Akrapovic silencer and tune
Discussion in 'GS Boxers' started by DDPRider, Jul 31, 2020.
  1. DDPRider
    DDPRider Adventurer
    Jun 9, 2020
    14
    California
    I recently installed the Akrapovic slip-on silencer on my 2020 R1250 GSA .
    The bike is running lean. Are there tunes out there for this application?
    Thanks in advance
  2. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    7,102
    Zer0-Zer0-Zer0-Zer0
    By changing the slip-on to Akrapovic from OE, you haven't changed how the bike runs. If it is lean now, it was lean before... :deal
    There are tunes (ECU flash-ones) but having them may void your warranty - should look into that a bit further (ie. Brentuning - spelling?)...
    There's also fuel enricher/controller of sorts called AF-X... something something which may help in your situation... Some say it does help so it actually may help you too...
    Many of us have changed the slip-on without changing anything in the fuel/map management of our bikes - ymmv... :deal
  3. ragtoplvr
    ragtoplvr Long timer
    Oct 18, 2007
    11,193
    central USA
    The bike CAN NOT run lean or rich as long as the ecm and sensors are functioning. There is a mixture sensor on the exhaust pipe. It compensates.
    This is fake knowledge that has circulated for years because of deceleration backfire which can be reduced by overfueling. There is high vacuum and a very thin cylinder filling, not enough to combust. Making it richer gains you nothing real. You should have a deceration fuel cutoff as long as you return the grip to idle on decel and you will not have popping above about 2K RPM.
    Overfueling does reduce temps a little, Boxers do not have overheating problems. All it does is waste fuel and pollute the air.
    Stand by for all kinds of comments about how I am wrong.
    Rod
    lewisjr1, Dorian and m931a2 like this.
  4. Lead Wrist
    May 26, 2007
    7,102
    Zer0-Zer0-Zer0-Zer0
    On a slip-on? Hmmm... My '16 didn't have that... :hmmmmm
  5. srv256ss
    srv256ss Been here awhile
    Mar 22, 2015
    134
    ATL, GA
    The 1250 has 3 O2 sensors, one after the cat.
    SidewinderX likes this.
  6. Lead Wrist
    May 26, 2007
    7,102
    Zer0-Zer0-Zer0-Zer0
    ^^ Yes it does but on the headers not on slip-on? The previous poster mentioned "exhaust pipe" as in slip-on pipe?? :dunno
  7. Matsgs
    Matsgs Adventurer
    Oct 2, 2019
    46
    Germany
    folks the 1250 runs two wideband sensors and compensates automatically you can run without exhaust it does not matter and the third probe is not yet active this is intented for Euro5 to detect if someone has altered the target lambda values and throw an engine fault.
  8. third eye
    third eye back road loon Supporter
    Sep 2, 2010
    417
    Concord, CA
    ^^^^ so the third probe is not activated for U.S market?
    #8
  9. Matsgs
    Matsgs Adventurer
    Oct 2, 2019
    46
    Germany
    not yet ... Current software ignores the signal
    #9
  10. third eye
    Sep 2, 2010
    417
    Concord, CA
    I have changed exhausts and tuning on several other bikes that I have owned but my 1250 runs really well bone stock. I may keep it that way
    #10
    Bluetooth Tuner likes this.
  11. ragtoplvr
    Oct 18, 2007
    11,193
    central USA
    NO a slip on is a slip on, it attaches to the existing exhaust pipes. Makes more noise, maybe a slight change in power, can be + or -. Those existing exhaust pipes have one or more mixture sensors, there are several types. Unplugging them generates a ECU fault.
    Rod
    #11
  12. Lead Wrist
    May 26, 2007
    7,102
    Zer0-Zer0-Zer0-Zer0
    Got it - by exhaust pipes you mean headers which do have 2+1 O2 sensors on R1250...
    #12
  13. m931a2
    m931a2 Been here awhile Supporter
    Oct 2, 2014
    412
    Austin, Texas
    If you have a need to fix something look in to getting a AFXied for your bike. Make it richer and not pop as much.
    Chat here sales here and here
    #13
    Rockred likes this.
  14. DDPRider
    DDPRider Adventurer
    Jun 9, 2020
    14
    California
    Thanks for all the comments. Interesting read.
    #14
  15. leafman60
    leafman60 Long timer
    Aug 14, 2005
    3,976
    2016 bikes were EURO 3 and not as strict about such items.
    Since then, we've had EURO 4 and now EURO 5. These standards have an application day for new models and usually a year's delay for existing models. If I recall correctly, EURO 5 was mandated at the beginning of 2020 for new models but delayed another year for existing models.
    #15
  16. luca9277
    luca9277 Been here awhile
    Feb 25, 2012
    329
    Singapore
    +1 for the AF-Xied. Best add-on my GS.
    I have de-cat headers, Akra slip-on and K&N filter
    It makes the bike run like a dream
    #16
    Rockred likes this.
  17. Matsgs
    Matsgs Adventurer
    Oct 2, 2019
    46
    Germany
    All new 1250 build after August i believe will be Euro 5.
    #17
  18. Bluetooth Tuner
    Bluetooth Tuner Adventurer
    Sep 10, 2019
    63
    London
    AF-xied is great for the 1200 wethead, not available yet for the 1250, but IMHO leave the 1250 alone it has a brain and after a few tanks of gas will adapt to the new pipe, and certainly do not believe that some imaginary tune from the UK or Australia that BMW cannot see will fix your bike, not naming names as to not pollute the thread.
    #18
    Rockred likes this.
  19. ragtoplvr
    Oct 18, 2007
    11,193
    central USA
    Dyno sheet for power increase or seat of the pants.
    #19
  20. side-burn
    side-burn Long timer
    Apr 28, 2019
    1,254
    Colorado
    Odd. My Akra slip on was fine after riding about 60 minutes for the ECU to tweak the AFR.
    #20
