1. eNewsletter Sign Up
alternator brush replacement
Discussion in 'Airheads' started by mslim, Dec 25, 2019.
  1. mslim
    mslim If it's worth doing... it's worth overdoing
    Jan 11, 2015
    1,336
    Austin of the Ozarks
    I was just contemplating why the Factory used soldered leads to the alternator brushes? Wouldn't it make more sense to have the leads provided with a ring terminal already soldered to it to make them easier to replace? I noticed EME offers a complete brush holder assembly with ring terminal brushes. How big a soldering gun does it take to R&R the brushes? I've got a nice Hakko iron for electronic work and a big old classic Weller 550 gun.
  2. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    7,483
    The Weller will get it done, but the risk of solder following the braided wire is fairly high. After I saw EMEs solution, I thought, Why didn't I think of this 30 years ago?"
  3. Richarde1605
    Richarde1605 Long timer
    Jan 1, 2015
    4,865
    QLD Australia
    Hold the braid with needle nose pliers or similar close the the solder joints to reduce the “wicking”.
    spo123, mslim, bmwrench and 1 other person like this.
