All Things Bonneville
Discussion in 'Road Warriors' started by rider33, Oct 27, 2014.
  1. ghoststrykre
    ghoststrykre Been here awhile
    Aug 9, 2019
    116
    Dayton
    good to know.
    chain and sprockets are due to be replaced. Both front and rear sprockets. Was trying to make it through this riding season before replacement.
    A bit over 15,000 miles on the odometer and still the original chain and sprockets. I’ve been checking them every time I clean and lubricate the chain and everything is in spec except the chain, which only recently started showing the signs it was time to replace. I was just trying to squeeze out these last few months.
  2. kickstandsup
    kickstandsup Devout Atheist Supporter
    Mar 21, 2013
    5,038
    Kitty litter USA
    Well, the situation should be pretty easy to replicate, and now that you know there's an issue, you can be looking/listening for a possible cause. If it is detonation, rolling off even just a little should make it go away immediately.
    And as an aside, why cruising in 4th at 75 mph?
    Steve516 likes this.
  3. ghoststrykre
    Aug 9, 2019
    116
    Dayton
    I’ll do my best to replicate shortly and see, but I do believe even slightly rolling off and the sound vanishes. Really sounding like detonation, as you all describe.
    and traffic was at a state that I wanted that 4th gear grunt and potential engine brake. RPMs are still pretty calm at that speed in 4th. 5th really just feels like an overdrive on the ST. I’ll confess that 75 is where I start thinking about going to 5th.
  4. geolpilot
    geolpilot Been here awhile
    Nov 3, 2011
    354
    Texas Coast
    It could also be a bad bearing in the sprocket carrier. That happened to my bike and the bearing was literally falling apart.
    ghoststrykre likes this.
  5. ZappBranigan
    ZappBranigan Still Riding
    Aug 7, 2007
    1,962
    Littleton, CO
  6. rixcafe
    rixcafe Been here awhile Supporter
    Jan 23, 2007
    945
    Durham, NC
    Great ride today, so much fun.
    Bugchewer, Rick G, HapHazard and 4 others like this.
  7. s.ga.rider
    s.ga.rider Been here awhile
    Feb 1, 2016
    430
    Ga
    Anyone found handlebar risers that work on the 2012 se? I ordered 2 different sets from amazon that said they fit but the bolt holes were just a tad off and wouldnt mount.
  8. rixcafe
    Jan 23, 2007
    945
    Durham, NC
    2009 and later fuel injected Thruxton handlebar mounts are taller than Bonnies and may work for you.
    s.ga.rider likes this.
  9. DeepBarney
    DeepBarney International Bumbler
    Jan 7, 2014
    4,011
    Wichita, KS
    Finally got around to tossing the new suspension bits at my bike. Hagon 2810 shocks for out back and Ricor Intiminators along with some new 5wt fork oil (as recommended by Ricor) for up front.
    I'm lazy so I took the easy way out and used a vac pump to remove the oil with the forks in-situ after I pulled the spacers and springs. Since the oil that was in it wasn't very old and only a bit heavier, I wasn't that worried about getting every last drop out.
    Tossed in the Intiminators and then added the factory prescribed oil quantity in each fork. Had to take a few measurements and do some math to find the proper setting for my motion pro oil level gauge to correct for the forks not being vertical. Way less headache than pulling the forks.
    New vs old. The Hagons while heavier than the failed TEC's, are still a few pounds lighter than the stock units. They don't have inner metal bushings like the stock units, so they got a bit of grease to reduce binding of the rubber. The rubber bushings are also about 5mm to wide for the mount. A Google search shows plenty of others have ran into this when fitting them to their Bonnevilles. Some have trimmed the bushing down so it isn't proud of the eyelet. Seems most just tighten the bolt down and don't worry about it. I chose the latter path. I can always go back and trim them.
    TimmyTheHog, HapHazard and rixcafe like this.
  10. AdvBike
    AdvBike Adventurer
    May 23, 2017
    44
    does anyone know if exhaust pipes from newer Bonneville models (straight pipes without the kink) would fit on older carburated Bonneville models (ones with pipes that have the kink) ?
  11. Cheshire
    Cheshire Been here awhile
    Feb 27, 2009
    385
    Winston-Salem, NC, US
  12. DeepBarney
    Jan 7, 2014
    4,011
    Wichita, KS
    You may have already considered this, but in case you haven't you could always drill out the bolt holes in the spacers to give you the clearance you need to pass the bolts through. As long as you got the spacers and clamps lined up before you put the final squeeze on them they should look and work just as intended.
  13. AdvBike
    AdvBike Adventurer
    May 23, 2017
    44
    refining the question a bit: would T120 exhaust pipes fit a T100?
  14. shaner1100gs
    shaner1100gs Been here awhile
    Nov 23, 2005
    581
    Laurel, MD
    So how do the new shocks handle? I have the Ricors with works dual rate springs and a set of Works shock. I like the set up a lot.
  15. DeepBarney
    Jan 7, 2014
    4,011
    Wichita, KS
    Still developing an opinion. But initial thoughts about to good, better than stock. Firm but compliant, seems an apt way to sum it up. Initial brake dive is gone, it's not until you keep squeezing and slowing the bike that it begins to dip (though much less and slower than stock, more controllable). The forks don't "crash" under hard braking or potholes/expansion joints/other road irregularities etc. like they used to. The back end definitely is better than stock but I'm not sure how to put it to words. I've got it set in the middle for damping and I think I need to play with that some, just not sure which way it should be going.
    rixcafe and HapHazard like this.
  16. rudolf35
    rudolf35 Warped & Twisted Mind
    Jun 15, 2008
    1,069
    Arlington, TX
    FYI, I had Hagen shocks on a lot of bikes and they do break in. After about 500 miles the take on a much more subtle feel; almost like Corbin seats.
    DeepBarney likes this.
  17. DeepBarney
    Jan 7, 2014
    4,011
    Wichita, KS
    Yeah I'm counting on that as well. Probably still a bit of stiction in the seals.
  18. squish
    squish Out of the office.
    Dec 4, 2003
    10,188
    Where the Ghetto meets the sea.
    I sort of doubt they would just bolt on since the watercooled bikes, use a pre muffler under the front of the engine and the exhaust pipe is fake for about 3 inches just after the bend.
  19. B02S4
    B02S4 Aye
    Mar 9, 2009
    2,343
    Martin Moto, Boyertown PA classic ride in show, 9/25/21... for some reason, this Bonnie with a build date from 2013 was my personal favorite:
    Bonus points...my 2007 SM is parked on the street below, next to a pristine Harley XR1200...& my bike's speedo is visible just below the kill switch wiring on the T-100.
    Tritwin, TonyKZ1, Philthy64 and 2 others like this.
  20. rixcafe
    Jan 23, 2007
    945
    Durham, NC
    Yesterday escorted Dan to Hanging Rock State Park. He is on a two month ride to nowhere in particular up from Florida. While I am a credit card and toothbrush traveler, Dan is not. Perfect day for a long ride.
