All the oil came out the bottom drain plug!!
Discussion in 'Dakar champion (950/990)' started by TheLimeyID, Jul 9, 2019.
Tags:
  1. TheLimeyID
    TheLimeyID Off road n00b
    Jun 4, 2019
    123
    ID, USA
    Good to know!
    LOL, is some kind of n00b joke where I end up completely stripping down the bike? :hmmmmm
    Hell, I have the tank off anyway, so why not? =) ...I already have a much greater understanding of many areas of my bike now than I have of any other vehicle I ever owned! After seeing the pictures of the oil pump, I had to go check out how exactly they work. I found a video explaining the basics of it. That's clever!
    Thank-you =)
    #41
  2. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    ...umm, I can see in the manual where it explains how to remove the shift mechanism, and the in the servicing section it says to check the drum and ball bearings for wear, but I can't see anything specifically about pins; ...is it the "guide bolts"?
    The manual unhelpfully just says to check things for wear, but not having new ones to compare against I'm unsure how I'll tell if things are "worn".
    #42
  3. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Ah! Yes, I recall seeing that as well now! Thank-you for the reminder! =)
    #43
  4. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    I just want to make sure I have definitely understood this correctly: the bulk of the oil is held in the oil tank only while the engine is running. When the engine is off the oil can collect in the sump.
    Sorry, if I'm being slow on the uptake on this.
    #44
  5. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,877
    Maine
    One thread I found. Read post 2.
    https://advrider.com/f/threads/transmission-inspection-procedure.1032863/#post-25790120
    #45
  6. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,338
    SWEDEN, Norsjö
    Trying to remember if I ever drained the oil out of a cold LC8.
    Quite sure I have but can't remember all oil coming out of the engine.
    Know I was surprised when draining oil out of the XR400 after an engine failure and all oil was down in engine (has oil tank also) but came to conclusion that it does not have a check valve like the LC8 so that explained oil creeping down into engine case over time.
    /Johan
    #46
  7. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    #47
    roookie1 and nk14zp like this.
  8. charlie264
    charlie264 Long timer
    Oct 27, 2007
    11,819
    Blighty
    Yep. The idea of the check valve is when the engine is cold the crank is not completely submerged in oil. The oil pump draws oil from the tank, filtered it circulates around the engine, then the scavenge pump draws oil from (sump) bottom of engine back to oil tank.
    #48
    TheLimeyID likes this.
  9. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,877
    Maine
    Corect. I checked mine when I did the WP. Didn't realize it was visible looking in the filter hole.
    #49
  10. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Well, the engine had been run for a few minutes and was pretty warm when I drained it and all the oil came out of the bottom plug. However, the bottom screen was somewhat re-clogged up with further aluminium shavings, so it may be that the pump just couldn't suck the oil back up fast enough. I guess I need to just put her back together and run her again for a few minutes and see where the oil ends up. ...I'm procrastinating because I'm worried about damaging the engine, hoping someone has a magic answer. =)
    #50
  11. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Thank-you! It's fantastic how patient everyone is =)
    ...I should stop calling both pumps the oil pump! Scavenge pump and oil pump (or pressure pump?)
    #51
  12. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Do you still have a KTM, or just the KLR?
    #52
  13. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,338
    SWEDEN, Norsjö
    Would for sure install or attach an oil pressure gauge.
    Dummy light is not good enough to tell if oil pressure is good enough.
    As someone said to me in a modern car if it gets oil pressure warning while running its to late.
    On the bike you are down to like 2psi 0,2 bar when light comes on.
    Until someone adds another tire or oil thread, patience for those is short these days.
    When someone has actual problems things are civilized.
    /Johan
    #53
    nk14zp and TheLimeyID like this.
  14. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Thank-you. I was just trying to put together a shopping list of all the things that have been suggested and I didn't have that one on my list!
    LOL, I have heard rumors of the intense disagreements that can arise over those subjects. An oil type was recommended earlier, and I was worried it would cause the thread to go off topic into an oil "discussion". =)
    #54
  15. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    6,366
    West of the West, Oregon
    Exactly. There are two pumps, the main pump sucks oil from the rez and delivers it slowly at high pressure to the engine. The scavenge pump sucks it out of the engine drain area and delivers it rapidly at low pressure to the tank. In normal conditions, these see-saw oil back and forth between the two locations. It only stabilizes with the rez full after 20 minutes or so for you to check it accurately.
    Good thing you stopped when you did.
    #55
    lithodave likes this.
  16. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,877
    Maine
    The klr sits since I got the 950.
    #56
  17. 88gs
    88gs Lc4nicator
    Feb 8, 2011
    49
    Seattle
    As stated earlier, alumni’s soft. I wouldn’t worry to much about the aluminum shavings damaging your motor. As long as the pumps are working and the check valve is unclogged. Just keep flushing the oil until it’s clean and you should be fine.
    #57
  18. The_Eccentric
    The_Eccentric Gearhead. Supporter
    Nov 2, 2009
    267
    Northwestern Wyoming
    You're experiencing the "might as well while you're in there..." affect. Like with most complex machines.........a lot of that stuff is a PITA to get to. When you're in there fixing something else, it just makes sense to take care of as many preventative/eventual fixes as you can.
    Like replacing a clutch in an automobile/truck. While you have the trans and such out, you might as well replace the rear main seal, trans input shaft seal, and pilot bearing. Also might as well check any freeze plugs back there...........and any hoses that are between the engine and the firewall, and.........
    If your luck is anything like mine (Murphy and I are old pals....) and you just fix the current problem.......then the water pump seal or one of the other 'might as wells' will inevitably fail and require to take the damn thing back apart again....
    #58
  19. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Ah!! ...hence you said to run it for 20 mins after adding the initial 2.5L to the oil tank, before topping it up. ...that advice makes a lot more sense now. =)
    #59
  20. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Understandable. Nice to have a backup bike for when the 950 is off the road for maintenance/repairs though, even if it is a KLR. =)
    #60
