    Dismiss Notice
Aluminium Panniers leave everything black
Discussion in 'Equipment' started by Scooterpt, Jun 29, 2020.
  1. Scooterpt
    Scooterpt GS 800 Adv
    Apr 29, 2013
    19
    Lisbon, Portugal
    Any moving thing that I leave in my aluminium topbox or panniers gets black from the rubbing, besides the obvious using a bag, is there any way to clean the insides to stop this?
    thanks
    sidetrack one likes this.
  2. rider1150gsadv
    rider1150gsadv Long timer
    Oct 6, 2003
    9,645
    Ft Likkertail , USA
    Outdoor carpeting is one option, I used bunkbed carpet for boat trailers only because I was in the marine industry. Also some peeps have used self adhesive kitchen shelf stuff.
    Paint is also an option but you really need to do it the right way by using aluminum primer and epoxy paint with the right prep work.... YMMV
    Eatmore Mudd and Scooterpt like this.
  3. blender
    blender Just another rider
    Jul 27, 2004
    1,177
    Wisconsin
    I sprayed the insides of mine with truck bed coating. Be careful of the brand, some result in a rough surface. IIR the brand I used is from Duracolor, leaves a somewhat smooth pebbly surface.
    Eatmore Mudd likes this.
  4. dddd
    dddd Long timer
    Jan 15, 2012
    1,404
    Montreal, Canada
    Pickup truck bed coating as mentioned is the right direction/idea.
    I would have tried plastidip but it will not be perfect and sharp things will punch through and may it flake. However this is its nature; it not permanent and can be removed if you dont like it.
    You would have a lot of color choices with plastidip (white or clear comes to mind, to liighten up this hole).
  5. Tsotsie
    Tsotsie Semi-reformed Tsotsi Supporter
    Nov 12, 2007
    2,714
    South Texas
    As per Rider1150 above.
    Go to HD or Lowes and get the stick-on flooring carpet sections/squares. Their strip adhesive can be helped with a can of spray adhesive too. Did my bags in 2009 and they are still great after about 95K miles.
  6. squish
    squish Out of the office.
    Dec 4, 2003
    9,460
    Where the Ghetto meets the sea.
    peel and stick flooring tiles, Contact peel and stick shelf liner, Liner bags
    Paint or powder coat the inside.
    Are all ways to help it, but uncoated aluminum will do that, it's even worse if there's any water in there.
  7. francs
    francs Been here awhile
    Jul 1, 2008
    391
    Ljubljana Slovenija
    adhesive foil
    It's inside and it's don't need to be perfect.
  8. YesRush
    YesRush Long timer
    Aug 17, 2014
    3,733
    Va
    Vinyl wrap it.
    #8
  9. Scooterpt
    Apr 29, 2013
    19
    Lisbon, Portugal
    Not a bad ideia, thanks mate
    #9
  10. MCMXCIVRS
    MCMXCIVRS Long timer
    Nov 13, 2006
    1,664
    Calgary, Alberta, Canada
    I used tool box drawer liner held on with spray adhesive.
    #10
    Eatmore Mudd and Fosters like this.
  11. Beelzebubbles
    Beelzebubbles RRG Dirtbag
    Mar 13, 2014
    8
    Somewhere in the Red.
    a few pieces of strategically cut astroturf or outdoor carpet will work nicely. Might cut down on rattling and noises too. I’d assume clear coating the inside of the cases or painting would work too if the carpeting isn’t an option.
    #11
  12. NorseCycles
    NorseCycles n00b since 2008 Supporter
    Aug 1, 2008
    220
    SW CO DRO
    I had a set of Happy Trails panniers rinolined in white. Easy to see into case and no black sh*t on my stuff.
    #12
  13. Vrode
    Vrode Not my problem Supporter
    Jan 21, 2014
    5,117
    Vermont
    Go over the insides with some steel wool and spray them with some clear coat. Still look original but won’t leave aluminum residue.
    #13
  14. cug
    cug Out riding ... Super Supporter
    May 31, 2009
    7,424
    Sunny California
    I couldn't be bothered with creating a pleasing, clean solution, my aluminium top case has a bottom inlay and the rest I've just put gaffers tape on. I don't care how it looks, it works.
    #14
