1. eNewsletter Sign Up
All the oil came out the bottom drain plug!!
Discussion in 'Dakar champion (950/990)' started by TheLimeyID, Jul 9, 2019.
Tags:
  1. TheLimeyID
    TheLimeyID Off road n00b
    Jun 4, 2019
    123
    ID, USA
    Oh, good. I thought so, but then it seemed odd for the pressure gauge to attach there. I found an offical KTM adapter cheap on ebay, and got an nice little (1.5") gauge off amazon, and got a hose made up earlier this week (measured to the rear cam tensioner hole). I plan to mount the gauge on the left of the dashboard. ...I'll post pictures when I get to that. Once I get the engine back in I'll be rockin!! =)
  2. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    I thought I had a picture of it, but I can't see it. Maybe, I just left it on there so I can take a picture. I'll check this morning.
    It's not a paste, more like "sticks", but more than 1 or 2. =O
    It shouldn't be from the bolt coming loose, as that only shredded the aluminium clutch case (of which I now have a picture)....
  3. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Ah, thank-you! I'll do that. =)
    ...so, what are they venting? ...excess pressure?
  4. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    OK, I got some footage of my oil plugs: https://photos.app.goo.gl/o6niGYHAJhDy9wyw8
    Also, I was looking at the carb vacuum ports.
    Those are where I would connect my carb balancer ( 20190803_083957.jpg )? So, could I just seal the ones on the offside by replacing the ports with a couple of bolts? Then attach hoses to the remaining two, for easy access when checking balance?
  5. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    14,180
    Mill Spring, NC
    They vent the vacuum slide diaphragms. Without the proper venting you will get all sorts of erratic behavior..
    TheLimeyID likes this.
  6. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    6,106
    West of the West, Oregon
    Don't try to take out the brass fittings. 50/50 chance you'll snap them off 100% of the time.
    I've found the rubber caps from the auto store just don't last. Probably happened to you. Instead, put a piece of hose back on and insert a bolt or screw to block it. Zip tie it tight or wire it to keep it from popping off if you get a back fire. Not pretty, but who's going to see it.
    And that's a yes. Run two hoses back to under the seat for balancing. Block the others. If two of the brass ports have very small holes, use those for your balancer. It makes the pulses a lot smoother.
    nk14zp likes this.
  7. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,876
    Maine
    I set my balance at 4k or a bit above.
  8. uk_mouse
    uk_mouse Aquatic adventurer
    Jul 20, 2006
    1,958
    UK
    To be pedantic, I think those hoses actually vent the float bowls. If you get pressure fluctuations in the bowl you get erratic fuel levels, leading to inconsistent mixture.
    Boatman and TheLimeyID like this.
  9. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Thank-you! That is all very useful information!
    Is this connected to the "popping" on deceleration?
  10. Boatman
    Mar 9, 2005
    14,180
    Mill Spring, NC
    Touche
  11. lithodave
    lithodave brachy850
    Jul 29, 2013
    94
    I have been experiencing this problem! (Dry sump) I measure the fresh oil going in after changing. Start engine, idle a few minutes, shut off. Check the level, and it needs topping off. I go for a ride, come home and check the level and it is over full. I thought I do something wrong. I just did not run enough to equalize levels in sump as well as tank . Thanks!
  12. radmann10
    radmann10 Derf Supporter
    Apr 29, 2014
    1,251
    Phoenix, AZ
    Great info here...thanks for that!
  13. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    It certainly is!! :clap
  14. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    I didn't get to it over the weekend (too much time on here Saturday morning :shog, then later back on Sunday than expected).
    Slow going tonight. I thought I'd start by removing the clutch and getting into the oil pumps, water pump, pressure release valve, etc. However my first hurdle was not having a 31mm socket (a trip to Napa fixed that), then I find I need a special tool to lock the clutch inner hub to the outer. Well, I don't have it so I made a better tool...
    ...the nails align with the spaces in the inner and outer hubs, locking them together (for the record, I pre-drilled the holes for the nails, I'm not that good).
    Then it fits on like this...
    However, it's either on there like a mother f****r, or I'm doing something wrong. I'm loath to just crank it down hard and break something, so though I'd check on here first.
    ...it undoes anti-clockwise? ...like a regular bolt! :hmmmmm
    Whodatschrome likes this.
  15. mountaincadre
    mountaincadre Long timer
    Jul 18, 2012
    1,808
    Mid Calder,Scotland
    Yes, its on with locktight 243 and 110nm so a wee bit of ooomhp is required.
  16. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,260
    SWEDEN, Norsjö
    First time breaking that nut loose on the 950. After failing with cheapo impact tools I ended up locking rear wheel and had bike on its side, long pipe on the tool, had to lay next to bike and feet to stop it from pivoting.
    Like a gunshot when it came undone, thought tool snapped.
    Never any issues since.
    And a 32 mm socket have worked fine.
    Did borrow the odd 31 mm first time around.
    Good luck with engine on a bench
    Lately been wrenching with forest machines and all of a sudden motorcycles seem so easy.
    /Johan
    nk14zp, mountaincadre and TheLimeyID like this.
  17. uk_mouse
    Jul 20, 2006
    1,958
    UK
    When all you have is a hammer... :)
    As others have said, that nut has threadlock on it, so hit it with a blowtorch. Or trade in your hammer for an electric impact wrench, they really are rather useful! :D
  18. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Thanks everyone!
    This morning's project will be to strap the engine down to the table, get a length of pipe on the socket handle, and get that nut undone! :thumb
  19. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    ...I keep seeing KTM's on the road round here now that I'm off it. ...I haven't managed to run any if them into the ditch so I can "borrow" their engines though. :lol3
    nk14zp likes this.
  20. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    3,126
    North of North Plains
