all-terrain FZ07 (like a strom but without the suzuki)
Discussion in 'Japanese polycylindered adventure bikes' started by Pablogordo, Sep 17, 2019.
  1. Pablogordo
    Pablogordo Been here awhile Supporter
    Oct 18, 2018
    118
    nola
    Rode it around the neighborhood some just now, ordered a custom Corbin for it also this morning, I can weld mediocre, but my upholstery skills are nil!
    #21
    redneckK20 and mcmann like this.
  2. Pablogordo
    Oct 18, 2018
    118
    nola
    Today I put some small loop-brackets in the bolt holes where the passenger pegs used to reside and mounted up my Great Basin 60L bag, fits great, like it was meant to go on there
    #22
    Ridin'nFishin, dtysdalx2 and merc16 like this.
  3. Pablogordo
    Oct 18, 2018
    118
    nola
    I welded myself a cat-back system for it today
    #23
  4. Edoz
    Edoz n00b sauce
    Jun 22, 2018
    430
    Tulsa,OK
    That's pretty bitchin. I like it.
    #24
    dtysdalx2 likes this.
  5. Pablogordo
    Oct 18, 2018
    118
    nola
    Made a license plate mount out of one of those axle-tags that have always seemed to gouge me in the ankle when I’ve tried to use one, and a case saver from a piece of 1/8” kydex
    #25
    merc16 likes this.
  6. Pablogordo
    Oct 18, 2018
    118
    nola
    I made some offset brackets to mount an FZ09 front fender with good clearance over the tire (1-1/4-1/2ish
    Also, rather than buying and fitting a 180/55 TKC80, I spent a few hours fiddling with a Versys rear wheel (17x4.5) and have it fitted... reason being this Shinko E805 170-size is a rather narrow 170 (it’s more of a 160 in my opinion) and was very flattened out on the FZ 5.5” wide rear rim, and besides I thought it was a little silly that a 650cc 70ish HP bike had a super bike sized rear wheel anyways
    Finally I also installed a Rekluse auto-clutch...what can I say, I love not stalling, not feathering the clutch, only drawback I have ever found both on my DRZ400 that has one and this one is it’s necessary to pull the now heavier clutch to find neutral at say a rather extended stoplight or traffic jam, exploring on old Jeep trails/mild singletrack, it’s just plain awesome
    #26
    tjzondrz likes this.
  7. Pablogordo
    Oct 18, 2018
    118
    nola
    Just wanted to add for anyone OCD on front to rear wheel alignment, there's more than a few threads out there on using strings or two bike length straight edges to make the wheel front to back aligned, and its super common on modern bikes with 180 sized rear tires (and even some older bikes) for the rear wheel centerline to be offset more to the brake side (bike will still track straight long as you've got the axles parallel to each other, BUT on swapping out **MY** stock rear 5.5" wide rear wheel for the 4.5"W, I ended up getting the rear wheel alot closer in plane with the front. Took me awhile to get it right, and I ended up spacing the rear rotor outboard, but it's all square now, the hangup now is that looking at the bike from the back, rear wheel looks like it needs shifted back over (out of plane)
    #27
    merc16 likes this.
  8. Pablogordo
    Oct 18, 2018
    118
    nola
    after MANY weeks of waiting, got my new custom corbin seat in (had them shave the pillion low as possible and build up the main seat some to not be locked into one position only. and while I still think its a bit ugly, first impressions of just sitting on it are VERY good, can hardly wait to take it out in a few days
    #28
  9. Pablogordo
    Oct 18, 2018
    118
    nola
    also, on the fr/rr wheel alignment, ended up just putting it back to where it was, as it looked like the frame/seat was bent/tweaked to one side since the frame was designed around the original rear wheel being actually offset to the front.
    #29
  10. Pablogordo
    Oct 18, 2018
    118
    nola
    I guess a bike isn't ever truly finished, but this one is now preeeeety close, thanks for reading, and looking forward to taking it camping in the coming weeks
    #30
  11. TimmyTheHog
    TimmyTheHog Been here awhile
    Jan 11, 2017
    258
    Surrey BC Canada
    Let us know how it runs and handle.
    been debating doing this myself however time and mechanical knowledge is quite short changed here :p...
    #31
  12. Pablogordo
    Oct 18, 2018
    118
    nola
    Well, I've spent a few h0urs on it here and there, what can I say, it rides like a bike!! It's much better to ride at 75mph than it was stock, and handles mild offroad about as good as I can imagine a wee-Strom does, which is exactly what I was going for
    Edited to add that the high speed improvement comes from the nice windbreak the fairing provides, and even tho I prefer the way a naked bike looks, thie fairing was a purely function over form decisiin
    #32
    mminob likes this.
  13. mminob
    mminob MotoHolic
    Mar 24, 2011
    806
    Ocean Beach,California
    Sounds like you had some fun doing all the mods and thinking outside the box on what you wanted to do... nice job :thumb
    Wind protection is nice to have when munching some miles , less strain on your torso... quite a bit warmer too ...
    Your custom Corbin seat looks way better than the standard one ... less of a bucket shape.. Ride safe brother !
    #33
  14. Pablogordo
    Oct 18, 2018
    118
    nola
    Thanks.and yes that was my main hangup on that Corbin all along, too much of a bucket, completely puzzles me why that would be the way they build almost all of them... I like having more than one seating position!
    #34
  15. Year1911
    Year1911 Adventurer
    Jun 16, 2019
    30
    WI
    Really like the look of that custom Corbin seat. Do you think they would be able to do the same for me and my FZ-07?
    The standard Corbin seat never appealed to me, but the one you have is something I might buy. Did they charge extra for the custom profile?
    #35
  16. Pablogordo
    Oct 18, 2018
    118
    nola
    No extra charge, just an extra month wait.....certainly they should be able to replicate it exactly.
    Edited to add, keep in mind the passenger pillion has virtually no padding, be uncomfortable for anything more than an emergency use jaunt
    #36
    Year1911 likes this.
  17. Pablogordo
    Oct 18, 2018
    118
    nola
    Arguably if two-up is the preference, a completely different bike is the choice anyways
    #37
  18. William42
    William42 Long timer Supporter
    Oct 16, 2008
    17,786
    Champaign, IL
    Nice build. :thumb :thumb
    #38
    Pablogordo likes this.
  19. Pablogordo
    Oct 18, 2018
    118
    nola
    I've acquired a larger UK tracer 700 fuel (petrol!) tank, fits exactly like the smaller original...UNTIL the plastics start to go back on..gonna have to get tracer plastics....
    #39
