1. eNewsletter Sign Up
An Unholy Union V: DRZ forks on an Airhead
Discussion in 'Airheads' started by Ras Thurlo, Jun 28, 2014.
  1. Desmodue
    Desmodue Adventurer
    Aug 30, 2019
    94
    Pnw
    That’s exactly what I did. Workers great. 1/4-20 (i know, should be metric)
  2. blaine.hale
    blaine.hale Long timer
    Feb 28, 2009
    4,308
    Atlanta, Ga
    What did y'all do for cable length on the handlebar controls? Mine are a couple inches short, with the new forks. I noticed the G/S and ST units are the same part number. Thought I could get away with ordering longer G/S ones but that doesn't seem to be true.
    Edit: I keep seeing that you need to route the wires "correctly." Anyone have pics of that, because it looks like mine are routed the stock direction. They go behind the brace and straight over to the 2 connections. I don't really see any other route that's more direct that would allow more length. Don't have a good pic of my route but this is where I am on the build:
    The Patagonia Kid likes this.
  3. radmeister
    radmeister Been here awhile Supporter
    Mar 23, 2010
    451
    The Creek - Stoney Creek, Ontario
    I am presently mounting 2 inch rocks risers with tomaselli handlebars on my r80st . It appears that all cables fit with the exception of the choke cable which is about 1/4 inch too short. I’m going to try to reroute the choke the choke cable but I won’t get to this for a couple of weeks because I am also replacing the steering head bearings which I have not yet ordered.The electrical cables on both sides of the handlebars have to be rerouted so that they do not pass through any part of the frame because they are not long enough to be “correctly” routed with the rocks risers installed. comfort trumps form. at least for an older guy like me.
    some more limber than i can take it back to stock in twenty years.
  4. Jim K in PA
    Jim K in PA Long timer Supporter
    Mar 15, 2011
    4,749
    Pocono Mountains, PA
    FWIW, I used throttle cables and switch harnesses for the US R100RT with the high bars, and they fit fine. I converted to manual choke pulls on the carbs. Routing is still important, even with the longest cables from der Vaterland.
  5. blaine.hale
    Feb 28, 2009
    4,308
    Atlanta, Ga
    My choke, throttle and right side controls are all perfect and route cleanly. It's just the wires coming from the left controls that are way short.
    Anyone have a photo of how their left control wires route, by chance? The DRZ setup really only raised my bars about an inch and pushed them back towards the tank maybe 1/2"
  6. hardwaregrrl
    hardwaregrrl ignore list Supporter
    Jan 26, 2006
    9,929
    Atlanta
    I don't have any good pics, I'll have to take the tank off to get a look but I believe I added some length to the harness.
  7. Motopsychoman
    Motopsychoman Not a total poseur Supporter
    Jun 2, 2013
    5,033
    Oaklandish
    I'll look for pictures, but I know I had to reroute both switch cluster cables behind the upper triple clamp instead of the original routing frontwards.
  8. Motopsychoman
    Jun 2, 2013
    5,033
    Oaklandish
    You can just see the left side controls cable in this pic.
    I'm sure I have another picture after I prettied this all up. I'll keep looking.
  9. GrahamM
    GrahamM Been here awhile
    Jul 15, 2008
    988
    Peterborough, Ontario, Canada
    wholly are you 7ft tall? those are some serious risers
  10. Motopsychoman
    Jun 2, 2013
    5,033
    Oaklandish
    Not using the OEM bar. ProTaper bar with a lot less rise. Turns out to be only about 10mm higher than the stock bar on the original triples.
    Ergos are just right with my forearms almost parallel to the ground.
    The Patagonia Kid and GrahamM like this.
  11. blaine.hale
    Feb 28, 2009
    4,308
    Atlanta, Ga
    Where are y'all getting black fork boot clamps for the DRZ forks? Tried dying the stock ones with RIT dye and it just doesn't come out a good shade of black at all.
  12. Motopsychoman
    Jun 2, 2013
    5,033
    Oaklandish
    Left mine white/natural. Fine by me.
    If you want to paint them, Krylon makes some spray paints called Fusion that stick to just about everything, including most plastics. I used some gloss white to paint my black Barkbusters and it has held up very well.
  13. blaine.hale
    Feb 28, 2009
    4,308
    Atlanta, Ga
    Anyone have a part number or specs on the spring folks are using? Can't seem to get ahold of Prutser to order some.
  14. Motopsychoman
    Jun 2, 2013
    5,033
    Oaklandish
    How much are you reducing the fork travel: 50mm or 75mm? that will change the free length and potentially change the spring rate as well. Plus your weight and weight of gear.
    I have a G/S (so 75mm spacers/shorter travel), my weight 180lbs, 36L of gas plus my gear. I had Prutser supply shortened springs for that configuration. I'm pretty sure the rate was 0.50kg. I think his part number was 1709, SP-FO-1709 is on the invoice.
    Have you emailed him directly? PM isn't as effective at reaching him.
  15. blaine.hale
    Feb 28, 2009
    4,308
    Atlanta, Ga
    Do you have his email handy?
