1. eNewsletter Sign Up
All the oil came out the bottom drain plug!!
Discussion in 'Dakar champion (950/990)' started by TheLimeyID, Jul 9, 2019.
Tags:
  1. TheLimeyID
    TheLimeyID Off road n00b
    Jun 4, 2019
    123
    ID, USA
    That is pretty sweet. It never occured to me to search for a clutch holder tool. I just searched for the official part number, and found $30+ prices! :doh
    ...maybe I'll order one of those for putting it back together (I'm assuming I'll need something), but my super tool worked great for getting the nut off. ...I had to strap the end down to the table, and use a 4' length of scaffold pipe on the socket handle, but I got it! :happay
    Breakfast now! =)
    DirtyADV and mountaincadre like this.
  2. mountaincadre
    mountaincadre Long timer
    Jul 18, 2012
    1,798
    Mid Calder,Scotland
    Good job limey,
    TheLimeyID likes this.
  3. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,876
    Maine
    Compared to working on logging machines these are toys. And they need little tools.
    Boatman and TheLimeyID like this.
  4. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,251
    SWEDEN, Norsjö
    Have brought in the excavator at times removing bolts. You know it was on there well when there are sparks flying when things come undone.
    And had to go with a long pipe on the already big torque wrench when you need over 1000 Nm on some of the bolts.
    And here is a way to lock engine when on bench:
    https://flic.kr/p/fZTGmk
    And Euro cents are stronger then pennies if putting a coin between sprockets:
    https://flic.kr/p/k5jMWF
    /Johan
  5. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Thank-you. It would have been pretty scary putting that much pressure on there without all the feedback I received; so thank-you all.
  6. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Wow, 1000Nm??
    I was confused which way up that engine was. I couldn't see the heads, or where they would go. ... then I noticed it was a Honda, not an LC8. :hmmmmm
    Unfortunately Euros are hard to come by here :2cry
    DirtyADV likes this.
  7. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,251
    SWEDEN, Norsjö
    My bad was only 900 Nm =) at least its toys compared to the machines at work, they removed a hydraulic cylinder to be repacked and it weights 8 metric tones (probably like a billion pounds ...no not that much only 17636 lbs).
    Luckily I avoided getting involved in removing that and it was sent to a mechanic workshop for the job.
    No Euros in Sweden either, just some monopoly money that lately have dropped alot in value =(
    And no suitable copper coins anymore either they were discontinued some years ago but have some suitable coins in the garage when need is, luckily not that often =)
    /Johan
    TheLimeyID and nk14zp like this.
  8. KPuusepp
    KPuusepp It's a f***ing 950 adventure...
    May 21, 2013
    115
    Estonia
    Or use sucky sucky showy showy tool and block the holes. I broke my nipples and had to punch in an hex key to get it loose. Then regular copper washer and block off bolt.
    https://classiccarbs.co.uk/product/...n-carbscarburettors-airflow-metersynchronizer
    Have balanced quite lots carbs with this tool. Double checked also with regular tube method and same.
  9. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    What is the sucky sucky showy showy tool??
    OK, OK, I won't touch my vacuum ports!! =D
    Looks nice, but I'll stick with my good old homemade mason jar one for now 20190803_083957.jpg . ...saving as much money for engine parts as I can right now. but thank-you for the suggestion! =)
  10. KPuusepp
    May 21, 2013
    115
    Estonia
    Its the same thing I posted
  11. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Oh, I see! Sorry, slow on the uptake there. =D
  12. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,876
    Maine
    That mason jar thingy is 10 times more fancy than my tubing taped to a stick.
    Boatman likes this.
  13. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Yep, I went all out on it!! :D
  14. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,251
    SWEDEN, Norsjö
    Am I the only one thinking moonshine seeing them?
    /Johan
    nk14zp and TheLimeyID like this.
  15. nk14zp
    nk14zp Long timer
    Feb 24, 2010
    2,876
    Maine
    I was thinkin hookah or bong.
  16. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    I just checked my valve clearances...
    Three of the intake valves are less than .102mm (my thinnest gauge won't go in at all), the other is about .127, so just about enough.
    Of the exhausts, one is only about 0.180mm, and the others seem to be spot on.
    It seems odd that they are too tight, I thought they wore down and the gaps got bigger!? :jjen
  17. roookie1
    roookie1 Been here awhile
    Jun 15, 2009
    463
    Denmark
    The valves are moving up in the seats. Normal for the lc8
  18. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Oh, ok. Yet more that I've learned! Thanks! =)
    ...I just change the shims to get the correct clearance, and that's it?
  19. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    I realised I wasn't thinking when I ordered the new water pump "seal", I only bought a gasket! I just ordered part number 0760123073, which is number 10 on this page. I hope that's the right thing.
    I also ordered the iridium CR8EIX plugs as mine looked a little on the crusty side. I'm assuming they're somewhat older, as they have the double metal hooks on the end, over the pointy bit, whereas I can only find ones with a single hook available now.
    I figured a new air filter wouldn't hurt either while we're at it, it was looking a bit grungy.
    I got the hoses for the airbox so I can vent the carbs properly, close off two of the vacuum ports, and run hose from the other two. ...oddly I have three small ports, and one bigger one, not two and two.
    Thanks to someone for suggesting getting a 16mm socket and grinding it down to fit in the spark plug hole. I did that, then found I do have the KTM one in the toolkit. No idea how I managed to miss that before, so now I have one for the bike and one for the toolbox.
    I've got a question regarding the toolkit sockets though. I only have the 6mm and 10mm sockets for the hex T-wrench. I was going to get an 8mm one, but I can't find one. When I search all I get is sockets with 8mm hex drives for square drive wrenches. Is there a term I don't know that I should be searching for, or could someone point me in the direction of some?
    Another question, what is the advantage of the "ear clamps", over regular worm drive hose clamps? Is it just the possibility of the worm drive ones unscrewing from the vibrations, etc?
    After looking at the lack of wear on the crankshaft bush in the clutch case (over Google Hangouts with my Dad, which is not easy), and with how slow this project is progressing, I'm contemplating just putting the engine back in the bike with all the problems discovered so far fixed and the upgrades done, crossing my fingers and seeing how it goes. I'm missing my riding!! :ricky
    mountaincadre likes this.
  20. TheLimeyID
    Jun 4, 2019
    123
    ID, USA
    Just to confirm, I need the 10mm shims for a 2006 950?
    I've read many people mention buying the Hot Cams shim kit, is that brand better? ...there appear to be other options, such as Moose Racing?
