...and what about all the recalls/retrofits?
Discussion in 'Dakar champion (950/990)' started by eugeneorange, Jun 23, 2004.
  1. eugeneorange
    eugeneorange that's gonna leave a mark
    Nov 3, 2003
    305
    Did anybody address these recalls/retrofits from the official KTM bulletins?
    • Oil hose repair kit
    • Preformed fuel hose/protection spring
    • Disc brake mounting screw
    • Swingarm bolt
    • Outer clutch hub (support rings)
    there is a whole lot more as part of this (clutch) bulletin, that seems pretty major and I never heard about them:
    - Monoshock replacement
    - Rear brake hose routing
    - Sidestand replacement
    - Instrument cover replacement
    - Chain fail protection nut replacement
    - Water pump seal ring
    - Control piston (in oil pressure pump housing) replacement
    - Oil pump connection shim installation
    - Oil check valve installation
    eugeneorange
  2. sethro
    sethro Been here awhile
    May 12, 2003
    826
    flagstaff
    Man, sure seems like these bikes have lots of problems
  3. Motobrandt
    Motobrandt Free Opinions Here Supporter
    Sep 13, 2002
    637
    Los Angeles
    Can we gather all of these "recalls" and "service bulletins" up and have them all together? I personally haven't seen any of them. I would like to create a place where we can see all of them and/or print them out to umm... show our dealers.
    If you have access to some or one could you post it please?
    thanks,
    Brandt :freaky
  4. KTMax
    KTMax Ninth of the Nazgul
    Oct 28, 2003
    1,099
    Amsterdam, The Netherlands
    As posted a few times before, the are here.
    Besides the clutch on a few of the very first '03 bikes none of them are recalls BTW. All mods and upgrades are done at the regular service intervals - if needed -.
    It's not that every 950 needs all the mods and upgrades listed above. Most bikes (mainly '03 models) need only a few of them depending on the VIN #. I think we should be a little cautious not to turn this into a some sort of witch hunt... :D :freaky
