another f800 stalling thread (solved)
Discussion in 'Parallel Universe' started by Daryloftexas, Aug 12, 2018.
  1. Daryloftexas
    Daryloftexas Been here awhile
    Mar 12, 2017
    200
    arizona
    well guys. no dice. new pump and filter did nothing. it was only about $85 for both the pump and filter and since the bike has almost 35,000 miles on it im not bothered. still very frustrated at this problem. suggestions? please look at first post to rule out anything ive already done.
    #21
  2. AntReed
    AntReed Been here awhile
    Nov 17, 2014
    294
    Kent, UK
    Next 2 most likely things in my mind are fuel pump controller, but I feel that is less likely. The other is the coils or maybe one coil? Just starting to breakdown and getting worse over time. I had a similar thing on a 1200 where a primary coil died but that felt a bit different to your issue
    #22
  3. Daryloftexas
    Mar 12, 2017
    200
    arizona
    so i actually took the controller out today and found some corrosion. cleaned it all up and plugged it all back in with no change. 20180819_140501.jpg 20180819_140506.jpg
    #23
  4. Daryloftexas
    Mar 12, 2017
    200
    arizona
    also this problem only has to do with the idle circuit so i think im going to look at all my hoses again, ill probly check the valves and spark plugs tomorrow just to rule that out.
    #24
  5. Daryloftexas
    Mar 12, 2017
    200
    arizona
    ok i got a little ancy, the first day of my weekend over here. checked the valves, even with the motor sitting in an ambient temp of 112 degrees they were all perfectly where i set them about 14,000 miles ago. this is pretty cool to know since i ring the shit out of this motor on a daily basis. plugs look pretty bad so im going to change them tomorrow just for the hell of it. theyre about the same age as the last valve adjustment. im going to disconnect my power commander until this problem is solved, i dont really want to while running the yoshi and aftermarket filter but ive never had so much trouble diagnosing a problem with a bike. this is getting ridiculous.
    #25
  6. shuswap1
    shuswap1 Long timer
    Mar 30, 2014
    1,207
    British Columbia, Canada
    Plug pics? Is it possible the idle seems just a little tiny bit low? Even 50 rpm low can cause the stalling
    #26
  7. Daryloftexas
    Mar 12, 2017
    200
    arizona
    #27
  8. dpike
    dpike BeeKeeper Supporter
    Nov 21, 2015
    1,828
    New Jersey
    Was your fpc silver or black ?
    #28
  9. Daryloftexas
    Mar 12, 2017
    200
    arizona
    silver
    #29
  10. Daryloftexas
    Mar 12, 2017
    200
    arizona
    idle seems normal, bmw says 1,200-1,300 rpm
    #30
  11. dpike
    Nov 21, 2015
    1,828
    New Jersey
    From what I read here the silver ones were known to go bad and were updated with the black version. I replaced my silver one when I did my pump and filter.
    #31
    Daryloftexas likes this.
  12. AntReed
    Nov 17, 2014
    294
    Kent, UK
    Plugs look good to me
    #32
  13. transcend_traveller
    transcend_traveller GSpusi
    Sep 9, 2015
    164
    South PA
    Could you please let me know if there a spec for this spark plug?
    Sree
    #33
  14. dpike
    Nov 21, 2015
    1,828
    New Jersey
    quoted the wrong post ?
    #34
  15. Daryloftexas
    Mar 12, 2017
    200
    arizona
    i wiped them off a bit. i think youre right though, they dont look too bad.
    #35
  16. Daryloftexas
    Mar 12, 2017
    200
    arizona
    yes, the gap is supposed to be .8-.9 mm
    #36
  17. AntReed
    Nov 17, 2014
    294
    Kent, UK
    So you had the exact same behaviour as before?? You definitely put the new fuel pump in? It just sounds perfectly the same as the issue I had which the pump cured!
    I would now start to look at all electrical connectors fuel injector idle hoses etc. With a fine tooth comb approach. It’s soo odd to not be the fuel pump but only be an issue in hot weather!!
    #37
  18. Daryloftexas
    Mar 12, 2017
    200
    arizona
    strange thing happened last night. after the new fuel pump install, i ran the bike til it got hot. i then bliped the throttle a very small amount. like 1-5% throttle which is usually what will kill it, the bike died same as before, but then it would just crank and crank and wouldnt start. i left the battery disconnected all night, went back out there this morning, put the plugs back in, installed the airbox and battery, and pushed the start button. it started right up and ran for a min, then i did the same 1-5% blip a couple times it died. now back to not starting, only cranking. im going to check that my fuel line didnt pop off in the tank. otherwise, this is very weird. maybe it was the controller the whole time? does anyone know how to test the controller, is there a spec for resistance? also if anyone would like to buy a mint f800gs with high fender and all the farkles, let me know, must bring trailer.:photog
    #38
  19. Woody2627
    Woody2627 Grey Wobbler
    Nov 11, 2008
    6,725
    Jindabyne
    You can by-pass the controller with no Ill effects. The controller just varies the voltage applied to the pump depending on fuel requirements, if you by-pass it it just applies maximum voltage. If you Google it by-pass cables are available on the net.
    #39
    Daryloftexas, Arbolmano and BygDaddee like this.
  20. Daryloftexas
    Mar 12, 2017
    200
    arizona
    well, strange turn of events. i gave the bike a little time to figure out what i had done to it and it is now running fine, its actually a lot smoother now on the highway and the exhaust note is a bit deeper, the idle problem is fully gone. i guess the power commander was never really doing much because the pump wasnt putting out the volume it was supposed to. for anyone in the future, what i would do is get it real hot and then quickly shut it off and hook up a fuel pressure tester to see what the pump is actually putting out at idle.
    #40
    transcend_traveller likes this.
