An Unholy Union V: DRZ forks on an Airhead
Discussion in 'Airheads' started by Ras Thurlo, Jun 28, 2014.
  1. Ras Thurlo
    Ras Thurlo Desert Lion
    Aug 5, 2010
    882
    Hillcountry, Italy
    :D
    best thing is that you don't get used to it
  2. Screaming Chicken
    Screaming Chicken Long timer
    Nov 29, 2007
    1,520
    Netherlands
    Full lock with everything on. It's like the PD tank was made for these forks... :lol3
    I did notice that with the new bars it's somehow more prone to tooting its own horn... :lol3
    Some more pics of the finished product:
    Yeah. Happy with it. :-)
  3. Beater
    Beater The Bavarian Butcher
    Sep 3, 2009
    3,708
    Atlanta, GA, USA
    Is that Prutzer's triple?
  4. Screaming Chicken
    Nov 29, 2007
    1,520
    Netherlands
    Yes, though they've been somewhat modified for clearance.
    mysticerror likes this.
  5. Screaming Chicken
    Nov 29, 2007
    1,520
    Netherlands
    For the record, the stock (2x 27mm Nissin) DRZ caliper works acceptably well with the 13mm GS MC. It's not great, a bit wooden (compared to the 4-pot Brembo I had), but it works well enough that I might just leave it alone if I can't easily find a way to improve it.
    So, just checking against the odds:
    That DRZ caliper looks awfully familiar, at least every other Honda seems to use the same one by the looks of it. (Transalp, etc.) I know some of the older Hondas had slightly different Nissin calipers with bigger pistons, IIRC the Dommie and some early TAs and ATs were 2x 30mm.
    There isn't by any chance a caliper out there with slightly bigger pistons that'll slip straight onto the DRZ bracket, is there? :lol3
  6. Jim K in PA
    Jim K in PA Long timer Supporter
    Mar 15, 2011
    5,049
    Pocono Mountains, PA
    There is a 12mm BMW master you could swap to. Not a huge difference, but maybe enough??
  7. Screaming Chicken
    Nov 29, 2007
    1,520
    Netherlands
    The 12 would be nice indeed, but is not a bolt on option for the K controls on the later model GS, that's 13mm minimum.
    Converting to older-style controls seems like a whole lot of work so I'd rather leave those be. Besides, I like the K controls. :-)
    Other options are to sleeve the MC to 12mm (the Phreaky Phil option :-) ) or to get into bracketry with a different caliper altogether but that doesn't rate as easy anymore so if it comes to that I think I'll leave it as is.
    Unless it does annoy me later, obviously. :lol3
  8. PaulRS
    PaulRS Dutch fool
    Apr 15, 2008
    1,599
    Holland, land of tulips and wooden shoes
    I was in the same boat.
    Started with the oem DRZ brake, 250 mm disk and 27-27 Nissin, that may be good enough to stop a 130 kgs DRZ, but no good for a 200 kgs BMW.
    I then got a few 30-30 calipers from a TA and an old VFR, thanks to the Dutch GS-forum, no joy, they don't fit.
    Ended up with a disk from a K/R1100RS/RT, 305 mm, which is suprisingly a straight fit to the DRZ hub*, and a caliper from a F650GS, 30-32 mm, a homemade bracket, braided line and the oem 13 mm pump.
    It still is a bit wooden, but very powerfull.
    *The disk used here requires 8 mm bolts and the DRZ hub only accepts 6 mm bolts, so to make it fit I countersunk the holes in the disk carrier and used countersunk M6 bolts.
    Not the best option in my engineering point of view, but the DRZ hub has little meat to be opened up to M8, and for shouldered bolts there is no room between the bolt heads and the fork leg.
    But after a few Kkm of hard use there are no issues with those bolts used, so I tend to keep it this way.
    Paul.
  9. Screaming Chicken
    Nov 29, 2007
    1,520
    Netherlands
    I really wouldn't want to stop a fully loaded PD with the DRZ 250mm disc... The 320 disc does help a bit there. It's clearly not as powerful as the 320 disc with the 1100 Brembo caliper, that was proper brakes. But it's acceptable, certainly better than the stock GS brake.
    Pity.
    Most of the older 30-30 Nissins have a different slider pin arrangement, they're visually different, the lower slider pin is too far down. I have some hope for the '89 TA caliper, which at least visually looks compatible. I'll have a look at the local wreckers sometime.
    Then again, should I even WANT a vintage Nissin caliper? The one on the dommie was a complete disaster... :lol3
  10. tututis
    tututis Adventurer
    Aug 9, 2004
    87
    I'm working on my project and I would know something more about this bike, namely about the windscreen. I have a R80ST and I want to keep his face with a similar of bike's photo.
    It seems a GIVI windscreen...
    bleaknessengine and naginalf like this.
  11. tututis
    tututis Adventurer
    Aug 9, 2004
    87
    these are my triples
  12. Area545
    Area545 Adventurer
    Oct 8, 2014
    51
    Netherlands
    Hey Tututis,
    The windshield I used is a PUIG.
    http://www.puigusa.com/tuning-bikes/windshield-naked/c171en/f199-r20/
    Cheers,
    Michael
  13. Screaming Chicken
    Nov 29, 2007
    1,520
    Netherlands
    That is a tasty looking bike... :-)
  14. Area545
    Area545 Adventurer
    Oct 8, 2014
    51
    Netherlands
    Thnx. Very very happy with it. Triples and DRZ fork work great.
    Prutser and Dmaster :thumb
  15. Prutser
    Prutser Long timer
    Aug 5, 2012
    2,073
    The Dutch swamp
    We both love your bike too :-)
    It might need a new mastercilinder if I remember correctly :D
  16. Area545
    Area545 Adventurer
    Oct 8, 2014
    51
    Netherlands
    Is it collecting dust ? :lol3 I'll be around soon for a friday takeout wrench night :dukegirl
  17. Hogberg
    Hogberg Adventurer
    Jun 16, 2012
    21
    Sweden
    Thanks all of you for the inspiration and knowledge that is shared in here!
    After some lurking i started with my project and this is what my R80/7 looks like with an drz front end.
    Front fork is shortened 70 mm and the rear shocks are 30 mm longer than the stock ones.
    The bike handles nice and is very fun to ride.
    [​IMG][/URL][/IMG] [​IMG][/URL][/IMG]
    Anders
  18. Prutser
    Prutser Long timer
    Aug 5, 2012
    2,073
    The Dutch swamp
    It is but still at the dealer. :shog
  19. tututis
    tututis Adventurer
    Aug 9, 2004
    87
  20. Screaming Chicken
    Nov 29, 2007
    1,520
    Netherlands
    Well, shit.
    On the plus side, the forks actually still look straight, and nothing's going to hurt those triples it seems. The frame, however...
