alternator output
Discussion in 'Dakar champion (950/990)' started by pistilpete, Feb 22, 2006.
  1. MrSandman818
    MrSandman818 INaVANdownBYtheRIVER
    Dec 29, 2009
    868
    Raeford, North Carolina
    Im not sure what the actual output is but I can tell you that my 05' 950 adv so far has had no trouble running my 55watt hid low beam, 90watt heated jacket liner on full blast, heated boot liners on all the way, heated grips turned up all the way, Garmin gps, 175watt mini power inverter to charge the good ole Iphone while riding, and my new led fog lights while doing my 4 day Olympia Peninsula trip. Started right up every morning with no issues even though it dropped to 40ish degrees and rained cats and dogs on day 4.
    #21
  2. Qwik
    Qwik Adrenaline Addict
    Apr 27, 2008
    7,788
    Basalt Colorado
    Was running Euro Headlight, Heated Grips, Heated Vest, and a set of Lightforce 140 Lancers Auxiliary lights and never had an issue.
    #22
  3. Geek
    Geek oot & aboot
    Jun 8, 2003
    35,344
    8000ft.
    FWIW I have my bike setup with heated grips, a permanent dual heat troller (I have gerbing jacket & pants) as well as aux cables to charge iphone and run the GPS etc.
    What I've done is installed a volt meter in the left fairing and I just keep an eye on it during times of high usage. If it starts to get a bit low I turn things down.
    Its also useful at camp at night... I can charge accessories, etc around camp and make sure I don't run the battery down too much.
    Food for thought :freaky
    You can see my voltmeter in the left fairing:
    #23
  4. DELTATANGO
    DELTATANGO Motorcyclist and Dog Walk
    Nov 27, 2005
    18,455
    Alabama
    LED lights save a lot of juice.
    #24
  5. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    6,913
    West of the West, Oregon
    The DRZ puts out more like 187 watts at 7000 rpm.
    The LC8's 450 watts is at 6000 rpm? How many ride around at that rpm? Better plan on about 350 watts at normal riding speed.
    The BMW uses a real alternator that runs at 2x to 3x engine speed. It's regulator changes the output of the alternator. This is great, but it's heavy and complicated.
    #25
  6. Gustavo.Ramos
    Gustavo.Ramos Long timer
    May 19, 2008
    1,251
    Accross the pond
    #26
  7. DELTATANGO
    Nov 27, 2005
    18,455
    Alabama
    Ha!:lol3
    #27
  8. DELTATANGO
    Nov 27, 2005
    18,455
    Alabama
    neato
    #28
  9. mtbtweety
    mtbtweety Adventurer
    Aug 16, 2009
    84
    Bentonville, AR
    Old thread revivial...
    While I understand alternator output, doesn't this also imply a very healthy battery? If the battery isn't particularly healthy, isn't it more likely that a higher electrical load will deplete it faster?
    #29
  10. Blackalac
    Blackalac Been here awhile Supporter
    Jul 30, 2010
    162
    Rochester NY
    When the bike is running and the battery is fully charged, the battery knows nothing about what the bike's load and the alternator charging rate is. The current to operate the bike flows from the voltage regulator into the motorcycle's electrical system without entering or leaving the battery The battery does smooth out the electric while the bike is running.
    #30
  11. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,070
    East Med, Greece
    Then the R/R starts filling it up, as well as keeping up with the demand of the bike and accessories. If the draw exceeds the R/R capability, it will start feeling the gap. If that goes on for too long, it will get depleated. I never heard of this happening. If ABS operate, that could overload the system, but that cannot last.
    Leds are very helpful saving power.
    Cheers.
    #31
