An Unholy Union V: DRZ forks on an Airhead
Discussion in 'Airheads' started by Ras Thurlo, Jun 28, 2014.
  1. Ras Thurlo
    Ras Thurlo Desert Lion
    Aug 5, 2010
    884
    Hillcountry, Italy
    Given the recent production run of DRZ triple clamps for airheads by Prutser, its time for a dedicated thread on the topic of DRZ fork airhead conversions.
    There are several historic discussions on DRZ conversions, but not one central thread.
    tac650 likes this.
  2. Prutser
    Prutser Long timer
    Aug 5, 2012
    2,073
    The Dutch swamp
    Ok :D
  3. OLD GREEN
    OLD GREEN Long timer Supporter
    Sep 6, 2009
    2,151
    N.W. Oregon
    Alright, let's see some pictures of those bolted up to some bikes!
  4. bgoodsoil
    bgoodsoil Dare to be Stupid
    Jul 9, 2008
    4,724
    Washington, DC, USA
    +1 :lurk
    I wish I had gone with DRZ forks way back when instead of the DRs but I didn't know they were height adjustable at the time.
    What offset did you go with on those triples?
  5. shearboy2004
    shearboy2004 KIWIINUSA Supporter
    Jun 28, 2007
    5,026
    Ft Collins ,Colorado
    I was looking it this exact idea last light , wanna know all about it ! If I could buy triples and forks as a bolt on I would all over it like a fly on shit !!!
  6. Phreaky Phil
    Phreaky Phil Long timer
    Mar 18, 2006
    3,056
    NEW ZEALAND
    Not as many in my collection as Pruster
    A 320mm Warp 9 rotor :D
  7. _cy_
    _cy_ Long timer
    Sep 25, 2011
    6,846
    Tulsa, Oklahoma
    any chance you could provide link .. can't seem to find it.
  8. ML WYDELL
    ML WYDELL NED
    Apr 10, 2009
    570
    Looking for fuel
    What year DRZ forks are you using?
    #8
  9. Clay Spinner
    Clay Spinner Been here awhile
    Nov 6, 2008
    771
    Nova Scotia
    Or should the question be 'what year forks are the best or most suitable for this application'?
    #9
  10. Ras Thurlo
    Aug 5, 2010
    884
    Hillcountry, Italy
    no specific thread (until now)
    #10
    elite-less likes this.
  11. Ras Thurlo
    Aug 5, 2010
    884
    Hillcountry, Italy
    fyi
    #11
  12. Ras Thurlo
    Aug 5, 2010
    884
    Hillcountry, Italy
    exhibit 1:
    exhibit 2:
    on a DRZ as mamma nature intended:
    (whole front-end would work well on an airhead)
    #12
    Jimkav likes this.
  13. Prutser
    Prutser Long timer
    Aug 5, 2012
    2,073
    The Dutch swamp
    There are no pictures yet. The triples came in last friday and we are still waiting for the stems to be finished.
    I wil post some pictures a.s.p.
    The triples have 28mm off-set.
    Shortening those DRZ forks is done in the same way as all the other cartridge forks, by putting a spacer on the cartridge rod on the inside of the cartridge.
    Some pictures of the different DRZ400 forks. These are all 49mm right side up forks. I still don't know on what model DRZ or the years the forks are used on.
    The first fork: with pre-load adjustment.(fork without a cartridge but does have compression adjustment on the bottom)Not the one to use for the best result.
    The fork with re-bound adjustment on the top cap.(this is the fork to buy)
    One specially for Jason:wink: RM fork with closed cartridge (very good for your race bike)
    Picture of the bottom with the compression adjuster (which all the drz
    forks have as far as I know)
    #13
  14. Prutser
    Prutser Long timer
    Aug 5, 2012
    2,073
    The Dutch swamp
    The good thing about those DRZ forks is that they are CHEAP most of the time.
    And they are really good forks. An even better thing is that they fit in our airheads without too much trouble.
    Using the DRZ head bearings and a thick washer and they fit.
    They can also be shortened pretty easy just like most upsd forks by putting a spacer in the cartridge.
    Dmaster(David) and me are often using our airheads for big bike trial riding.
    The stock DRZ triples will give the bike a lot bigger turning circle compared to the stock G/S and GS forks and triples.
    Because the stock DRZ triples have less off-set than the stock BMW triples and the tubes are bigger in diameter they will hit the tank and/or the frame.
    The fork clamp bolts on the bottom DRZ triple are on the rear and are hitting the frame a bit too soon for comfort.
    You can take some material off where the top of the two bolts screws into the plate to make it a bit better but there is still not that much turning space.
    To make our bikes better suitable for what we like to do with them we decided to make our own triples that would fit our bikes. The minute I mentioned those triples people started to ask about them. So than we decided to make a few more.
    Thats how the whole thing started :D
    #14
    lurcher1000 likes this.
  15. Prutser
    Prutser Long timer
    Aug 5, 2012
    2,073
    The Dutch swamp
    A few things we tried to pay attention to:
    Not to much off-set but just enough to get as much clearance as needed.(28mm)
    Tubes are spaced 10mm wider than the DRZ tubes (200mm)
    clamp bolts on the front side.
    They should work on the G/S and the GS frames.(using different screw in steering stops)
    Holes to mount stock BMW headlight unit are in the triples.
    Stock fender bolts straight on.
    Comes with a Metal stem for BMW head bearing sizes.
    The top nut and adjuster nut are both BMW parts and can still be ordered from BMW if you need them.
    Holes in the bottom triple to take off the bearings.
    10mm thread in the top triple to mount handle bar mounts. Two positions
    Two holes in the top triple to mount a steering damper.
    Holes in the front to mount brake line guides or indicator mounts.
    Wing shaped bottom triple to make sure all the travel in the fork is usable if needed.
    Enough space behind the headlight bucket to route all the cables without the need of spacers between the triple and the headlight bucket.
    #15
  16. Prutser
    Prutser Long timer
    Aug 5, 2012
    2,073
    The Dutch swamp
    #16
  17. walkingbear
    walkingbear Lets Play Chicken! Supporter
    Jun 5, 2004
    5,251
    Scottsdale AZ..
    do you have a cost for a set?
    #17
  18. shearboy2004
    Jun 28, 2007
    5,026
    Bloody beautiful work ! Want ! cash in hand .:deal
    #18
  19. Prutser
    Prutser Long timer
    Aug 5, 2012
    2,073
    The Dutch swamp
    They will be 630€ for the set. Including the stem.
    #19
  20. walkingbear
    Jun 5, 2004
    5,251
    Scottsdale AZ..
    is that 630 euros?
    630 EUR
    861.83311 USD
    #20
