AltRider bash plate installation
Discussion in 'Parallel Universe' started by Jacque, Jan 29, 2020.
  1. Jacque
    Jacque Adventurer
    Sep 5, 2019
    62
    PacNorWest
    Trying to install an Altrider skid plate and I’m having a heck of a time aligning the front through bolt so that it engages the threads. I’m at the point of pulling the pipes. Anyone have any ideas or similar problems? And if so how did you get through it?
  2. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    6,876
    South Jersey... Close to the Pines
    IIRC The bracket that the bolt goes through is bolted to the plate? If so loosen the bolts that hold the bracket to the plate so it can float. Do not tighten any bolts until all the bolts are started.
  3. Jacque
    Jacque Adventurer
    Sep 5, 2019
    62
    PacNorWest
    All the flange nuts are only installed to the second thread (everything is loose) and the through bolt inserts 90% but will not start thread engagement on the blind nut.
  4. dpike
    dpike BeeKeeper Supporter
    Nov 21, 2015
    1,819
    New Jersey
    put a floor jack under the plate and put a little pressure on it, the damping bushings on the bottom probably just need to be compressed a bit if they're new.
  5. Jacque
    Jacque Adventurer
    Sep 5, 2019
    62
    PacNorWest
    Thanks dpike, I have, i just cant find the sweet spot.
  6. dpike
    Nov 21, 2015
    1,819
    New Jersey
    Maybe give those tabs on the skid a few taps with a hammer in the direction you need them to go.
  7. Jacque
    Jacque Adventurer
    Sep 5, 2019
    62
    PacNorWest
    Thanks for all the help. It is finally installed.
    SnoDrtRider and dpike like this.
