bore x stroke100.0 mm x 84.0 mm
    Compression ratio10.0 : 1
    Maximum power35.0 kW (47.6PS) @ 6,000 rpm
    Limited power versionkW (PS) @ rpm
    Maximum torque58.0 Nm (5.92 kg-m) @ 5,500 rpm
    Lubrication systemDry sump
    Clutch typeWet, multiple-disc coil spring
    Fuel systemElectronic Fuel Injection
    Ignition systemTCI
    Starter systemElectric
    Transmission systemConstant Mesh, 5-speed
    Final transmissionChain
    #94
  15. hahmule
    hahmule Balding Gloriously
    Jan 9, 2007
    668
    Nowhere Valley, CA
    as a replacement for my 610. Only wish it had a six speed over a 5. Looks bullet proof, way tougher than a KTM. Gotta have the plate though, can't ride anywhere without it in Cali.
    #95
  16. sir marco
    sir marco Always on the run
    Apr 29, 2012
    100
    NL
    http://www.bike-on-tour.com/motorrad/meine-ccm/
    127,8 kg...
    #96
  17. MaNDan
    MaNDan 'Old Japanese cycles & '26Chevy truck
    Dec 21, 2013
    312
    Wild midWest -USA
    #97
  18. 2 SPOT
    Dec 14, 2005
    7,120
    Payson AZ
    they didnt at the AZ show
    #98
  19. Starchamp
    Starchamp Rebel Scum
    Apr 9, 2009
    1,487
    Out there
    Nor the NYC show.
    #99
  20. MaNDan
    Dec 21, 2013
    312
    Wild midWest -USA
    Ok, if I get to Mpls, will report back
    How about J Mo, maybe s/he can give us some info!?
    I'm new to this thread, is there a list of dealers -retailers in US?
